Old 17th March 2010, 20:39   #201  |  Link
VincAlastor
I probably don't need a 64 bit OS to make the build. But I do need someone with 64-bit expertise to tell me how to make such builds. I have never made a 64-bit anything.
i hope there is an expert. don't be angry about me, i think you could understand me, that i wish a x64 version of your modern source filters
i'm not a programmer, but i'm a good tester
VincAlastor is offline   Reply With Quote
Old 17th March 2010, 20:40   #202  |  Link
I'm not angry! I'll be happy to make a 64-bit build if someone is willing to educate me about it.
Old 17th March 2010, 21:18   #203  |  Link
JoshyD
@neuron2
You can compile 64bit binaries without a 64bit operating system, you just can't test them without a 64bit computer/os The ease of porting the build will depend on how much it relies on assembly language, always considering pointers as the same length as an int, etc. If you want to try, I can find you some good reading material.
Also, isn't dg nv tools written in CUDA? I'm not super-familiar with compiling it, is it done via a custom NVIDIA compiler? If that's the case, and it only uses NVIDIA specific language references (I know CUDA is C like, or something) then it may be as easy as changing your compile target architecture to x64.
A little background info on how it's written, and I think I can get you going . . .
@Audionut
That error (the MT plugin is written in russian originally, I think?) usually happens when something goes wrong in the script you're trying to invoke. Syntax error, filter not loaded, something little is missing. That's really the only place in the code I see that error, so I don't know what to tell you. Something's throwing an exception in your chain.
@osgZach
Thread deadlock should be resolved by tonight. I'm pretty sure it's a result of me giving the compiler free reign to add parallelism where it *thinks* it is safe. I think I've mentioned this in an earlier post, compilers are stupid, I shouldn't have trusted it, but oh well. I can thread it all by hand eventually, but that's not my main concern. I'm working on some performance tweaks here and there that should make everyone smile.
JoshyD is offline   Reply With Quote
Old 17th March 2010, 21:45   #204  |  Link
Sure, please do. There is no assembler in the DLLs and just some basic stuff in DGIndexNV for chroma upsampling.
No. It uses the CUVID API.
See above.
Old 17th March 2010, 23:13   #205  |  Link
osgZach
Joshy, cool will look forward to testing when it's released.
Also, just wanted to say, I know we all have problems with the build but don't let our whining control when you release updates or how often you work on it. I know how easy it is to get burned out on something you start out doing because you want to. I'd rather download an update a week later than a hastily put together crowd pleaser
In other news.. I've gone back to using MT("filter") as I appear to have solved the overlap issue by cranking it up to 12.. Which I was initially afraid to do because I thought it would actually overlap the sections to the point where actual data started dissapearing.. It seems to work though, I will be comparing it against other encodes made without MT("filter")..
It is interesting to note, that I can actually use my PC for web browsing and other tasks when using MT("filter") - as opposed to SetMTMode which makes the entire thing slow down to a bog crawl. Even though performance is roughly the same (although MT("filter") seems a bit faster ).. Any reason why that is? And would it be reasonable to expert SetMTMode in the future to not bog down the PC completely even when using all cores?
osgZach is offline   Reply With Quote
Old 18th March 2010, 04:55   #206  |  Link
levi
SetMTMode doesn't bog down my PC. if you are getting weird behavior, i suggest you look in to:
limit # of threads - SetMTMode(2,x) - x = threads
limit max memory - SetMaxMemory(512)
try regulator()
post your script
levi is offline   Reply With Quote
Old 18th March 2010, 14:44   #207  |  Link
paulvdb
Only the DLLs have to be 64-bit because they have to be loaded by 64-bit avisynth. You can still use the 32-bit indexer. At least that's how squid80 did it with DGMPGDec.
paulvdb is offline   Reply With Quote
Old 18th March 2010, 15:47   #208  |  Link
osgZach
Levi, I will if I have problems in the future. But for now I'm content that its working the way I have it.
The only time SetMtMode didn't bog down the PC was when trying out the x32 builds w/MT. And performance was not really better than single threaded either for the most part, although I saw occassional spikes past 50 under task manager.. Maybe I just have a goofy install of Windows going on, or something like that..
