15th September 2008, 16:02 | #1241 | Link |
Feature Request
dmz01, if you are still around and still developing this application, I would like to request a feature.
It would be very beneficial if you added the ability to open/import more than one file at a time, and then select the desired tracks for output - similar to the way TsMuxer handles this. TsRemux has a few features that TsMuxer does not have (correct TrueHD handling being a big one), but the ability to only open a single file at a time is a huge hindrance. This is a great program and I only hope that it continues to improve. |
19th September 2008, 16:17 | #1242 | Link | |
22nd September 2008, 13:03 | #1243 | Link |
Posts: n/a
Anyone help i used TsRemux 0.21.2 on a Blu ray recently with TrueHD audio and stripped everything else out, Now when i tried this i found that every few seconds the {icture speeds up and audio loses sync then everything goes back to normal. Anyone.
Thanks |
23rd September 2008, 18:52 | #1244 | Link | |
Similar Issue here.
I know the audio is there, its just not working on my "standalone" player. |
26th September 2008, 21:20 | #1245 | Link | |
26th September 2008, 22:01 | #1246 | Link | |
27th September 2008, 23:06 | #1247 | Link |
TsRemux does handle TrueHD, though not always -- I've found it to be pretty good with BD TrueHD and less good with HD DVD TrueHD. I'm bitstreaming from a Popcorn Hour A-110 to an Onkyo 605 and an M2TS or TS stripped with TsRemux often plays TrueHD fine. What movies are you guys using?
12th October 2008, 01:39 | #1248 | Link |
I am having a problem backing up Meet the Robinsons and Ratatouille with the audio going out of sync. I am trying to convert the movies to 720p h.264 mkvs. I have read that TSRemux is the right tool to help me with my problem, that once I have muxed all the m2ts files into a single m2ts that if I run that through TSRemux it fixes it. Unfortunately it doesn't seem to have worked.
Originally I was using TSMuxeR to create the single m2ts file. Playing the m2ts file everything was in sync, but the converted mkv (using AutoMKV) had audio sync issues, in sync at the beginning, but gradually falling out of sync towards the end. I then used TSMuxeR to join the m2ts files, then ran the resulting m2ts through TSRemux, twice actually, once to create a new m2ts file (with video and 3 ac3 streams), and then again to create a .ts file which AutoMKV prefers. Again the converted file has the same sync problems. From what I have read it seems to be the audio that is the problem, that the video is likely fine. Any ideas what I can do to demux, create or convert the 3 AC3 streams correctly? |
12th October 2008, 02:11 | #1249 | Link | |
After the first "pass" eac3to will advise you it has found audio gaps that need correcting, and you should run the process again, exactly the same as before (you will notice extra files relating to the audio gaps) After the 2nd pass, you should then run through tsremux or tsmuxer to mux to ts and then your good to go... |
12th October 2008, 03:31 | #1250 | Link |
Thanks very much, eac3to was the trick.
Rather than starting again I found someone suggesting to demux the m2ts with eac3to twice, utilizing .gaps files which fixed the audio. Then I was able to just remux the converted h.264 and the eac3to ac3 files, yay |
12th October 2008, 16:41 | #1251 | Link |
For using TsRemux under Linux/MacOS X see this thread.
14th October 2008, 12:59 | #1252 | Link |
"Presentation Graphics Stream" Subtitles don't work
v.0.0.21.2
When I load my mpeg program stream files recorded from a Nebula DigiTV card & software, the DVB(UK) subtitles are correctly detected as "Presentation Graphics Stream # 32". So far so good. After remuxing to TS or M2TS format, neither VLC nor VideoRedoTVS see the subtitles. Can anyone help with this? |
18th October 2008, 14:07 | #1253 | Link |
Location: The Great North (the better half of North America)
I'm trying to remux a m2ts file with TrueHD, originally muxed with tsMuxeR. I get an error though;
Unhandled exception has occured in your application. If you click Continue, the application will ignore and attempt to continue... or Quit. Object reference not set to an instance of an object. EDIT: I rebooted my PC and it remuxed fine. Last edited by odin24; 18th October 2008 at 14:35. Reason: Problem Fixed |
1st November 2008, 03:26 | #1254 | Link |
If anybody has experience on joining 'mts' files and converting it to 'ts' file ?
