Old 15th February 2011, 16:49   #301  |  Link
-Vit-
Of course, you're supposed to use mt_masktools-25.dll for 2.58MT. But I've heard this story before, the other way round - needed to use mt_xx-25.dll when using 2.6MT. There's only one rule to get best MT avisynth stability - try every version of everything.
I assume you've tweaked the thread counts. I often find > 8 is best for SetMTMode at "Slow" (I use as high as 14 in some cases), and recently I've noticed better results with EdiThreads lower (4 or less). However, these values will likely vary widely with different systems.
The output resolution is a little unusual (5:3), but I can't tell you what is correct though - depends on the source and how you intend to encode it / what you are using it for.
-Vit- is offline
Old 15th February 2011, 17:42   #302  |  Link
@MeGui
Then what res. should i use to get nice 16:9 as final PAL video?
This is my input:
Video
Format : DV
Format_Commercial_IfAny : DVCPRO
Codec ID : dvsd
Codec ID/Hint : Sony
Duration : 46s 320ms
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Stream size : 159 MiB (95%)
Encoding settings : wb mode= / white balance= / fcm=auto focus
Should i add SelectEven()?
p.s. i'll keep current treads..works nice so far ))
Tnx again mate
@MeGui is offline
Old 15th February 2011, 17:50   #303  |  Link
pokazene_maslo
Do you have any ETA when will be chroma planes denoising supported?
pokazene_maslo is offline
Old 15th February 2011, 19:04   #304  |  Link
sadie
I've uploaded that miserable little 3 second clip.
http://rapidshare.com/files/448099289/Arg.avi
Yesterday I got the error with a sourcematch 25p test, so there goes that theory down the drain. I will try your new update tonight along with newly installed setMT. SetMTmode (5,4)>DirectShowSource>SetMtmode (2,4) sound OK for my core duo? Or perhaps down a notch. Since x264 has its own multi-thread settings I've wondered if there might be some interference going on there? Or should I even just go back to standard two-pass mode and forget about CRF. Lossless will have to wait for the next project and new hard disk.
I also want to reiterate that when my bug rears its head, it can just as easily disappear in the next sequence if there's adequate movement going on. I believe that Didee even mentioned straight out somewhere on this thread that TGMC wasn't ever made for static scenes? Or is that to be nuanced?
sadie is offline
Old 15th February 2011, 19:09   #305  |  Link
-Vit-
@@Megui: I'm sure there are many threads here about resizing. I work with NTSC material, SD at 720x480. I don't resize, instead encode as anamorphic 16:9 and let the player do the resizing. This keeps the original detail and doesn't bloat the final encode size, but relies on the player's resizers. I imagine a similar process would would work for you, but you'll have to find out for yourself. If you really want to explicitly resize, then 1024x576 would lose no vertical detail, but the encode will be somewhat larger.
Use SelectEven if you want a 25fps result. It's close to film rate and some people prefer that look. It can make for a smaller and quicker encode than 50fps. However, a 25fps result can look juddery depending on the source. You could use the new motion blur feature to help with that (in which case you don't use SelectEven, you set FPSDivisor=2 in QTGMC, along with the motion blur settings). Motion blur will slow the encode, but might reduce filesize a little.
____
@pokazene_maslo: Chroma/pixel format features are next on my list (as long as I don't go off on a whim as I just did with the motion blur). But currently I'm looking at Avisynth itself, in particular the caching, which is starting to become a serious stability problem with more complex settings. I'm also busy with several other projects. So I don't currently have an ETA, although I am quite active with QTGMC at the moment...
-Vit- is offline
Old 15th February 2011, 19:15   #306  |  Link
-Vit-
@sadie: DirectShowSource: Can be problematic, could explain any number of ills. I've seen strange ghosting with it sometimes. Try FFVideoSource?
EDIT: This might be a source filter issue. Comparing DirectShowSource to FFVideoSource on this vid, no other processing. FFVideoSource shows some horizontal lines - under the fountain and red mark in the first 4 or 5 frames, DirectShow has some flickering in that bright area but nothing so problematic. However, that was all. [DSS2 matches DirectShowSource, but it got the parity wrong and I had to use ConvertToYV12 - is there a DSS2 setting to set a preferred pixel format?]
Encoded both directly to MKV and via lossless, no other visual issues apart from that odd difference despite running several versions testing source accuracy. As expected, the most accurate to the source was:
QuickTGMC( Preset="Slower", SourceMatch=3, Lossless=2, Sharpness=0.1 )
EDIT2: Here's the result from the above line (x264 in MKV).
[I've reupped a cleaner version done with new v3.11]. I went for source accuracy. Everything was done with 10 main threads and 4 EdiThreads.
-Vit- is offline
Old 16th February 2011, 00:23   #307  |  Link
wOxxOm
Oz of the zOo
I wonder how do I set qtgmc parameters to avoid ugly artefacts in static fades from/to black like these: qtgmc vs daa - changing Preset or SourceMatch=1/2/3 do not help...
wOxxOm is offline
Old 16th February 2011, 00:53   #308  |  Link
Didée
Post your script. It's not clear what exactly you are doing there. In particular, since it seems you're actually doing IVTC ....
Fades generally are problematic. As far as MVTools are concerned, try different DCT modes - they can help to get better matches. (For some fun, try blocksize 16 together with DCT 1. No, nothing is broken ... it *IS* *THAT* slow. Really.)
But even then, it's still a fade ...
