Old 25th November 2006, 14:47   #201  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
exactly. also b-pyramid can be used only for 2 or more b-frames. Otherwise the codec will ignore it.
But as i said, to avoid delays or desynchs, keep the number of Bs as low as possible or dont even use them.
Old 25th November 2006, 18:37   #202  |  Link
DeathTheSheep
<The VFW Sheep of Death>
DeathTheSheep's Avatar
...Or delay audio by (Num of B-frames)*(fps).
Or more simply: Add ~25ms (or 30, or whatever your framerate is) for each B-frame you are using. But really, it isn't that necessary-- x264's lag in AVI is hardly noticeable in most cases. And as ST said: Use a fewer number to be safe.
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds!
DeathTheSheep is offline   Reply With Quote
Old 25th November 2006, 21:20   #203  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
And in most cases there is not any lag.
shon3i is offline   Reply With Quote
Old 25th November 2006, 23:22   #204  |  Link
DeathTheSheep
Precisely.
Old 26th November 2006, 04:07   #205  |  Link
squid_80
Delay audio by (Num of B-frames)*(1/fps). E.g.:
For NTSC Film (23.976fps) frame duration is ~41.7ms
For PAL (25fps) frame duration is 40ms
For NTSC TV (29.97fps) frame duration is ~33.36ms
squid_80 is offline   Reply With Quote
Old 26th November 2006, 12:25   #206  |  Link
akupenguin
x264 developer
akupenguin's Avatar
6) have I-Frames in coincidence with IDR Frames
Or just not set the keyframe flag on non-IDR I-frames, just like you do in any other container. If keyframes are set incorrectly, that's just a bug in x264vfw, not a limitation of VfW.
Originally Posted by Sharktooth View Post
3) works but it's a hackery... also do not set too much reference frames when trying to use this option...
Number of reference frames has nothing to do with any of the limitations of VfW or AVI. The fact that you can use multiple reference frames is what promped H.264 to distinguish between I-frames and IDR-frames. But if you treat keyframes correctly, then it doesn't matter to AVI whether you use 1 ref or 16. And B-pyramid exacerbates the general B-frame problems because it increases the amount of re-ordering, not because it adds referenced B-frames.
Old 26th November 2006, 14:09   #207  |  Link
GodofaGap
2) no, i meant what i said. the problem is avi doesnt like VBR streams.
For video this is absolute nonsense. Setting dwsamplesize to 0 means VBR in AVI and this works fine. There are no problems.
GodofaGap is offline   Reply With Quote
Old 26th November 2006, 14:30   #208  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
The problem is with editors, not players. For playback, avi just works, once the necessary changes are made to the splitters to seek properly.
However, avi editors are mostly dumb as rocks compared to directshow splitters like haali's and even microsoft's; virtualdub only just recently started supporting vbr, avidemux has for a long time, but premier, AE, aviedit, and all the other avi cutters and editors that I've used just freak out on vbr. Some crash, some output garbage, some timeshift like vdubmod, and so on. This is avi's legacy, and combining that wide support base with avi's loose specs gives a lot of interoperability problems.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 26th November 2006, 14:51   #209  |  Link
squid_80
If you put little effort into your avi importing functions and rely on the AVIFile API (which really shouldn't be a bad thing, it is part of win32 after all) you've got no hope when it comes to VBR audio.
Old 26th November 2006, 14:51   #210  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Use Avidemux and be happy
Old 29th November 2006, 20:56   #211  |  Link
DeathTheSheep
This is VBR audio we're talking about here, right? In terms of video, VBR has been supported since before VfW even came into existence. It practically MUST be VBR.
Anyways, DeathTheSheep United is now http://DeathTheSheep.Uni.cc
Fitting, isn't it?
Old 30th November 2006, 05:24   #212  |  Link
celtic_druid
celtic_druid's Avatar
If I recall correctly there was a modified version of avs2avi which could encode via x264 taking bframes into account.
celtic_druid is offline   Reply With Quote
Old 29th December 2006, 07:32   #213  |  Link
servass
I got "Can not Connect VidCompressor To AVIMux..." if I start capturing from tv-card with this x264?
I think I have vfw in use...
Another 264er (lead) run's without error, but on playing the captured video with vlc there is only black noise ...
Has someone a suggestion?
servass is offline   Reply With Quote
Old 19th April 2007, 06:55   #214  |  Link
snow_xmas
snow_xmas's Avatar
There are many missing in x264vfw encoder. The original version confused "bitrate variability" with "qcomp". it said that if you change the "bitrate variability" to 100, the qcomp will be "1.00". And the "ratetol" is 4.00 forever whatever is set in "bitrate variability".
And "Const Quality" is important too. So I think the source of vfw requires to update.It is not enough that adding "fast p skip" and "DCT Decimate" only. Can the VFW encoder has all of options in MeGUI?
snow_xmas is offline   Reply With Quote
Old 19th April 2007, 12:54   #215  |  Link
Irwin
And "Const Quality" is important too. So I think the source of vfw requires to update.It is not enough that add "fast p skip" and "DCT Decimate" only. Can the VFW encoder has all of options in MeGUI?
For me x264vfw is best way to encode in h264. DeathThe Sheep when new version?
Irwin is offline   Reply With Quote
Old 21st April 2007, 12:02   #216  |  Link
snow_xmas
snow_xmas's Avatar
I have built the newest x264 vfw encoder. Some options what is not in vfw before have been added. And the logo of "x264" have been removed by me because it is a waste of space and useless.
But I can't assure it have no bug. Anyone Who want it may tell me your email and I will post the source and the install package to you.
Let's keep x264 vfw together!
Old 21st April 2007, 18:55   #217  |  Link
dtomoyo
hi ^^ i need new x264vfw
e-mail: dtomoyo at empal.com
sorry, wrong email address. ^^;
dtomoyo is offline   Reply With Quote
Old 21st April 2007, 20:17   #218  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
email: akostic5 at yahoo.com
Thank you.
Live long and prosperLive long and prosperLive long and prosper
Romario is offline   Reply With Quote
Old 22nd April 2007, 01:41   #219  |  Link
plane
Email: ultima0 at yahoo.com
plane is offline   Reply With Quote
Old 22nd April 2007, 10:48   #220  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
@snow_xmas: Why not just upload your packages to some webhost somewhere and post a link here ? Megaupload or others (not rapidshare plz) are sufficient for that sort of thing, and I bet your ISP offers a small webspace where you can upload your stuff too.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
