Old 15th July 2013, 09:46   #12381  |  Link
gnol009
Anyone know how to creat qpfile.txt?
gnol009 is offline
Old 15th July 2013, 16:27   #12382  |  Link
filler56789
SuperVirus
filler56789's Avatar
Looks like you have posted in the wrong forum AND in the wrong thread
http://forum.doom9.org/forumdisplay.php?f=77
filler56789 is offline
Old 6th August 2013, 19:40   #12383  |  Link
jpsdr
I have a little question...
If i do something like : "eac3to 00001.m2ts 3: c:\File.wavs"
Track 3 is DTS-HD MA, either 2.0, 5.1 or 7.1. I have the decoderdtsdll.dll installed.
Will the wave files be created only from the DTS core (so from lossy audio), or will they be created from the full DTS-HD MA information (the lossless audio) ?
jpsdr is offline
Old 6th August 2013, 20:44   #12384  |  Link
rapscallion
NY Frame of Mind
rapscallion's Avatar
I Use a GUI with eac3to and do the same kind of extractions and always get the full lossless wavs.
"Talk to me Goose"
rapscallion is offline
Old 7th August 2013, 00:24   #12385  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
It will extract the core if you tell it to with "-core" switch.
Otherwise, if Arcsoft decoder registered, then it will extract the lossless DTS.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Sparktank is offline
Old 7th August 2013, 05:40   #12386  |  Link
DoctorM
I oddly find that when I'm decoding AC3 I have to force the switch -Nero. Yes, Nero 7 is properly installed, eac3to -test KNOWS it is installed (and says it works fine) and it seems to work properly when I add -Nero to my line. For some reason it doesn't seem to be the default decoder though.
Any thoughts on this?
DoctorM is offline
Old 7th August 2013, 07:10   #12387  |  Link
nevcairiel
The default decoder for AC3 is ffmpeg/libav, so that behaviour is expected (as documented in the first post in this thread)
I don't think the Nero decoder does a better job at it, so the default choice here makes sense, IMHO.
nevcairiel is offline
Old 7th August 2013, 16:57   #12388  |  Link
DoctorM
Thank you. I misread that. Nero is best for AAC not AC3. In fact nothing is listed as 'best for ac3". I guess I just assumed.
DoctorM is offline
Old 8th August 2013, 01:53   #12389  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
The Wikibooks says that Nero should offer better sound quality over libav/ffmpeg.
As a result Nero7 is the default decoder for AC3 format.
Outdated since version 3.25...
* libav is now the default decoder for AC3 and E-AC3
But shortly before release of version 3.26, someone asked about this and Madshi said there was a problem where Nero didn't always remove DRC for some files.
Originally Posted by 88keyz View Post
Curious, why the change from Nero to libav as the preferred DD decoder?
Because there were some problems with the Nero decoder. Mostly, disabling DRC didn't work for all tracks.
Old 8th August 2013, 12:00   #12390  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Somebody users reports issues decoding ac3 files with nero decoder, mainly with multitracks files (5.1). For this reason, libav is decoder for default.
This Wikibooks is outdated.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline
Old 10th August 2013, 22:42   #12391  |  Link
Mark Regalo
What files are used by eac3to from Nero to decode aac files? I have an old Nero 7 cd which I bought a long time ago yet I really don't want to install Nero on my computer.
Mark Regalo is offline
Old 10th August 2013, 22:43   #12392  |  Link
Snowknight26
Then why do you want to use Nero to decode AAC?
Snowknight26 is offline
Old 10th August 2013, 23:16   #12393  |  Link
Mark Regalo
Isn't that what eac3to uses as the "best" method to decode aac? I just read what madshi wrote about eac3to in the OP.
Old 12th August 2013, 01:43   #12394  |  Link
Mark Regalo
So, any idea on how to use Nero with eac3to without installing it?
Old 12th August 2013, 02:58   #12395  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
There was a batch script created a long time ago that would do it for you.
Try a google search and limit to this forum only.
site:forum.doom9.org something something something eac3to
Old 15th August 2013, 14:40   #12396  |  Link
utenteanonimo64
Is there any software that can take the information created by eac3to in "chapters.txt" and apply it to a WAV/W64 file to split it into separate files with the appropriate WAV/W64 headers for each chapter?
utenteanonimo64 is offline
Old 15th August 2013, 15:15   #12397  |  Link
Shevek
Perhaps Medieval CUE Splitter?
Shevek is offline
Old 15th August 2013, 18:38   #12398  |  Link
utenteanonimo64
Thanks for the quick reply. I will have to look if there is an easy way to turn "chapters.txt" into a CUE format file...
Old 17th August 2013, 10:58   #12399  |  Link
kevmitch
-downmix and dithering.
I noticed that decoding the same surround source file with the -downmix option produced different output files each time (the samples weren't the same). I'm pretty sure that this is because there is dithering which is randomly chosen. Sure enough, when I specify "-full" as suggested by madshi, the output is identical every time.
My question is how exactly is the random noise seeded/generated and why not just use a method (i.e., same seed) that produces identical results each time? I know it would put my mind at ease a little.
kevmitch is offline
Old 17th August 2013, 11:52   #12400  |  Link
kevmitch
Oblivion: distorted center channel
While waiting to be able to post here for the first time, I posted over at avsvorums about a problem I noticed trying to decode the DTS HD MA sound from the Obilivion blu ray. In short, the center channel becomes distorted in loud bits. Since that posting, I have realised that specifying '-core' option to eac3to fixes the problem but of course its not "lossless", which my decode of the MA track clearly isn't either in this case.
I have uploaded a sample .dtshd file from 8:10-8:20 of the film which exhibits the problem. Also included with the sample are my eac3to decodes of the centre channel with and without "-core" as well as the libav decode, which also exhibits the distiortion. And of course all the logs and eac3to -test results.
I get the same results (bit-for-bit) using eac3to with the Arcsoft decoder versions 1.1.0.0, 1.1.0.7 and 1.1.0.8. I also hear the distortion when decoding the .dtshd directly in mplayer, vlc and audacity (which I think use the same code as libav anyway).
EDIT: On second thought, the distortion is there in core track as well. I don't know how I didn't hear that before.
kevmitch is offline
eac3to