Didée is offline
Old 16th February 2011, 01:07   #309  |  Link
wOxxOm
Oz of the zOo
IVTC(TFM) is a nonfactor here, it was used for debugging purposes, the script is plain simple:
DGDecode_mpeg2source("dvd1.d2v",info=3)
QTGMC( preset="very slow", SourceMatch=3 ).selectEven()
I've tried blocksize=16 & dct=1 (it was sloooooow) - slightly better (picture was kinda posterized/banded but without previously seen ghosting/blending artefacts), anyway it is far from being as clean as daa(), then avisynth hanged when I added sourcematch=3. Seems like I have to find manually every little fade throughout the whole movie.
wOxxOm is offline
Old 16th February 2011, 01:35   #310  |  Link
Didée
Darn fades. Well ... if it was about TGMC, you could set low SAD thresholds like thSAD1=64,thSAD2=32, which probably would solve the problem. In QTGMC, those aren't exposed anymore.
May I ask what you're trying to achive, at all? For most Anime-content scenarios, Q/TGMC isn't the most-suited-filter-of-all, anyway.
Didée is offline
Old 16th February 2011, 03:00   #311  |  Link
DVDBob
Which interlace method, can this filter deinterlace??
DVDBob is offline
Old 16th February 2011, 06:06   #312  |  Link
-Vit-
Oops... I introduced a nasty bug in v3.05. The final couple of core algorithm stages were being skipped over including the final smooth, which left the output noisy. Fixed in the OP (v3.11). If you have version 3.05 or 3.10, you really need to update to v3.11 as it was a serious bug. Sorry for the inconvenience.
Dunno if that was partly causing wOxxOm's problem (although Didée's points still hold regardless). Don't think it caused sadie's smears, the bug caused noise.
____
Given the above posts, I have allowed control over thSAD1, thSAD2, thSCD1 and thSCD2 (which are the same as TempGaussMC_beta2):
- ThSAD1/2 control how willing the temporal smooths are to blend with the neighbor frames. Increasing these values will increase smoothness, but can also can cause blurring or smearing. Conversely, reducing these values can reduce ghosting, or the blurring of high-speed temporal changes, but may leave shimmer or noise. In any case, they should be used rarely, and ThSAD2 is safer to use than ThSAD1.
- ThSCD1/2 control scene change detection. Again only change them if you must (read the MVTools documentation for details).
QTGMC( Preset="Slower", TR2=2, ThSAD2=400 ) # Smoother but might smear...
Defaults are: ThSAD1=640, ThSAD2=256, ThSCD1=180, ThSCD2=98
____
DVDBob: I'm not sure I understand, what other interlacing methods are there?
-Vit- is offline
Old 16th February 2011, 08:22   #313  |  Link
SubJunk
Hi -Vit-, thanks so much for this script! It is really great.
Also thanks for keeping it updated.
I have what is hopefully a quick question
I have an interlaced video at 706x480 which I want to resize to 706x528.
I've noticed that doing the resize before calling QTGMC produces better results than afterwards (it is a cartoon, so some of the lines connect up better this way) but then there are fat horizontal lines every 5 frames which aren't there if I resize after QTGMC (I attached a screenshot to show it)
I did of course expect that something wrong would happen if I resized it beforehand but I was curious if the interpolation would like the extra resolution - which it did.
So my question is: Is there somewhere I can put the resize line in your script so it will work properly?
The script I used for that screenshot is (with irrelevant things removed for clarity):
PointResize(706,528)
QTGMC()
SubJunk is offline
Old 16th February 2011, 10:06   #314  |  Link
kypec
User of free A/V tools
kypec's Avatar
QTGMC()
Changing vertical resolution before the frame(s) were deinterlaced is plainly wrong. No deinterlacer can reliably re-construct the frame that had its fields resized vertically. Period.
kypec is offline
Old 16th February 2011, 10:30   #315  |  Link
wOxxOm
Oz of the zOo
I always use it as clip2 for tfm with pp=4, and sometimes for scrolling credits without tfm.
wOxxOm is offline
Old 16th February 2011, 10:49   #316  |  Link
SubJunk
Maybe you should read the whole post before replying
I did of course expect that something wrong would happen if I resized it beforehand [...] Is there somewhere I can put the resize line in your script so it will work properly?
Last edited by SubJunk; 16th February 2011 at 10:51. Reason: Clarified in case he misses it again
SubJunk is offline
Old 16th February 2011, 11:16   #317  |  Link
Gavino
Avisynth language lover
Any vertical resizing must be done after deinterlacing.
Why are you using PointResize? That is almost bound to introduce artifacts.
Gavino is offline
Old 16th February 2011, 11:30   #318  |  Link
SubJunk
I was using Spline36Resize but I changed it in the post to the most simple one in order to avoid comments about which resizing filter is better
I obviously worded my first post in a confusing way, I'll try again. Hopefully this is clearer:
I've noticed that doing the resize before calling QTGMC produces better results than afterwards (it is a cartoon, so some of the lines connect up better this way) but then there are fat horizontal lines every 5 frames which aren't there if I resize after QTGMC (screenshot here)
I did of course expect that something wrong would happen if I resized it before the deinterlacing but I was curious if the interpolation would like the extra resolution - which it did.
So my question is:
Is there somewhere I can add a resize line to your script - after deinterlacing but before the interpolation and postproc - so it will work properly?
Spline36Resize(706,528)
QTGMC()
SubJunk is offline
Old 16th February 2011, 12:26   #319  |  Link
Gavino
Are you sure your source is really interlaced?
A glitch every 5 frames suggests that it is telecine material and should be IVTC'd rather than deinterlaced.
Gavino is offline
Old 16th February 2011, 12:57   #320  |  Link
DVDBob
____
____
What I mean is that there are some movies that are just interlaced, other films are partially interlaced, hybrid interlaced etc.
DVDBob is offline
