Old 21st September 2017, 09:10   #15321  |  Link
hogtop
FFDSHOW -work with avx 512 ?HDR ? REC 2020 ? amd ?
do FFDSHOW video and sound
works with :
1. Intel's AVX 512 commands ?
2. HDR - do you support ? to what level 1000/2000NITS ?
3.Can FFDSHOW convert SDR to HDR ?
4. Which computer is recommended for FFDSHOW? Intel or AMD ?
5. Does FFDSHOW support new commands for new AMD processors Threadripper 1950X ?
SHA / Secure Hash Algorithm extensions
F16C / 16-bit Floating-Point conversion instructions
FMA3 / 3-operand Fused Multiply-Add instructions
SMAP / Supervisor Mode Access Prevention
SMEP / Secure Mode Execution Protection
Precision Boost
Extended Frequency Range
6. Does FFDSHOW support REC 2020 ?
Can convert color from SDR to REC 2020 ?
7. i open a lot of tabs in FFDSHOW
the film is very slow, as if the processor is too weak
which processor is best for FFDSHOW ?
( when i open many tabs on-FFDSHOW )
thank you for your answer
hogtop is offline   Reply With Quote
Old 21st September 2017, 09:11   #15322  |  Link
nevcairiel
ffdshow has been abandoned for years, it doesn't support any modern instruction sets or any sort of HDR.
Old 21st September 2017, 09:21   #15323  |  Link
hogtop
http://ffdshow-tryout.sourceforge.net/
it says there was an update on 2014-06-28
it is very unfortunate to hear
which system is best coded today? KLITE ?
Old 21st September 2017, 09:39   #15324  |  Link
LigH
LigH's Avatar
You seem to confuse "codec" (encoder / decoder) and "pack".
K-Lite is a collection of many different decoders from many different authors, for many different purposes. It even included ffdshow as multi-format decoder.
If you had read this thread before asking, you would know that the next evolutionary step after ffdshow is "LAV Filters". Look at nevcairiel's signature.
New German Gleitz board
Old 21st September 2017, 09:49   #15325  |  Link
hogtop
i very much hate "LAV Filters"
you can not tune them professionally like FFDSHOW
Still with KLITE the questions remained .
FFDSHOW IN KLITE
Old 21st September 2017, 10:04   #15326  |  Link
LigH
LigH's Avatar
Well, this may rather be a request for LAV Filters than a complaint in the ffdshow thread, which is futile now, as it is abandoned...
And, as just explained, the "K-Lite pack" is only a collection. It is not decoder software on its own. The author of the K-Lite pack did not develop a codec.
Old 21st September 2017, 11:10   #15327  |  Link
hogtop
encoded that can not be directed seriously like FFDSHOW
for me it's a big problem!
because LAV Filters Does not bring quality in image or sound!
he plays everything, but not quality
why are there no encoders you can tune like FFDSHOW ???
it's a shame to see that there are no groups to develop good, serious encoders that can be directed .
too bad that no one buys the FFDSHOW and develops the encoders for money .
I would be happy to pay FFDSHOW money for quality encoders
Old 21st September 2017, 11:19   #15328  |  Link
nussman
FFDShow is not an encoder, it's for decoding and processing.
For Video processing you can use madVR and for audio processing you can still use ffshow after the decoder.
nussman is offline   Reply With Quote
Old 25th September 2017, 16:16   #15329  |  Link
hogtop
Why use madVR
FFDSHOW does everything better (although not updated from 2014)
that means a lot not good things about development
i'm trying to direct the madVR not contributing anything good
maybe someone here has a right direction for madVR? For OLED ?
which computer processor is good for madVR ?
i have an OLED screen that I must say is not worth anything to the computer
maybe because all VGA cards are not WRGB and RGB
the LG processor is bad
UPSCALE LG Worse
there are no good shades
there are no grays
contras are bad
Old 25th September 2017, 17:00   #15330  |  Link
why don't you sit back for a little bit and rethink a bit...
i mean you are saying stuff like this:
maybe because all VGA cards are not WRGB and RGB.
every playback device is using YCbCr and RGB so the PC VGA has nothing todo with it...
so you are saying madVR is not contributing anything good and you don't even know it is mostly using the GPU not the CPU?
UPSCALE LG Worse
there are no grays
contras are bad
while LG is not known for good processing you should really fix your settings...
Old 29th September 2017, 18:29   #15331  |  Link
hogtop
I have no idea what you're writing about? Do you have any idea what you are writing?
so what wrong with the truth ?
you want to calibrate a video card ( RGB/YCbCr )to the WRGB screen there are large backlight ( oled light) issues in the OLED, there are brightness issues
Not to mention that LG's algorithm system is very poor and distorted image
no
not every playback device is using YCbCr and RGB
OLED TV have only YCbCr but it has a problem that the OLED color is WRGB
and that does not work out very well at calibration.
amazing you success understand!
1. madVR adds different types of noise in the image
2. madVR Causes problems of uneven sound to the lips
3. madVR running it takes up to 26% of CPU power not GPU
4. madVR in LED works better
i curse every day I bought an OLED, not a good connection to the computer
fix your settings
What to fix? How to fix ? You throw things in the air
I paid for 2 professional calibrations for $ 600 and got a worse
picture!
