14th March 2011, 18:56 | #423 | Link | |
partially-informed layman
I've been doing some testing with it and it seems to be right. All just done single-threaded on my laptop. One thing I noticed was that the ShutterBlur setting didn't seem to make much difference to speed at all, so I left it at 3 for most tests. I didn't see much difference between using SBlurLimit or not on this particular clip. The table more or less speaks for itself: I zipped up the 3 x 10 second tests I've highlighted in yellow and put them here if anyone is interested. Footage used with permission from Stringer (Gregory) on the Vegas forum. I would be interested to hear which people prefer. By the way Vit, are you making a general recommendation for FPSDivisor=2 over SelectEven (which is currently in your "Getting Started" section)? I just want to be consistent with you in my guide. |
14th March 2011, 19:04 | #424 | Link |
Sorry! I have read and re-read the Noise part of the docs and nowhere does it say that NoiseProcess has to be non-zero for ChromaNoise to work. If it's supposed to be obvious due to the nature of Chroma noise... Well it's lost on us newbie types who don't really understand the finer points of video
14th March 2011, 20:53 | #425 | Link | ||
nhope: Thanks for the clarification that 180 degrees is the norm for shooting that kind of footage. Reading your thread over at Sony just confirms that there can be some confusion over shutter speeds. I'm going to stick with using shutter angle for the settings as it makes people think and/or ask rather than use the settings blindly...
The default setting for SBlurLimit should be OK for most sources, it's just an extra tweakable in case difficult motion is causing unwanted distortion/smearing. Similar with the higher shutter blur settings (2,3). Edit: As noted in the docs, increasing those settings will likely reduce the level of blur a little from where it should be for the requested shutter angle. Looking at your motion blur samples - the 1/30s shutter version seems to have a little less blur than I would expect. I would stick to the (faster) ShutterBlur mode 1 and a lower SBlurLimit value (default is good). It doesn't harm to change ShutterAngleOut to get a bit more or less blur as you wish [The ideal would be to make some actual footage with known shutters and compare]. However, that particular footage is quite soft already and the motion is smooth, it doesn't benefit much from extra blur. I found motion blur works better on higher contrast video, with swift or sudden motion. It's also excellent for footage shot with a fast shutter, which really suffers when dropping to single rate. You must use FPSDivisor if you're using shutter motion blur whilst cutting to single rate - it needs to know that information along with the shutter angles to calculate the correct amount to blur. If you're not using shutter motion blur it makes little difference whether you use SelectEven or FPSDivisor - whichever makes your tutorial easier. [BTW: Ouch on those fps... Time to upgrade...] ____ Quote:
15th March 2011, 20:18 | #427 | Link |
Anime addict
Hi, thanks for your update.
This version throw an exception: With version 3.20 doesnt pass me. I do two scripts and run both, with rendering pass(lagarith). 1st script Code:
DirectShowSource("E:\Pruebas Ghost Hound\16\F8_T2_Video - .mkv") AssumeFPS(30000,1001) QTGMC(preset="very fast" ) Selecteven() threads=2 x=(framecount()/threads) A=trim(0,x) B=trim(x+1,0) return A Code:
DirectShowSource("E:\Pruebas Ghost Hound\16\F8_T2_Video - .mkv") AssumeFPS(30000,1001) QTGMC(preset="very fast" ) Selecteven() threads=2 x=(framecount()/threads) A=trim(0,x) B=trim(x+1,0) return B
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
15th March 2011, 22:16 | #428 | Link |
I have not seen an error like this before. Does it happen with preset "Faster" or "Ultra Fast"?
You could try this: Code:
QTGMC( preset="very fast", SafeMode=true ) Last edited by -Vit-; 15th March 2011 at 22:26. |
16th March 2011, 00:06 | #429 | Link |
Anime addict
In safemode run fine but decrease speed process, around of 2 frames/second. Now, my process is of 2.30 hours before was of 1.50 hours, more or less.
16th March 2011, 01:10 | #430 | Link |
The bug is in MVTools2. Make sure you have the latest version of MVTools2 and try again without SafeMode.
