31st August 2010, 04:10 | #181 | Link | |
I wrote this a year ago, no response.
If there is a reason for this not to be so, please explain. EDIT: Checking the "current" download, it hasn't been updated for three years. So I guess there isn't much chance of any response from the author, let alone an update. Last edited by AlanHK; 31st August 2010 at 07:01. |
3rd September 2010, 20:06 | #183 | Link |
Xbox Live: o 4lif o
When I try to make MP2 files at CBR 384kbps, they all seem to cut short and produce 256kb files. VBR gives me 0kb files. Anybody else experience this at all? I've tried it on a few different machines. Seems to be the only "broken" part of this plugin I can find (but it could just be me).
16th May 2011, 13:58 | #184 | Link |
heretic nuB
Thank you for this plugin.
I'm also experiencing hangs on exit when using showprogress = false. Thats with an AVS script fed into x264, writing the audio to WAV. With showprogress = true and autoclose = true it works as expected. |
23rd November 2013, 20:16 | #185 | Link |
I compiled it for the latest AviSynth 2.6 (with VC2005 express): http://www.wilbertdijkhof.com/SoundOut26-1.1.1.zip
I will commit the changes soon and I hope i didn't break anything So please let me know if something is not working anymore which used to work before. A final note. Getting this to compile was one thing, but to fix bugs or add new features to it (i like to see an aac encoder for example) is way over my head. Last edited by Wilbert; 23rd August 2015 at 17:35. |
24th November 2013, 01:14 | #186 | Link | |
契約者
Not that important, but while you at it, maybe you can at least update some libraries? FLAC and wavpack could have a nice update. Not sure if there is any point to touch other formats. (personally I don't see the reason to use this plugin for anything other than creating intermediate files, where lossless/uncompressed is the way to go) Also no one needs AAC encoder. The most used ones that are topping listening tests can't be included in this plugin anyway. Last edited by Keiyakusha; 24th November 2013 at 01:18. |
24th November 2013, 13:07 | #187 | Link | |
SoundOut(type=1, format=1, executable="D:\Program\qaac.exe", prefilename="-V 99 --ignorelength -o", postfilename="-")
24th November 2013, 22:18 | #188 | Link | ||
24th November 2013, 22:40 | #189 | Link | |
契約者
Edit: besides how will it really work? There will be some note in the readme that says: here is a new feature, aac encoder. But for that you absolutely have to use commandline! Also QuickTime or winamp (in case of fgh) are required for it to function... Meh Well, yes and no. If we are to trust guys from hydrogenaudio, the most popular encoders are the one from apple (for which qaac or qtaacenc are used to get access to) or fghaac from winamp. Neither is opensource. If not these two, FDK is probably what one would use, but here some licensing issues may arise. I don't really follow this project, but from what I understand there are some serious issues so that people are staying away from distributing it in binary form. Which is kinda required for the avisynth plugin... People are even building automated scripts for users so that it will fetch the source code, mingw and will automatically build the encoder for them. There have to be a good reason for that. Last edited by Keiyakusha; 24th November 2013 at 23:03. |
8th December 2013, 23:27 | #190 | Link | ||
11th August 2018, 13:54 | #191 | Link |
Big Bit Savings Now !
SoundOut 1.1.1 commandline usage format is documented wrong !
format=-2 throws an error.. format=-1 delivers a 32-bit float header only. format=0 delivers 8bit Unsigned Integer format=1 delivers 16bit Little Endian Signed Integer format=2 delivers 24bit Little Endian Signed Integer format=3 delivers 32bit Little Endian Signed Integer format=4 delivers 32bit float format=5 makes Avisynth hang forever. If format is unspecified it delivers source format unchanged, fine (in my test case 24bit Little Endian Signed Integer) Who has access to the documentation may correct that.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 11th August 2018 at 13:58. |
12th August 2018, 10:46 | #192 | Link | |
format=5 delivers 32bit float also. format = 6 -> error. Using AviSynth+ r2728