I said maybe I'll learn from others by their calibration
It turns out that no one really knows how to calibrate OLED and they all invent stories :
Home Theater Geeks 324: Leo's LG OLED Followup
https://www.youtube.com/watch?v=sBDun9fbEWU&t=355s
In program 323, they made a professional calibration with equipment worth $ 35,000 on a $ 4000 screen
and they did not succeed, in they site published the results of the calibration was discovered inaccuracies, lack of professionalism, irrationality
and for 60 minutes (In program 324 ) they told 100 stories and they promised to calibrate OLED again and tell about results, which did not happen !!!
( Most of the experts in their forum who raised the problems in their calibration that the results are illogical - were deleted from the forum !!! )
now ask but no forum does not register the truth?
1. The OLED UK and USA forums are managed by PRs, eliminating any question or problem in OLED!
2. LG pays a lot of money to publicists, site owners and mute people!
the trips to exhibitions abroad + hotels LG pays them.
Note:
OLED shows full Blu-ray through OPPO in quality !
but any other video that is not Blu-ray , full of problems
Old 5th October 2017, 17:40   #15332  |  Link
i know it not a good idea to answer any of this delusion so i make it short.
an oppo (and every other BD player) send RGB or YCbCr like any other PC gaming console and settop box.
this is the fundamental of video processing and this is missing so nothing more to say.
Old 7th October 2017, 02:33   #15333  |  Link
Asmodian
I recently purchased an LG OLED55C7P and was able to calibrate it quite successfully. It is now extremely accurate in SDR but only fairly accurate in HDR.
I used a Display 3 Pro I profiled on my TV with a i1 pro2. My white point looks very good, contrast is amazing, and my gamma is a near perfect pure power 2.4. The highest error is at ~2 dE and most colors are <1 dE (DCI-P3, D65, BT.1886), and that is before madVR with a 3DLUT.
I am not sure why your professional calibrator failed so badly but it did take me some experimenting with my TV's options to figure how what to tweak and what to leave alone. Using the TV's color management was not good, nor was using its 20-point white point adjustment. However, the two point white point adjustment worked quite well and I was able to get a near perfect gray scale, every patch in the entire 21 point gray scale was <1 dE.
I do have some minor banding I was unable to get rid of but otherwise I am very happy with the image quality and its before software calibration.
Of course this might not be the case with older models but it isn't a problem calibrating OLED TVs in general.
madVR options explained
Old 7th October 2019, 00:44   #15334  |  Link
JReiginsei
Can side left, side right, and back center be added to the Convolver module?
It seems if the Convolver module order is moved after Mixer, Convolver doesn't function properly, at least for back left and back right.
Intel Core i5-4250U, 8 GB Ram, Intel HD 5000
JReiginsei is offline   Reply With Quote
Old 7th October 2019, 15:10   #15335  |  Link
Phanton_13
JReiginsei, lamentably ffdshow is dead, I wish that at least one fork with only the post processing filters existed that is the think that I really miss of it in LAV Filters.
Phanton_13 is offline   Reply With Quote
Old 8th October 2019, 07:11   #15336  |  Link
LigH
LigH's Avatar
And I would enjoy, in addition, a separate ffvfw codec providing the ffmpeg implementations of FFV1, MJPEG, DV, Huffyuv ...
Old 29th January 2020, 17:11   #15337  |  Link
Dogway
Does this include the ffmpeg's sofalizer filter for downmixing multichannel audio with a HRTF function?
Old 6th February 2020, 21:57   #15338  |  Link
sofakng
What's the latest version of ffdshow?
I know that ffdshow was abandoned a long time ago, and then I think that ffdshow-tryouts was created and updated.
So... I think my question should be, what's the latest version of ffdshow-tryouts?
(I need it for SVP playback with DirectShow-based media players)
sofakng is offline   Reply With Quote
Old 6th February 2020, 22:40   #15339  |  Link
Thundik81
The one in K-Lite Mega Codec Pack:
https://codecguide.com/features_mega.htm
Thundik81 is offline   Reply With Quote
Old 7th February 2020, 01:22   #15340  |  Link
hello_hello
A late reply I know, but ffdshow effectively comes with filter-only versions. They can be used to process the decoded video or audio with a player such as MPC-HC by adding them under External Filters in preferences (it's probably an idea to set them to "prefer"). To configure them, you can double click on their entries in the External Filters list. The video processor is called "ffdshow raw video filter" and for audio it's "ffdshow audio processor".
I vaguely remember the raw video/audio filters don't have shortcuts added to the start menu. Someone must have told me how to create them manually if that's the case. I'm running XP, so for me the raw video processor shortcut is:
C:\WINDOWS\system32\rundll32.exe "C:\Program Files\ffdshow\ffdshow.ax",configureRaw
and for audio it's
C:\WINDOWS\system32\rundll32.exe "C:\Program Files\ffdshow\ffdshow.ax",configureAudioRaw
I can't remember if they can be installed separately, but you can do much the same for other players by disabling all the codecs in the regular filters except for raw video/audio.
I seem to have rev 4532 installed and there's two headphone presets, one labelled HRFT and the other "Headphone Virtual Spatialization". Are either of those it?
Last official release or recommended version.
http://ffdshow-tryout.sourceforge.net/download.php
Wikipedia says the latest is rev.4533
https://www.videohelp.com/software/ffdshow
But rev.4534 can be found via the last two links here. It the same version as in the codec pack, according to the K-Lite website.
https://www.free-codecs.com/ffdshow_download.htm