But if its working under MT("filter") then that is OK for now.
re: DGindex/NV, The indexer itself runs fine as a 32bit app, its the decoder DLL's that have to be 64bit, and they will have no problems loading the index file as its just a basic text file after all.. Squid's x64 release is just the Dgdecode.dll compiled for x64.
Old 18th March 2010, 17:52   #209  |  Link
Hiritsuki
Novice of AVS
I just waiting tnlmeans x64 ver.
and it's release I change use X86 MT to X64 MT
My PC
Hiritsuki is offline   Reply With Quote
Old 19th March 2010, 18:21   #210  |  Link
ifb
I have a 1080i MPEG2 source that I deinterlace and resize to 512x288.
Vertically resizing to anything less than 720 causes crashes. BilinearResize() did not crash, but every other resizer did.
Using the latest Intel build from the top post on an i7 920.
SetMemoryMax(512)
Global NewHeight = 288
Global NewWidth = 512
SetMTMode(5)
Vid = MPEG2Source("file.d2v")
Aud = wavSource("file.wav")
SetMtMode(2)
AudioDub(Vid,Aud)
Spline36Resize(NewWidth,NewHeight)
ifb is offline   Reply With Quote
Old 19th March 2010, 19:52   #211  |  Link
osgZach
It doesn't look like your initial SetMTMode call specified the number of threads, try (5,0). You might even be able to get away with Mode 2.. There seems to be conflicting opinions about whether it works properly under any mode less than 5.
Is your input clip progressive? You shouldn't be resizing before a deinterlace also, and I don't know if trying to resize an interlaced clip would mess up MT either ?
You could also try resizing before your Dub operation ?
Old 19th March 2010, 20:22   #212  |  Link
ifb
Doesn't change anything. I've never had to specify thread number, even with vanilla avisynth.
Not setting mode 5 before DGSource reduces speed dramatically, even when changing to mode 2 later in the script.
It's 1080i, like I said. I removed the deinterlacer for simplicity. I can resize horizontally all I want, just not vertically to a value less than 720.
Normally (32-bit) the script would be:
Spline36Resize(NewWidth,height,8,0,-8,0)
Yadif()
Spline36Resize(width,NewHeight,0,-4,0,-4)
Leaving SetMTMode() out completely, causes virtualdub to get green frames instead of crashing completely on open.
Old 19th March 2010, 20:49   #213  |  Link
osgZach
Are you using the newest compile of Dgdecode? (1.5.8)
Don't know if it matters, but not all the iDCT modes work, could that be causing an issue?
That's about all I can think of really. I don't have any HD source files to play with.
Old 19th March 2010, 21:06   #214  |  Link
ifb
Downloaded today.
No, because then it wouldn't decode anything (or the output would be trash).
It's very simple. Resize height<720 using lanczos, spline, or bicubic -> crashes virtualdub and avs2avi.
OS is Win2k8 Server 64-bit.
I should be thorough and try an older build (prior to the vertical resizer using SSSE3).
<edit>
The 3-1-2010 build works fine.
Old 19th March 2010, 23:53   #215  |  Link
JoshyD
I think your resize problem is really my fault . . . I noticed I rolled back to an older version of the resample function source when releasing that build. If you could try my latest compile, I'd appreciate it. Let me know if it's still crashing so I know if I need to delve deeper into the matter.
@neuron2
This details the differences between x86 and x64. The main thing to watch out for is any assembler that assumes a certain calling convention. In x64, instead of parameter passing on the stack, you get the first four "integer" (pointers, shorts, whatever) in rcx, rdx, r8, and r9. The first four floating point typed arguments are passed in xmm0-xmm3 (I think). There is shadow space created on the stack where you would normally find these variables, but don't go looking there for them. It's just garbage memory to start with, unless you explicitly store the parameter there for later use. Also, all variables on the stack are aligned to 64bits. So, even though int types should take 4 bytes on your stack, 8 are actually allocated. However, when reading these from memory, you can't read all 8 bytes, only the first 4 contain useful memory.
