25th September 2016, 18:23 | #1 | Link |
(Suggestion for a new filter)Generalized Video Deblurring for Dynamic Scenes
I've been trying to deblur this old VHS capture for several years now and had until now found nothing that could help. It was filmed with handheld camcorder with a lot of blur due to the motion of the camera. I finally found this Matlab code that does some major improvement, but it takes forever and a day to process a lot of video. I was hoping their was some skilled person here that might be willing to take up the challenge and convert this Matlab and C++ code to an avisynth plugin.
It was developed by Tae Hyun Kim & Kyoung Mu Lee from Seoul National University. http://cv.snu.ac.kr/research/~VD/ https://www.youtube.com/watch?v=T6F5QzRm2lQ Thanks in advance, Navarre66 Last edited by Navarre66; 8th May 2018 at 15:26. Reason: Added video presentation of paper. |
6th May 2018, 21:06 | #2 | Link |
Dynamic Video Deblurring using a Locally Adaptive Linear Blur Model
Tae Hyun Kim & Kyoung Mu Lee have continued developing and added correction for out of focus video. This is essential if you want to do video stabilization on hand-held video footage or the stabilization will show the video going in and out of focus. This isn't noticeable when the video is not stabilized because it is in sync with the motion-blur.
From what I can tell this code would work well with MVTools. Perhaps pinterf would be interested in taking this up. Latest paper. http://cv.snu.ac.kr/publication/jour...M_PAMI2017.pdf Source code is Matlab and C++ http://cv.snu.ac.kr/research/~VD/GVD-release_v1.zip Thanks in advance, Navarre66 |
8th May 2018, 02:34 | #3 | Link |
Here is an example of before and after with this filter that I ran myself. It isn't CSI, but it is marked improvement over the original.
It took 8 hours for 30 frames. I'm sure the speed can be improved because this code is not optimized at all. Thanks in advance, Navarre66 Original: Deblurred: Last edited by Navarre66; 8th May 2018 at 15:38. Reason: Updated images |
8th May 2018, 02:42 | #4 | Link |
Have you tried FQSharp ? :- https://forum.doom9.org/showthread.php?t=120496
8th May 2018, 02:47 | #5 | Link | |
Thanks, Navarre66 |
8th May 2018, 03:01 | #6 | Link |
One of the things I forgot to make clear is that this method analyzes the motion of the video and uses that to determine the motion blur in order to reverse the motion blur. I'm pretty sure the motion estimations that are produced by MVTools could be used as input for this method.
As far as I know, FQSharp is only good for a consistent blur or if you only want to deblur a few frames as you adjust the parameters. Navarre66 |
8th May 2018, 06:31 | #7 | Link | |
It looks very interesting, and the pdf results look good. Too bad there weren't any video samples to check for temporal consistency (or problems with flicker) - can you make any comments on that from what you've seen so far ?
It's nothing compared to the time required for attachments to get approved....*that* code is not optimized either ... I can't see your pictures, but people skirt around the issue by posting to free 3rd party image hosts or file hosts |
8th May 2018, 09:22 | #8 | Link | |
Navarre66, suggest try PostImage.org, you can create an account [EDIT: free] very easily, or post anonymous if you prefer. Paste this one (circled in red, copies to ClipBoard): EDIT: Or the Thumbnail for forums, two options higher. eg
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th May 2018 at 10:18. |
9th May 2018, 11:36 | #10 | Link | |
EDIT: Nevermind, I missed the YouTube video at first. The results look quite good, but the output begs to then be run through Deshaker or equivalent for several scenes. While you're probably right about some potential integration with MVTools, I can already sort of see a way to do this with the current MVTools, plus a little extra magic on the side. The basic idea would be to detect global motion blur (e.g. camera movement) via contrast detection or some other means (perhaps look at how MPEG-4 ASP does it for GMC), and then use MFlowInter() to interpolate those frames? No idea if this would work well or if it would even be practical, but it might be worth a quick test. That said, while you mention pinterf is probably the best person for anything related to MVTools (and possibly the only one active on the forums now who fully understands its internals), I hate to ask him to do one more thing as he already does such a ridiculous amount for the community. If someone does pick this up though, I'll be sure to give it a test, though I'm not sure if I have much footage that needs a filter like this. Last edited by `Orum; 9th May 2018 at 11:49. |
10th May 2018, 06:47 | #12 | Link |
The results really are good, at least based on the the demo material. Much better than what we have now in terms of deconvolution , motion blur removal , including commercial offerings
If it's the real deal , I'm surprised some company like Adobe or some plugin company hasn't already worked with (or in the process of working) with the authors to commercialize it. Quite a few operations outlined in the pdf, it looks quite complex and I think a massive undertaking. I have a feeling it would be extremely difficult to implement in avisynth. |
12th May 2018, 03:57 | #14 | Link |
In what way ?
MFlowBlur won't work (as in by itself) because it doesn't accept negative values to reverse the blur. It overlays many copies of intermediate time pixels to make the blur larger, not smaller Some other 3rd party plugins / approaches that add motion blur can use negative values (essentially subtracting blur), and they can work to a limited extent; but nothing as remarkable as the results presented here |
12th May 2018, 09:25 | #15 | Link |
McDegrainSharp() is one of my favorite script functions, works great almost always. (I include in pretty much every script)
http://forum.doom9.org/showthread.ph...45#post1737045 EDIT: Only sharpens where good matches found, so maybe of limited use here.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th May 2018 at 10:07. |
9th June 2018, 15:09 | #16 | Link | |
2- subtract input clip from motionblur 3- add difference to input clip
powered by Google Translator |
9th June 2018, 17:42 | #17 | Link | |
If you've ever used MFlowBlur (to add motion blur) to a clean source, with clear motion paths, ideal circumstance - you should already know the accuracy is quite poor. Or do you have an example where this approach works semi decently , even on an "ideal" test scenario ? |
avisynth, deblur, matlab, mvtools |
