15th June 2010, 16:06 | #82 | Link | |
This is not supported. Please make a clean installation (instruction in the first posting). If you overwrite your installation the files will not be updated because the build number of the tools does not change. Therefore you have to replace all files yourself.
Since a few build DGMultiSource is the default value but this will only be applied to new installations. You can change it manually in the settings - deselect "Use CUVIDServer". |
16th June 2010, 21:18 | #84 | Link |
Hello. I have the same problem than Inspector Gadget - when I try to load avs script, megui comes up with an error "avisynth script error: cannot load avisynth.dll"
I have confirmed that avisynth is working by loading the same avs file in virtualdub x64. I have the latest MeGUI 0.3.4.17 x64 |
16th June 2010, 22:38 | #89 | Link |
The changelog for .15 doesn't reveal any alteration to the Avisynth detection method, so maybe Zathor can think of something else relevant. For fun, try importing the registry file in joshyd's package and see if it's a paths issue.
16th June 2010, 22:40 | #90 | Link | |
http://megui.org/auto At the moment I believe your avisynth installation is somehow corrupt. Please try to open the AVS script for example with VirtualDub x64. |
16th June 2010, 22:56 | #91 | Link |
Read post number #84 I already tried to open the avs script in virtualdub 1.9.9 x64 - no problem.
And i will try older build, but later.... Edit: tried megui-core versions: 0.3.4.12, 0.3.4.13, 0.3.4.14, 0.3.4.15 all the same error. Don't know what other files I should try to revert? And executing avisynth.reg didn't change anything. Last edited by pokazene_maslo; 16th June 2010 at 23:32. |
18th June 2010, 14:34 | #93 | Link |
@pokazene
virtualdub is finding avisynth.dll somewhere that megui isn't, is mpc-hc x64 opening the avs ok? i doubt avisynth64 is installed properly, are you sure the install batch file executed properly and reg imported properly? that's where you need to be looking, it's all plain text. @tormento i dont know exact technical reasons but the output mkv coming directly from the encoders are lacking some info that mkvmerge will add upon muxing in audio(or just remuxing), i guess this might be a nuisance if you dont generally add any other audio or files to the final output, but having megui automatically remux mkv's would be a waste of time for most users. |
18th June 2010, 17:38 | #95 | Link | |
19th June 2010, 14:35 | #96 | Link | |
tried - no change. |
28th June 2010, 03:31 | #97 | Link |
Zanthor: I'm having this strange error that sometimes pops up when a processing job finishes. Its occurrence seems to be random. After it occurs MeGUI then crashes.
It also seems to be limited to x264 jobs, not audio encoding jobs. |
29th June 2010, 15:20 | #98 | Link | |
Mr. Sandman
install FFDSHOW (64 bits)
30th June 2010, 07:19 | #100 | Link |
Hi Zathor,
I'm getting this error when I'm trying to use the one click encoder. it looks it's having trouble generating output filename. basically i have been through Futurama season 1 using the one click encoder without any problems but when i start on season 2 i get that error, if i try and load another season 1 vob in it work fine. i have closed MeGUI and reopened and it still does it. Code:
[Error] Unhandled error -[NoImage] Exception message: An attempt was made to move the file pointer before the beginning of the file. -[NoImage] Stacktrace --[NoImage] at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) --[NoImage] at System.IO.FileStream.SeekCore(Int64 offset, SeekOrigin origin) --[NoImage] at System.IO.FileStream.Seek(Int64 offset, SeekOrigin origin) --[NoImage] at MeGUI.core.util.IFOparser.GetFileBlock(String strFile, Int64 pos, Int32 count) --[NoImage] at MeGUI.IfoExtractor.GetChapters(String ifoFile, Int32 programChain, TimeSpan& duration, Double& fps) --[NoImage] at MeGUI.IfoExtractor.GetStreams(String location) --[NoImage] at MeGUI.VideoUtil.getChaptersFromIFO(String fileName, Boolean qpfile) --[NoImage] at MeGUI.OneClickWindow.openInput(String fileName) --[NoImage] at MeGUI.FileBar.triggerEvent() --[NoImage] at MeGUI.FileBar.setFilename(String filename) --[NoImage] at System.Windows.Forms.Control.OnClick(EventArgs e) --[NoImage] at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) --[NoImage] at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) --[NoImage] at System.Windows.Forms.Control.WndProc(Message& m) --[NoImage] at System.Windows.Forms.ButtonBase.WndProc(Message& m) --[NoImage] at System.Windows.Forms.Button.WndProc(Message& m) --[NoImage] at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) --[NoImage] at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) -[NoImage] Inner exception: null Code:
[Information] Versions -[NoImage] MeGUI Version : 0.3.4.18 x64 -[NoImage] OS : Windows Seven Ultimate Edition x64 (6.1.0.7600) -[NoImage] Latest .Net Framework installed : 4.0 (4.0.30319) -[NoImage] Avisynth Version : 2.5.8.5
A Man Eating Duck Last edited by AMED; 30th June 2010 at 07:24. |
