Old 17th June 2005, 21:01   #441  |  Link
CAPM32
I've created russian language file (it's parital however). But some captions don't fit.
Also it would be good to add translatations for drop down controls.
It would be nice if language file will be accepted automatically if placed in appropriate folder (menu languages updated).
CAPM32 is offline   Reply With Quote
Old 17th June 2005, 21:32   #442  |  Link
odyn1982
I've translated english.ini to polish language. I hope that You will add this translation to BeLight
Thx
odyn1982 is offline   Reply With Quote
Old 18th June 2005, 09:32   #443  |  Link
daphy
Miles Freak
daphy's Avatar
Mirror
Hi folks,
my provider has been hacked two times this week, on the second attemp needfulthings went down - letīs see what damages happens
anyway here another mirror of the latest BeLight beta 4
the new language ini arenīt included due to their missing approval!
CYA Daphy
daphy is offline   Reply With Quote
Old 18th June 2005, 12:28   #444  |  Link
mazzo
Empty dialogs in beta 4
Strange - the dialogs in beta 4 are empty.
--------- SORRY: Forgot to make a "lang" folder. Everything is OK ----------
mazzo is offline   Reply With Quote
Old 18th June 2005, 16:30   #445  |  Link
drob
Kurtnoise13 Beta 4 works fine, no access violations no more. Is there a way to use toolame.exe instead of the dll? the dll is known to have hiss issues.
drob is offline   Reply With Quote
Old 18th June 2005, 16:59   #446  |  Link
johnman
johnman's Avatar
There is also an other program based on toolame call tWolame. If you are going to use the executable you might consider twolame.exe.
johnman is offline   Reply With Quote
Old 19th June 2005, 03:59   #447  |  Link
humax
how can i change output name and output path ??
wave to mp3 convert
thx
humax is offline   Reply With Quote
Old 19th June 2005, 06:05   #448  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
First of all, thanks for the translation guys. I really appreciate. I'll add them in the next release.
wave to mp3 convert
Open... --> Save...That's all.
Are you sure ? Give me a link please...
Indeed...
Yes, it was in my todo list. btw, what do you think about an unicode version ? Can you make a such thing ? Unfortunately, I can't compile myself unicode support with my D7 Personnal Version. So, if you want and if you can, I'll update the CVS today...It seems that CoreCodec works now.
Old 19th June 2005, 11:02   #449  |  Link
drob
Kurtnoise13, here is the answer from DSPguru himself, to a post i made awhile back:
there has been a report about static noise that can be found in one of the channels when encoding with toolame.dll, so until i shot this, mp2enc.dll is the default way to go (or make your own personal test and find a mode that you're satisfied with).
This is why toolame.dll isn't included with BeSweet package.
The issue seems to be hiss in the left channel using certain psy modes, which is not present in the exe version.
Old 19th June 2005, 14:48   #450  |  Link
Kurtnoise
Kurtnoise's Avatar
Yes but there is mp2enc.dll...Have you tested extensively with this library ? Is it bad ? I don't think so...
Old 19th June 2005, 16:30   #451  |  Link
drob
mp2enc.dll is not bad, it is based on an earlier version of toolame.dll, and was created for cdex, as such toolame is more optimized, this had been discussed on hydrogenaudio, and most testimonies are that in most case toolame is slightly better then mp2enc.dll.
Old 19th June 2005, 16:44   #452  |  Link
Kurtnoise
Kurtnoise's Avatar
slightly, yeah. So, the easier way (if you want to use BeLight) could be to create a batch file (by using azid if your source is ac3 and/or toolame). Then, in Edit BeSweet command line you write the command (example : c:\windows\cmd.exe c:\my_batch_file.bat) to run this batch file...
Old 19th June 2005, 16:52   #453  |  Link
drob
Could you integrate toolame.exe into the GUI? enabling to choose between mp2enc, toolame dll and the executable? maybe by adding a fixed command line that points to toolame.exe and parsing the switches from the dll?
Old 19th June 2005, 17:01   #454  |  Link
Kurtnoise
Kurtnoise's Avatar
I'll try but you must know that it's not my first priority.
Old 19th June 2005, 17:17   #455  |  Link
drob
It is your up-most priority, got it
Old 19th June 2005, 20:17   #456  |  Link
Backwoods
ReMember
Backwoods's Avatar
The progress bar does not move for me nor does the CML come up anymore. Normal changes?
Backwoods is offline   Reply With Quote
Old 19th June 2005, 21:53   #457  |  Link
drob
I can confirm progress bar not moving.
Old 19th June 2005, 22:59   #458  |  Link
Kurtnoise
Kurtnoise's Avatar
With what kind of input files ? ac3 or anything else ?
Old 19th June 2005, 23:50   #459  |  Link
Backwoods
ReMember
Backwoods's Avatar
Only tried WAV to AC3. I can test others tonight.
Old 20th June 2005, 03:21   #460  |  Link
absinthe
absinthe's Avatar
Ok, I haven't been following this whole thread along, but what does it mean when all your labels disappear (literally all the words on the GUI)? I do have a 'lang' folder which contains English.ini.
I just upgraded to the latest beta, and it worked the first time I ran it, but after that all my labels disappeared. Weird.
-abs
edit: Oh yeah, and the progress bar doesn't seem to move right for me, either.
Also, is there some limitation or bug with batch encoding? That's my main reason for wanting to use BeLight (no batches in Headac3he). I queued up 4 jobs and the first 3 seem to have worked, but I got an abort in the last one. And all 4 jobs were virtually identical, so there should've been anything peculiar about job #4 that caused it to crash.
-abs
The perfect browser is now completely free: Opera. Get it. Love it.
absinthe is offline   Reply With Quote
