18th December 2014, 23:14 | #22021 | Link |
no,
the DGDecNV one sais 14.554kb http://forum.doom9.org/showpost.php?...ostcount=21958 the LAVF one sais 13.752 http://forum.doom9.org/showpost.php?...ostcount=22020 Between those 2 is the big difference in size and the fact that that DGDecNV one was run with multiprocess=1 (2 instances fired up) DGDecNV one 13.757kb one http://forum.doom9.org/showpost.php?...ostcount=21980 is with multiprocess=0 why the difference in size, i have no idea. But it's not the first ISO i see turning out at around 19GB. Prometheus disc 2 (bonus disc) is also such a disc that turns out at 19GB (19.995.904kb exact) |
18th December 2014, 23:22 | #22022 | Link | |
Just seems strange that both movies cut off at exactly 6 1/2 minutes. Once i have my drive i will rip a disc & try again. just to point out , i have tried both films with dvdfab & it works fine. Just out of curiosity what convert speeds & time are people getting ? I have x4 phenom 970be OC to 4.0ghz 12gb ram 6gb sata hd My convert speeds seem to be around the 8-9 hour mark with a FPS of .22 Does that seem about right ? Thanks rob Last edited by robbie74; 19th December 2014 at 00:15. |
19th December 2014, 01:42 | #22023 | Link |
@robbie74
1. Your post violates forum rules -- as discussion of downloaded copyrighted material is NOT PERMITTED on Doom9. Please review Rule #6. 2. You have violated BD-RB bug reporting rules -- as the sources have been preprocessed. #2 above is probably the reason you are having issues. There will be no more discussion related to your posts, any further discussion will result in strikes. Last edited by jdobbs; 19th December 2014 at 01:44. |
19th December 2014, 15:48 | #22024 | Link | |
20th December 2014, 04:19 | #22026 | Link | |
So, even with all the tweaks and the relatively high setting, at the most my 2nd pass is about 8 hrs or so (the 1st is consistently about 1 - 1 1/2 hrs no matter what my settings) I have an AMD APU A8-5600 with 8 Gigs of RAM. When the movie size is smaller, I usually leave it on High: Default 2 Pass and basically only tune - film, so it takes about 4 hrs on the 2nd pass. When the size is just a couple of Gigs larger than a BD-25, I leave it on 'Auto' with just the tune-film tweaks, and the 2nd pass usually only takes anywhere from 1 to 2 hrs. The FPS on the 2nd passes are about 4-5 on the really high settings and maybe around 30-70 on the lower settings. That is why I thought .22 sounded REALLY low... |
20th December 2014, 11:35 | #22027 | Link | |
20th December 2014, 13:25 | #22028 | Link | |
Banned
Hey jdobbs,
have Problems with both Hobbit Desolation of Smaug Extended 3D Discs Quote:
Got this with both Discs. Systemcheck is fine and other 3D encodes are working fine. |
20th December 2014, 17:28 | #22030 | Link |
Having issues with West Side Story 50th Anniversary Blu-ray
I ripped to ISO with AnyDVD HD 7.5.4.0 (Registered lifetime user of the Slysoft program--use same username over at their Forum as well), and while using BD-Rebuilder got this issue that I'm posting below.
I have never seen this before, so I'm stumped. (I'm removed my personal name from the text.) [12/20/14] BD Rebuilder v0.50.01 [06:37:07] Source: WEST_SIDE_STORY - Input BD size: 41.44 GB - Approximate total content: [03:02:04.036] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [06:37:09] PHASE ONE, Encoding - [08:49:37] Rebuilding stream 00508 [8 of 19] - [08:49:37] Multiplexing M2TS - Error in attempt to multiplex: MUX_00508.meta - Can't create file E:\FILEHISTORY\Username\Username-PC\DATA\C\USERS\Username\VIDEOS\WORKFILES\TMP\BDMV\STREAM\00000.m2ts - Failed to rebuild BD file(s). Aborted. ---------------------- [12/20/14] BD Rebuilder v0.50.01 [09:48:32] Source: WEST_SIDE_STORY - Input BD size: 41.44 GB - Approximate total content: [03:02:04.036] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [09:48:35] PHASE ONE, Encoding [09:48:35]PHASE ONE complete [09:48:35]PHASE TWO - Rebuild Started - [09:48:35] Rebuilding stream 00501 [1 of 19] - [09:48:35] Multiplexing M2TS - [09:48:58] Rebuilding stream 00502 [2 of 19] - [09:48:58] Multiplexing M2TS - [09:50:34] Rebuilding