;void mmx_merge_luma( unsigned int *src, unsigned int *luma, int pitch, int luma_pitch,int width, int height )
; parameter 1(src): rcx
; parameter 2(luma): rdx
; parameter 3(pitch): r8d
; parameter 4(luma_pitch): r9d
; parameter 5(width): rsp + 40
; parameter 6(height): rsp + 48
in this example, getting from memory would look like:
mov eax, DWORD [rsp+40]
You can't do this:
mov rax, QWORD [rsp+40]
Because bytes 44-47 are garbage. It's the little things you have to get used to.
There are some other oddities, like whenever an extended register is used, a REX prefix accompanies the opcode. If you want to use an extended register (r8-r15) as a counter, dec and inc always treat them as 64bit values, even when specifying:
dec r8d
or
inc r9d
You still get a 64 bit add, which is slower.
Volatile registers:
rax
rcx
rdx
r8
r9
r10
r11
Non volatiles:
rbx
rbp
rdi
rsi
r12
r13
r14
r15
XMM0-XMM5 are volatile, XMM6-XMM15 are non-volatile.
If your compiler supports 64bit binary compilation, then your shouldn't have a problem just taking the source and compiling it as is.
Watch out for MSVS's compiler, it takes away inline asm when compiling for x64.
Old 20th March 2010, 04:47   #216  |  Link
squid_80
64-bit adds/subs aren't slower, that's the whole point of having a processor that uses 64-bit registers.
squid_80 is offline   Reply With Quote
Old 20th March 2010, 06:55   #217  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
I can confirm that I experience "Avisynth: unknown exception" when resizing 1920x1080 to 704x396 with Spline36Resize, using the latest Intel build. 1920x1080 -> 1280x720 -> 704x396 works.
Stephen R. Savage is offline   Reply With Quote
Old 20th March 2010, 15:43   #218  |  Link
JoshyD
My bad on the inc, dec instructions, I thought I had read something in the Intel docs about them, it was actually that some forms of them aren't supported. I think the instruction is encoding may longer when using the extended registers, regardless of which portion of the register you want to inc or dec.
The INC and DEC instructions are supported in 64-bit mode. However, some forms of INC and DEC (the register operand being encoded using register extension field in the MOD R/M byte) are not encodable in 64-bit mode because the opcodes are treated as REX prefixes.
There's also something about register dependency breaking (the whole register renaming in an out of order core thing) if you modify all the flags with an ADD or SUB rather than just an INC or DEC, I don't remember exactly what it is.
Edit: found it, from intel's optimization guidelines
Assembly/Compiler Coding Rule 32. (M impact, H generality) INC and DEC instructions should be replaced with ADD or SUB instructions, because ADD and SUB overwrite all flags, whereas INC and DEC do not, therefore creating false dependencies on earlier instructions that set the flags.
I'll look into why the resize is throwing an error. What color space is it giving the error in? I can't seem to get the crash in any color space . . .
Old 21st March 2010, 02:21   #219  |  Link
yo4kazu
64bit support so that you can do?
_GPU25.dll(source)
http://www.mediafire.com/?jdtmm2cjvrm
HLSLfile for HD48xx
original author:thejam79
GPU_001(binary&source)
http://www.avisynth.info/?plugin=att...le=GPU_001.zip
custom author:gpu25clone
_GPU25(binary)
http://www.avisynth.info/?plugin=att...nary_Rev53.rar
include filter on GPU sharder
(GPU_001)BilinearResize,ColorYUY2,Convolution3d,IT,LanczosResize,TemporalSmoother,WNR
(_GPU25)2DClean,2DCleanFake,Wavelet,HardwareResize,Blur,Sharp,HFlip,VFlip
yo4kazu is offline   Reply With Quote
Old 21st March 2010, 02:29   #220  |  Link
turbojet
JoshyD a few questions about the separate builds.
Does the amd build work on intel cpus? If so, is there a significant speedup of intel over the amd build on intel cpus? If not, any reason for separate builds? If so, do you want me to improve the install script to use amd dll for amd cpus and intel dll for intel cpus? If so, what will be the names of the 2 dll's?
Also I could make a self contained exe to install or use a typical installer but I'd have to inject new dll's every time, also typical installers are invasive in the registry. Maybe when the development slows down i'll look into it if you want.
