Old 7th January 2015, 02:03   #661  |  Link
Bloody
Originally Posted by Dean007 View Post
I do have a problem! In v1.50b5 when I try to rip subtitles (idx) I get this, and for every single letter
In 1.50b7 same subtitles I get this
Any suggestions?
Try to un-check the "Use IDX's file offsets" checkbox in the "Global Options" dialog. I bet you had that already done in the old version.
Btw: you may import (copy) your SubRip.ini from an older version to the installation folder of a new SubRip version, to preserve your previous settings.
Bloody is offline   Reply With Quote
Old 1st March 2015, 07:49   #662  |  Link
Sven Bent
My server is up and running again so my matrix file can be downloaded
http://162.248.14.188/
remember to set you "Sensibility on character difference" to 1000
If you do spanish subtitles you need to lower "Max. Character Top Diff." to 2
Sven Bent is offline   Reply With Quote
Old 1st March 2015, 20:03   #663  |  Link
Xebika
Will the setting of "Max. Character Top Diff." for spanish subtitles be the same for danish subtitles??
Xebika is offline   Reply With Quote
Old 5th March 2015, 00:25   #664  |  Link
Sven Bent
No. The Max. Character Top Diff." is only to see the difference between the lower case "i" and the Spanish reverse exclamation mark ""
Old 5th March 2015, 00:41   #665  |  Link
Xebika
Ok thanks for the information.
Old 23rd March 2015, 02:52   #666  |  Link
Sven Bent
just some small info update.
Ive noticed a few subtitles where the lowered "Max. Character Top Diff." would help resolves issues i with capital vs lowercase . its very few but if you run into that issues you might wanna reduce "Max. Character Top Diff." to 2 on other languages than Spanish.
i personally runs mine on 2 most of the time but I'm a bit over cautious
Old 22nd April 2015, 18:55   #667  |  Link
Sven Bent
My ISP gave me a new IP again.
Currently my matrix file can be found here
it haven't been updated for month's as i have been busy with other projects
Old 4th August 2015, 03:16   #668  |  Link
Sven Bent
Just an update if people are still using my matrix file.
i finally got my domain up and working so no more dead links when i get a new IP
Website: http://www.techcenter.dk
Direct Link: http://techcenter.dk/SBmatrix.sum