stream 00503 [3 of 19] - [09:50:34] Multiplexing M2TS - [09:51:00] Rebuilding stream 00504 [4 of 19] - [09:51:00] Multiplexing M2TS - [09:51:37] Rebuilding stream 00505 [5 of 19] - [09:51:37] Multiplexing M2TS - [09:54:42] Rebuilding stream 00506 [6 of 19] - [09:54:42] Multiplexing M2TS - [09:55:02] Rebuilding stream 00507 [7 of 19] - [09:55:02] Multiplexing M2TS - [09:55:46] Rebuilding stream 00508 [8 of 19] - [09:55:46] Multiplexing M2TS - [09:58:03] Rebuilding stream 00511 [9 of 19] - [09:58:03] Multiplexing M2TS - [09:58:19] Rebuilding stream 00512 [10 of 19] - [09:58:19] Multiplexing M2TS - [09:58:32] Rebuilding stream 00513 [11 of 19] - [09:58:32] Multiplexing M2TS - [09:58:42] Rebuilding stream 00514 [12 of 19] - [09:58:42] Multiplexing M2TS - [09:58:53] Rebuilding stream 00515 [13 of 19] - [09:58:53] Multiplexing M2TS - [09:59:01] Rebuilding stream 00516 [14 of 19] - [09:59:01] Multiplexing M2TS - [09:59:10] Rebuilding stream 00517 [15 of 19] - [09:59:10] Multiplexing M2TS - [09:59:23] Rebuilding stream 00518 [16 of 19] - [09:59:23] Multiplexing M2TS - [09:59:26] Rebuilding stream 00519 [17 of 19] - [09:59:26] Multiplexing M2TS - [09:59:30] Rebuilding stream 00520 [18 of 19] - [09:59:30] Multiplexing M2TS - [09:59:34] Rebuilding stream 00521 [19 of 19] - [09:59:34] Multiplexing M2TS - [09:59:38] Rebuilding BD file Structure [10:00:19] - Failed to REBUILD |
20th December 2014, 22:17 | #22031 | Link | |
SubME-9 is REALLY going over the deep end and it HUGELY impacts the encoding time for likely no real visual gain... 'Auto' is probably just fine for everything. I just personally start getting a little nervous when the disc size starts getting pretty big and BDRB want's to do the encode really fast, although I'm sure the result would be excellent. I mean, shoot... I USED to be perfectly happy with the free DVDFab encodes, and we KNOW JD's program is a heck of a lot better than that! |
21st December 2014, 19:15 | #22032 | Link | ||
[21:32:32] Source: HOBBIT_DOS_EXTENDED_3D_PART1_00100 - Input BD size: 31,53 GB - Approximate total content: [01:36:05.676] - Target BD size: 23,73 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Ultra-High (Extremely Slow), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:32:32] PHASE ONE, Encoding - [21:32:32] Processing: VID_00049 (1 of 1) - [21:32:32] Extracting A/V streams [VID_00049] - [21:38:32] Reencoding video [VID_00049] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 138*238 frames - Bitrate: 26*485 Kbs - Using FRIMEncoder for MVC encoding - [21:38:32] Reencoding: VID_00049, Pass 1 of 1 - [22:18:16] Video Encode complete - [22:18:16] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4354 (hun): Keeping original audio [22:18:16]PHASE ONE complete [22:18:16]PHASE TWO - Rebuild Started - [22:18:17] Rebuilding BD-3D file Structure [22:31:33] - Encode and Rebuild complete [22:31:33] JOB: HOBBIT_DOS_EXTENDED_3D_PART1 finished. Quote:
[12.21.14] BD Rebuilder v0.50.01 [18:52:59] Source: GONE GIRL - Input BD size: 41,71 GB - Approximate total content: [02:41:27.677] - Target BD size: 23,93 GB - Windows Version: 6.2 [9200] - Quality: Ultra-High (Extremely Slow), Two Pass - X264 Tweak(s) enabled |
22nd December 2014, 10:43 | #22034 | Link | |
Banned
That was a while ago and you are using an older version, maybe something changed? Code:
[12.22.14] Checking System Settings - BD-Rebuilder v0.50.01 - Windows Version: 6.1 [7601] - Working Path Free Space: 42,95GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [12.22.14] Systems Settings Check complete Code:
[12.22.14] BD Rebuilder v0.50.01 [10:40:17] Source: HOBBIT_DOS_EXTENDED_3D_PART1 - Input BD size: 35,04 GB - Approximate total content: [02:00:51.994] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [10:40:17] PHASE ONE, Encoding - [10:40:17] Processing: VID_00031 (1 of 3) - [10:40:17] Extracting A/V streams [VID_00031] - [10:40:28] Reencoding video [VID_00031] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8.159 frames - Bitrate: 5.890 Kbs - Using FRIMEncoder for MVC encoding - [10:40:28] Reencoding: VID_00031, Pass 1 of 1 [10:40:30] - Failed video encode, aborted |
