Old 28th July 2009, 06:46   #1  |  Link
greatmagician
MP4 and MP4 PSP ?
hi to all
i have ? for mp4 file is same mp4 psp
i mean i can play mp4 file in psp if not mp4psp and what's the different between them ? any idea ...
greatmagician is offline
Old 28th July 2009, 07:31   #2  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
MP4 is the container, it is the same for psp and others.
Content matters:
PSP has some restrictions:
- Resolution (up to 480x272 and fixed 720x480)
- AVC Level and Profile (Level 3.0, Main Profile, not High)
- count of ref and bframes (2 ref, 3 b)
- some other encoding options (no b-pyramid)
- Audio: LC-AAC Stereo (no HE, no 5.1)
So for example you can't play a MP4 with 1920x1080 AVC Level 4.1 onto a PSP
Wishbringer is offline
Old 28th July 2009, 08:50   #3  |  Link
greatmagician
thanx brother so if profile in High and sound 5.1 i can't play the file on psp???
PLZ ..can u look to this : if i can play it withe psp
General
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 691 MiB
Duration                         : 1h 25mn
Overall bit rate                 : 1 129 Kbps
Performer                        : Avidemux
Screenplay by                    : Avidemux
Encoded date                     : UTC 1970-01-01 00:00:00
Tagged date                      : UTC 1970-01-01 00:00:00
Writing application              : Lavf52.33.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L3.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1h 25mn
Bit rate mode                    : Variable
Bit rate                         : 996 Kbps
Width                            : 704 pixels
Height                           : 384 pixels
Display aspect ratio             : 16/9
Frame rate mode                  : Constant
Frame rate                       : 25.000 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : MBAFF
Bits/(Pixel*Frame)               : 0.147
Stream size                      : 610 MiB (88%)
Writing library                  : x264 core 67 r1170M 364d7df
aq=1:1.00
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 1h 25mn
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Channel positions                : L R
Sampling rate                    : 48.0 KHz
Resolution                       : 16 bits
Stream size                      : 78.4 MiB (11%)
Old 28th July 2009, 09:40   #4  |  Link
imk
|ン、)
imk's Avatar
He just listed that it can only play Main, not High, so why do you need to even ask if it will play? That video is listed as High. Also, that shows the audio as having 2 channels, not 5.1.
imk is offline
Old 28th July 2009, 10:08   #5  |  Link
roozhou
AFAIK PSP supports ref <= 3
HE-AAC plays fine on my PSP1000.
roozhou is offline
Old 28th July 2009, 10:10   #6  |  Link
greatmagician
because there is movies for secrtmyth all bd rip alo of video in high
and sound 5.1 and he said the not to all his movie
NOTE : I have tested this on the and and works fine.
get why i'm ask now baby
Old 28th July 2009, 10:58   #7  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
Read the rules! http://forum.doom9.org/forum-rules.htm
No discussion of pirated content allowed here!
microchip8 is offline
mp4, psp
