Old 6th September 2010, 09:50   #1  |  Link
sLiD
Problem with PSP
Hi.
I found this problem about one month ago.
Please look at the pictures below.
Look closely around the forehead and the lips.
As you can see, there are some block lines.(stairs lines? I don't know its technical term.)
I used MeGUI to encode that movie.
Now I will show you my MeGUI's settings.
This problem is most visible when the color is red.
When the color is another color, this phenomenon doesn't seem to occur.
Compare red with sky-blue
And look at the small holes inside the tires.(near the nuts.)
You will see the difference between the two.
This pictures are a scene of the Evangelion movie.
Maybe you can exactly see what is problem.
Look at the bottom.
Red building's lines are not smooth although green lines is smooth.
All of the pictures are captured in PSP(not PC)
So... How can I fix those problems?
Please help me.
Additional pictures.
Hair line.
Eyes.
sLiD is offline   Reply With Quote
Old 6th September 2010, 10:01   #2  |  Link
J_Darnley
J_Darnley's Avatar
Use a better renderer... oh you're using a PSP. I guess you're stuck with it then. The chroma subsampling a a feature of the colourspace all videos you can play on the PSP.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 6th September 2010, 11:50   #3  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Blame sony for lack of chroma upscaling.
Old 6th September 2010, 14:37   #4  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Yeah, that's just bad YV12 to RGB conversion.
The only way to make that look better is to encode into 720x480 or similarly 'bigger than native' resolution (so that the PSP has more information from which to create your 480x272 RGB picture).
TL;DR Blame Sony
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 6th September 2010, 14:52   #5  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
Indeed, I learned about the same issue on the Zune HD after asking around. Is there any particular reason they do this other than being completely ignorant? Anything to do with processing power, etc.?
"I'll take a potato chip... and eat it!"
Yoshiyuki Blade is offline   Reply With Quote
Old 9th September 2010, 03:02   #6  |  Link
sLiD
Hmm...
All I have to do is blaming sony T.T
Any way, thank you.
P.S.
But... is still there anybody who can fix this problem, please help me.
Old 9th September 2010, 06:27   #7  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
You can't do anything to the source that will fix this. The problem lies in poor YV12 -> RGB conversion during playback on the PSP. Sadly, unless there are homebrew media players that address this issue, you're SOL.
Derek
Old 9th September 2010, 09:21   #8  |  Link
J_Darnley
J_Darnley's Avatar
Originally Posted by sLiD View Post
P.S.
JEEB had a suggesstion. Did you try it?
Old 9th September 2010, 20:18   #9  |  Link
SquallMX
Special SeeD
TL;DR Blame Sony
That's exactly what i do, using 480p "solves" the chroma up-sampling problem, obviously your encodes would need more bitrate.
SquallMX is offline   Reply With Quote
Old 9th September 2010, 21:29   #10  |  Link
Yoshiyuki Blade
Novice x264 User
That sounds like a pretty decent solution. It would probably risk softening up the image too though, depending on the device's internal resizer.
Old 10th September 2010, 06:27   #11  |  Link
sLiD
Yeah, I tried.
Also I solved the problem in that way.
But what I really want was solution of "480x272".
Anyway, Thanks!!
(Also thanks to JEEB )
Old 10th September 2010, 07:41   #12  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Have fun rewriting the YV12->RGB conversion routines, if it's even possible (not sure what the API gives you actually, in the worst case it just gives you the already converted RGB data).
psp