My Panasonic HDC-SD9 generates 'mts' video files after every 'start/stop' recording. There can be 40-60 'mts' files for one hour records and I wish to merge all of them in a single file to facilitate management. I have tried 'tsMuxeR v.1.8.8b' and 'tsSplitter v.1.0' to join the 'mts' file and convert it to 'ts' format by 'tsRemux v.0.0.21.2'. The output file can be played but it will hang-up at every joint of video clips. However, the video can be continued to next joint after I press 'stop' and 'play' again. There are some optional settings at 'tsRemux v.0.0.21.2' like the 'Use async I/O' and 'Bypass Audio Alignment' but I do not know its exact function. Is there any new version of 'tsRemux' ? Is there any other freeware that can merge / join 'mts' files and convert it to 'ts' file directly ? |
2nd November 2008, 02:26 | #1255 | Link |
Split by size e.g. 4GB
Anyway to get TsRemux to write a Bluray structure, but limit the .m2ts file size to 4GB - so several chunks to make up a typical movie)
(tsMuxeR allows the 4GB chunks, but cant do TrueHD as well as TsRemux) any ideas Jeff |
5th November 2008, 00:07 | #1256 | Link |
Hi I have the Popcorn Hour B-110. With TSmuxer DTS-HD works realy fine but with TSRemux TrueHD doesnīt the same.
I have one movie without any problems: Cloverfield. I can play every Audio Stream I want and switch any time...I also can make a time seek. I have real problems iwth "I am lagend" "Hancock" and other TrueHD Movies. Mostly the TrueHD works if I switch to it at the beginning of the movie, but I should not change the audio Stream after that. If I do that, TrueHD is gone. ALso I can not jump to another moment without losing TrueHD. What is wrong? - What is the best way to remux a mainmovie m2ts: m2ts?ts? which settings with audio Alignment and asynch I/O? - Since TSRemux canīt handle BR-Playlists I have to Mux/Join same Blurays (like Cars and Hancock) with TSmuxer bevor handling it in TSRemux. Which is the best way here? Whoch destination file in TSmuxer and which settings in TSRemux while remuxing this TSmuxer-File?! IS THERE ANY OTHER WAY to join multiple m2ts Files, without the lags, that TSmuxer is doing to the TrueHD Streams?! Thanks, Greetings Michael
Popcorn Hour B-110 Onkyo TX-SR 805 Last edited by flyingernst; 5th November 2008 at 00:48. |
8th November 2008, 18:46 | #1257 | Link |
Created m2ts by TSMuxer (includig thd+ac3 demuxed by eac3to) can no be remuxed as BD by TSRemux while it can be remuxed as m2ts-works on Graph- i get this error: Here is the sample thd+ac3: http://www.mediafire.com/?sharekey=6...d9c5c0b2214fdd EDIT: This is carried from eac3to thread/and deleted there/ since madshi told it is not related with his thread. _ _ _ _ __ Last edited by rica; 8th November 2008 at 19:13. |
20th December 2008, 15:33 | #1259 | Link | |
use 'r'
27th March 2009, 16:45 | #1260 | Link |
heres two mirrors
http://x264.nwgat.net/TsRemux/0.21.2/TsRemux.exe http://x264.nwgat.net/TsRemux/0.21.2...ux.exe?torrent http://x264.nwgat.net/TsRemux/0.21.2...x0.21.2src.zip http://x264.nwgat.net/TsRemux/0.21.2...rc.zip?torrent
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview) "Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat Last edited by wiak; 27th March 2009 at 16:54. |