If it still crashes then this line will restore the behavior of the last version (3.2): Code:
QTGMC( Preset="Very Fast", Overlap=16, SLMode=1, SrchClipPP=0 ) |
16th March 2011, 03:53 | #431 | Link |
Anime addict
I already installed last version MVtools. In fact, i don know that new features in this version, but in my case, deinterlaced bad in the same mode. Snapshots:
Version 3.20, preset very fast New version, preset very fast
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 16th March 2011 at 03:56. |
16th March 2011, 04:08 | #432 | Link |
Final Edit (I hope): I can reproduce the MVTools crash, I'll look into that later.
However, I cannot reproduce the major ghosting shown in your images. Could you upload part of your source please? Last edited by -Vit-; 16th March 2011 at 05:03. |
16th March 2011, 05:43 | #433 | Link |
I also found some problem bobbing a 1080i source. The field order is correct as confirmed by separatefields(). But the motion jumps "backward" in some scenes. I am using Preset="Faster" and tr2=2. Setting EdiMode="Yadif" solves the problem.
16th March 2011, 09:44 | #434 | Link | |
16th March 2011, 12:11 | #437 | Link | |
Anime addict
@Vit. My source is 1080i@29.97. I upload a part of interlacing credits, compress in x264 @ 5000 Kb/s. If you need that upload in other format, only say me. ^^ http://www.megaupload.com/?d=ZJSXS36E
16th March 2011, 17:36 | #438 | Link |
Overdrive80: The field parity needs to be reversed. This worked fine for me:
FFVideoSource( "E:\Video\Test\Original.mp4" ) ComplementParity() QTGMC( Preset="Very Fast" ) |
16th March 2011, 18:22 | #439 | Link | |
Anime addict
My question is for curiosity... because is necesary add a filter for autodetecting dominant field but not with previous version?
16th March 2011, 20:53 | #440 | Link |
I am using a script based on Nick Hope's work. However, I have made it multithreaded. Everything works with the older version of QTGMC, but only with Very Fast. When I use Fast, I get problems. Here's the script:
#Script to deinterlace video based on QTGMC deinterlacing script #Designed to produce 1280x720 progressive video loadplugin("C:\Program Files\AviSynth 2.5\plugins\MVTools\mvtools2.dll") #--------------------------- #Import("E:\Documents\My Videos\AVISynth Scripts\QTGMC3.20.avsi") #older script Import("E:\Documents\My Videos\AVISynth Scripts\QTGMC3.25.avsi") #Serve out from Vegas in RGB24 SetMemoryMax(768) SetMTMode(5,4) AVISource("e:\frameserver.avi").assumetff().ConvertToYV12(interlaced=true,matrix="PC.709") # SetMTMode(2) LanczosResize(1280,height) #--------------------------- QTGMC( Preset="Very Fast", FPSDivisor=2, EdiThreads=0, ShowSettings=false ) #QTGMC( Preset="Faster", FPSDivisor=2, EdiThreads=0, ShowSettings=false ) LanczosResize(width,720) ColorYUV(levels="PC->TV") #Scale levels from [0,255] to [16,235]. Compensates for Flash Player scaling [16,235] to [0,255]. Code:
Script Version Script Preset QTGMC3.20.avsi QTGMC( Preset="Very Fast" ... ) QTGMC3.20.avsi QTGMC( Preset="Faster" ... ) QTGMC3.25.avsi QTGMC( Preset="Very Fast" ... ) QTGMC3.25.avsi QTGMC( Preset="Faster" ... ) I have tried changing the SetMemoryMax number and also tried changing the number of cores in the first SetMTMode, but all that does is change how long it takes before the crash happens. It usually takes about 200-500 frames before the crash begins (the fps counter drops for about a dozen frames prior to the crash). For the third test listed above (your newest script with the Very Fast setting), here is the relevant line (I think) from the crashinfo.txt log: Code:
Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'mvtools2'... ...reading address 247EF1D2. Oh, and prior to the beginning of the crash, the newer script runs considerably slower, probably about 30% slower, with each of the settings. Let me know if you need any other information. |
