Old 5th September 2010, 14:32   #641  |  Link
Midzuki
Unavailable
Midzuki's Avatar
This time MasterNobody was faster than Komisar.
Also, for the time being, Komisar's site is down
(or unreachable) :-/
EDIT: Actually, there is some problem between my crappy ISP
and komisar's web site, I've managed to access komisar.gin.by through a public proxy server.
Midzuki is offline   Reply With Quote
Old 24th January 2011, 20:33   #642  |  Link
komisar
komisar's Avatar
[2011-01-24] added new command-line options for vfw r1867
Specify RGB to YUV conversion logic (not important if input is already in YUV)
--input-csp-rec ["bt601"|"bt709"] (default "bt601")
--input-csp-scale ["tv"|"pc"] (default "tv")
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 24th January 2011, 23:43   #643  |  Link
J_Darnley
J_Darnley's Avatar
Why wouldn't you use the existing --colormatrix and --fullrange options for that?
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 25th January 2011, 09:30   #644  |  Link
komisar
komisar's Avatar
--colormatrix and --fullrange mark output stream
--input-csp-rec/--input-csp-scale convert input stream from host app
Old 25th January 2011, 11:26   #645  |  Link
J_Darnley
J_Darnley's Avatar
Yes, so if you ask for --colormatrix rec709 --fullrange on with RGB video, you will get TV range 601. Nice work.
Old 25th January 2011, 17:56   #646  |  Link
komisar
komisar's Avatar
J_Darnley, "--colormatrix rec709 --fullrange" you known what you do... and yes, you get 601-tv marked as 709-pc...
but with "--input-csp-rec 709 --input-csp-scale pc" you get RGB->YUV converted as you expected marked as "undef"...
"--input-csp-rec 709 --input-csp-scale pc --colormatrix rec709 --fullrange" converted and marked as 709-pc...
This is a "quick-fix" and may changed (maybe using "--colormatrix rec709 --fullrange" for RGB->YUV conversion indicator is better?)
What is better?
P.S. Prior this changes you always get RGB->YUV converted as 601-tv....
Old 26th January 2011, 13:13   #647  |  Link
Midzuki
Unavailable
Midzuki's Avatar
What ?????
This time, komisar was faster than Jarod
r1881 @ komisar.gin.by
EDIT:
r1882 released on 2011/01/27 O_o
UPDATE:
r1884 released on 2011/01/31
Old 8th July 2011, 18:11   #648  |  Link
colinhunt
May I ask that komisar and MasterNobody take a look at Peter Wimmer's "MVC to AVI Converter" (http://3dtv.at/Downloads/Index_en.aspx) and please try to figure out why it doesn't work with either implementation of x264vfw?
colinhunt is offline   Reply With Quote
Old 9th July 2011, 10:11   #649  |  Link
MasterNobody
colinhunt
You better readdress this question to Peter Wimmer because this utility doesn't work with most of encoders (both vfw and DirectShow) which I tried so this is not x264vfw specific.
MasterNobody is offline   Reply With Quote
Old 10th July 2011, 00:07   #650  |  Link
colinhunt
Originally Posted by MasterNobody View Post
colinhunt
Thank you for your reply; I will contact Wimmer.
Old 14th March 2013, 17:07   #651  |  Link
Rumbah
Does anyone know if there is a current version of x264vfw that supports the preset/tune system?
I only found Komisars build and while using the latest x264 version it is horrible ot configure as you have to set every option by hand. And Masternobody's build does not use the latest x264.
x264 full help - x264 --fullhelp r2345
Cuttermaran HCEnc provider - Support for HCEnc in Cuttermaran
DualDVDRB - Dual core support for DVD-RB free
Rumbah is offline   Reply With Quote
Old 17th March 2013, 18:40   #652  |  Link
MasterNobody
Rumbah
I have updated my builds today. Enjoy.
Old 17th March 2013, 18:54   #653  |  Link
Rumbah
Thank you very much!
This way I can quickly determine the matching setting for realtime recording pretty comfortable instead of clicking through all the options by hand.
Old 16th September 2013, 12:00   #654  |  Link
Makaveli84
I'm not sure if this is the place to make such a request, but then again, I'm not sure where else, so here goes:
I use komisar's version, and it seems I can only get rclookahead and mbtree enabled (even in CRF mode for example) through the command line, which would defeat the purpose of using this version for its GUI and ability to set individual settings through it instead of the command line.
Bottom line, komisar, please include the mbtree and rclookahead settings in the GUI (even if for some reason, you wish to leave mbtree disabled by default for all rate control methods.
Makaveli84 is offline   Reply With Quote
Old 16th September 2013, 14:27   #655  |  Link
komisar
komisar's Avatar
i plan to refactor gui for vfw... but not so fast... all option will be included in it...
Old 16th September 2013, 17:20   #656  |  Link
Makaveli84
Would it be possible meanwhile (until the new GUI is ready) to enable mbtree by default (at least for CRF mode) in an update release?
