Old 24th October 2019, 05:21   #21  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
Originally Posted by poisondeathray View Post
lower sec / frame means it 's faster
Oops, my mistake, I thought I read frames per second.
Cary Knoop is offline   Reply With Quote
Old 25th October 2019, 01:18   #22  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
It would probably be useful to add installation instructions for portable Vapoursynth installs as well.
Old 27th October 2019, 23:13   #23  |  Link
AlphaAtlas
It works the same in the VS Fatpack for me. Just open a console window wherever python.exe is, and then install all the dependencies with pip the same way.
Unfortunately CUDA isn't portable, so that part needs a system install.
AlphaAtlas is offline   Reply With Quote
Old 28th October 2019, 01:50   #24  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
It's looking for the Vapoursynth installation path.
Old 11th December 2019, 20:08   #25  |  Link
PRAGMA
PRAGMA's Avatar
VSGAN doesn't care where or how you have VapourSynth installed. All it cares is you have installed it via pip and that you have all dependencies especially PyTorch installed.
PRAGMA is offline   Reply With Quote
Old 11th December 2019, 20:31   #26  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
That was my whole point if you have an install (not through pip) it fails.
Old 11th December 2019, 21:47   #27  |  Link
brucethemoose
AFAIK it's not really practical to install without pip, if that's what you mean.
To be clear, what I do with the vapoursynth fatpack is call "C:/pathtofatpack/VapourSynth64/python.exe -m pip install vsgan". You have to specify the portable python path, otherwise you'll call pip in a python setup that doesn't have access to VS.
On Linux, you can also set the PYTHONPATH environment variable in the terminal if you have multiple Python installs.
brucethemoose is offline   Reply With Quote
Old 11th December 2019, 23:02   #28  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
That would work.
I merely wanted to point out that not everybody will know this.
esrgan, gan, upscale, vapoursynth
