Old 2nd January 2016, 15:35   #821  |  Link
jihyo
Originally Posted by jihyo View Post
But it doesn't work for Potplayer 32 with AviSynth+
http://avisynth.nl/index.php/AviSynth+#Downloads
NOTE:
1) It doesn't works with AviSynth+ r1825 (March 23, 2015) but works with AviSynth+ r1779 (March 17, 2015)
So yeah I got 60 fps in Potplayer 64 bit
2) We have to use AviSynth with MT enabled otherwise it would be useless (low perfomance)
For "AviSynth 2.58/2.6 MT" MT is already enabled in Potplayer's original scripts
but "AviSynth+" has different functions for MT: http://avisynth.nl/index.php/AviSynth+#MT_Notes
jihyo is offline   Reply With Quote
Old 18th August 2016, 19:38   #822  |  Link
real.finder
I build GetSystemEnv for avs 64
no source change, just make c++ 6.0 project workspace by Microsoft Visual Studio 6.0 in winxp then open it in Visual c++ 2008 in win7 and update and convert project to c++ 2008, and last, open c++ 2008 project file in vs2012 and update the project and build it in x64 with avs 2.5 x64 header
http://rgho.st/6F54dcFcd
edit: I build LoadDll too now
http://rgho.st/89sqKfBpg
See My Avisynth Stuff
Old 18th August 2016, 23:58   #823  |  Link
ultim
AVS+ Dev
ultim's Avatar
Can somebody verify this with a recent Avs+ (preferably r2085)?
If this problem still persists, I'm willing to look at it and provide a fix.
AviSynth+
ultim is offline   Reply With Quote
Old 14th December 2016, 08:14   #824  |  Link
real.finder
another x64 filter
made it for my mod of MotionRamp
Old 16th August 2021, 11:00   #825  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by real.finder View Post
another x64 filter
Can you share 32bit version of this plugin?
VoodooFX is offline   Reply With Quote
Old 16th August 2021, 11:47   #826  |  Link
kedautinh12
If you use avs is 2.6 or up, you can use Average to replacw
Old 16th August 2021, 15:28   #827  |  Link
real.finder
you can find it here https://web.archive.org/web/20201020...asmsasham/soft
