Old 16th December 2010, 01:35   #3421  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
it should be noted that for those that are doing comparisons of pthread-win32 threading against native windows threading that the windows threading takes different codepaths depending on the version of windows:
A) 2000/XP
B) Vista/7/(anything beyond this)
as such, comparing pthread-win32 against win32thread should take this into account.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 16th December 2010, 02:16   #3422  |  Link
aegisofrime
Any improvement no matter how small is welcomed
Thanks rack04 for the 64-bit builds. Neither x264.nl nor fushizen has them yet.
aegisofrime is offline   Reply With Quote
Old 16th December 2010, 02:23   #3423  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
A) 2000/XP
May I ask: What was the main motivation to implement support for native Win32 threads? Speedup? Getting rid of pthreads?
Old 16th December 2010, 02:53   #3424  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
pthread-win32 is LGPL, this causes a conflict with --disable-gpl x264 builds.
it was not done for performance reasons.
though since we were doing it, might as well use windows for all its worth when it's available (for vista+ platforms) so there might be a very small performance increase there.
[Edit]
the windows threading might be more important later when support for windows 7 x86_64's (and similar/later x86_64 platforms) way of handling systems with over 64 logical cores is added
(yes, microsoft totally made things a bit odd to extend support to 256 logical cores on the x86_64 systems starting with 7/server 2008 R2).
[/Edit]
Old 16th December 2010, 02:56   #3425  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
No it doesn't. Even a commercial x264 can link fine with LGPL libs.
It caused a conflict with a customer who didn't like LGPL libs
Old 23rd April 2011, 08:47   #3426  |  Link
upyzl
zj262144
upyzl's Avatar
Excuse me, is it still worth patching ME-prepass(#5) now? (or can the patch be available now? Of course manually -- ignore patch's line numbers)
Because of large changes in x264, I want to patch it myself manually
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14
Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated)
upyzl is offline   Reply With Quote
Old 24th April 2011, 04:08   #3427  |  Link
upyzl
zj262144
upyzl's Avatar
...and another question
Is ME prepass patch (rev 680, #1) the latest?
Old 21st July 2011, 05:43   #3428  |  Link
Kurosaki Ichigo
Kurosaki Ichigo's Avatar
Hi there, I'm new. I don't know if I'm writing in the right place. I have a problem with Lagarith Lossless Codec. I tried the 1.3.2.0 version and the last 1.3.2.5, but when the process finished, the output file is too small
This is the source RAW
General
Unique ID                        : 235762869933910293037496416019526284763 (0xB15E46EFE5A7B520951159776D4175DB)
Complete name                    : J:\[IM9 & FTF] RAW Anime\Freezing\[Yousei-raws] Freezing 01 [BDrip 1920x1080 x264 FLAC].mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 2.26 GiB
Duration                         : 23mn 41s
Overall bit rate                 : 13.6 Mbps
Encoded date                     : UTC 2011-04-02 07:30:50
Writing application              : mkvmerge v4.6.0 ('Still Crazy After All These Years') сборка от Mar 10 2011 02:50:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 23mn 41s
Nominal bit rate                 : 12.9 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.259
Writing library                  : x264 core 114 r1924 08d04a4
Encoding settings                : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=12860 / ratetol=1.0 / qcomp=0.65 / qpmin=9 / qpmax=32 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=30000 / vbv_bufsize=27000 / nal_hrd=none / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Language                         : Japanese
Audio
Format                           : FLAC
Format/Info                      : Free Lossless Audio Codec
Codec ID                         : A_FLAC
Duration                         : 23mn 41s
Bit rate mode                    : Variable
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Writing library                  : libFLAC 1.2.1 (UTC 2007-09-17)
Language                         : Japanese
And this, the output with Lagarith, in Full Processing Mode:
General
Complete name                    : J:\Freezing 01.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
Format profile                   : OpenDML
File size                        : 37.5 GiB
Duration                         : 23mn 41s
Overall bit rate                 : 226 Mbps
Writing application              : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                  : VirtualDubMod build 2540/release
Video
Format                           : Lagarith
Codec ID                         : LAGS
Duration                         : 23mn 41s
Bit rate                         : 226 Mbps
Color space                      : RGB
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 4.552
Stream size                      : 37.5 GiB (100%)
For what I know about Lagarith, this file size is too small. I don't know if I missed something when installed it. I have the last version of K-lite codec pack for 32 bit, on Windows 7 32 bit without SP1. Anyone Have an idea?
Kurosaki Ichigo is offline   Reply With Quote
Old 21st July 2011, 06:24   #3429  |  Link
@Kurosaki Ichigo
Please read and follow forum rules, especially rule 6 regarding downloaded files, torrents, etc. Further violations will incur strikes.
@all
No help on this. Thank you.
Old 21st July 2011, 06:36   #3430  |  Link
Kurosaki Ichigo
I get it for rule number 6. I'll pay attention in future! ^^ Thanks anyway...
Old 21st July 2011, 06:41   #3431  |  Link
Thank you for your understanding.
Old 21st July 2011, 08:36   #3432  |  Link
Kurosaki Ichigo
Don't say it! It's a rule, it's just normal! ^^
Old 5th December 2015, 18:16   #3433  |  Link
RipFan
Thanks for all the information and effort.
I have only one question, I use Megui 2624 (latest version) downloaded x264 2638 Kmod and replaced it by the "x264_64.exe" that was placed inside megui folder "tools".
My question is: to use a fade_compensate CLI do I have to download the patch as well?
If the answer is yes, where do I have to place this Patch?
Best regards and many thanks once again
RipFan is offline   Reply With Quote
Old 5th December 2015, 19:43   #3434  |  Link
sneaker_ger
The patch file (.diff) is not needed, that's just what the kMod creator used to build x264.exe from.
Old 5th December 2015, 23:14   #3435  |  Link
RipFan
Thanks a lot, just what I nedded to know
Old 6th December 2015, 20:30   #3436  |  Link
benwaggoner
That said, it's been about 8 years since the first post was updated. It'd be nice to have a current version of this thread with up-to-date info.
Ben Waggoner
Principal Video Specialist, Amazon Instant Video
My Compression Book
Amazon Instant Video is hiring! PM me if you're interested.
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
