22nd June 2009, 16:09 | #1321 | Link |
HDConvertToX author
with your cropping values, the ar should be similar and more near to 4/3.
i am sorry about forcing/not forcing mkv muxing, BUT you can follow this simply rules: - if your video file has more then one audio streams, allow mux in mkv, otherwise say no to mux BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
24th June 2009, 08:01 | #1322 | Link |
I just did my first full dvd movie and have a probelm to report
stdout - Log.txt eac3to v3.16 command line: "C:\Documents and Settings\Sash\Desktop\HDConvertToX_1.8.332.2935\applications\eac3to.exe" "N:\New Folder (8)\Movies\Movie Dvd\Apna Sapna Money Money\VIDEO_TS\VTS_01_1.vob"+"N:\New Folder (8)\Movies\Movie Dvd\Apna Sapna Money Money\VIDEO_TS\VTS_01_2.vob"+"N:\New Folder (8)\Movies\Movie Dvd\Apna Sapna Money Money\VIDEO_TS\VTS_01_3.vob"+"N:\New Folder (8)\Movies\Movie Dvd\Apna Sapna Money Money\VIDEO_TS\VTS_01_4.vob"+"N:\New Folder (8)\Movies\Movie Dvd\Apna Sapna Money Money\VIDEO_TS\VTS_01_5.vob"+"N:\New Folder (8)\Movies\Movie Dvd\Apna Sapna Money Money\VIDEO_TS\VTS_01_6.vob" 3: stdout.wav -normalize ------------------------------------------------------------------------------ VOB, 1 video track, 1 audio track, 14:19:05 1: Joined VOB file 2: MPEG2, 704x480 60i /1.001 (16:9) 3: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB [a03] The Nero decoder doesn't seem to work, will use libav instead. [a03] Extracting audio track number 3... [a03] Removing AC3 dialog normalization... [a03] Decoding with libav/ffmpeg... [a03] Remapping channels... [a03] Writing WAV... [a03] Creating file "stdout.pass1.wav"... [a03] Clipping detected, a 2nd pass will be necessary. <WARNING> [a03] Starting 2nd pass... [a03] Reading WAV... [a03] Reducing depth from 64 to 24 bits... [a03] Writing WAV... [a03] Creating file "stdout.wav"... [a03] The original audio track has a constant bit depth of 64 bits. [a03] The processed audio track has a constant bit depth of 24 bits. Video track 2 contains 248389 frames. eac3to processing took 32 minutes, 38 seconds. Done. Even though 5.1 was detected MPC says 2 channel. there are mp4 and mkv I can play which says 6 channels and play fine... Video: MPEG4 Video (H264) 704x320 23.98fps [Video] Audio: AAC 24000Hz stereo 768Kbps [Audio] Media info says final output has 6 channel audio General Complete name : G:\Movies\Apna Sapna Money Money.Mkv Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 1.32 GiB Duration : 2h 18mn Overall bit rate : 1 372 Kbps Encoded date : UTC 2009-06-23 05:57:26 Tagged date : UTC 2009-06-23 05:57:26 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.2 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2h 18mn Bit rate mode : Variable Bit rate : 1 237 Kbps Maximum bit rate : 6 357 Kbps Width : 704 pixels Height : 320 pixels Display aspect ratio : 2.2 Frame rate mode : Constant Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.229 Stream size : 1.19 GiB (90%) Writing library : x264 core 67 r1162kAVAQ f7bfcfa Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=0 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / thread_queue=6 / nr=0 / decimate=1 / mbaff=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=crf / crf=20.0000 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=14000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Encoded date : UTC 2009-06-23 05:57:26 Tagged date : UTC 2009-06-23 06:00:27 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : Yes Format settings, PS : No Codec ID : 40 Duration : 2h 18mn Bit rate mode : Variable Bit rate : 132.3 Kbps Maximum bit rate : 175 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 130 MiB (10%) Language : Hindi Encoded date : UTC 2009-06-23 06:00:10 Tagged date : UTC 2009-06-23 06:00:27 Menu 00:00:00.000 : Chapter 1 00:00:56.000 : Chapter 2 00:02:30.400 : Chapter 3 00:04:41.600 : Chapter 4 00:07:10.400 : Chapter 5 00:12:43.200 : Chapter 6 00:18:37.867 : Chapter 7 00:22:53.867 : Chapter 8 00:30:17.067 : Chapter 9 00:34:35.200 : Chapter 10 00:48:29.867 : Chapter 11 00:49:48.267 : Chapter 12 00:55:01.867 : Chapter 13 00:57:57.334 : Chapter 14 01:05:04.534 : Chapter 15 01:08:34.134 : Chapter 16 01:14:07.834 : Chapter 17 01:14:48.367 : Chapter 18 01:16:20.101 : Chapter 19 01:26:49.968 : Chapter 20 01:30:55.835 : Chapter 21 01:33:51.302 : Chapter 22 01:45:03.835 : Chapter 23 02:01:58.235 : Chapter 24 02:06:43.568 : Chapter 25 02:15:18.768 : Chapter 26 02:17:50.034 : Chapter 27 VLC player has an option to play 5.1 Goldwave said 2 channels. Cant understand what I should believe Also how to make sure temp files are deleted contents of temp folder after encode except for log files? Name Size hdconverttox_vts_01_1.h264 1,223.1 MB hdencodertox-pid3.mp4 131.2 MB movie.d2v 1.1 MB hdconverttox_vts_01_1.avs 0.0 MB info.txt 0.0 MB stdout - Log.txt 0.0 MB chapters.txt 0.0 MB analyze.avs 0.0 MB AutoCrop.log 0.0 MB movielenght.h264 0.0 MB Last edited by Mrsash; 24th June 2009 at 08:05. |
24th June 2009, 09:12 | #1323 | Link | |
HDConvertToX author
not all application are able to decode the full channels spectrum if you want not SBR you should rise bitrate or quality of audio BHH
24th June 2009, 09:17 | #1324 | Link |
That does seem to be a bug, as he included x264.exe in the applications folder.
Another is that .avi doesn't seem to be on the accepted files list. And it muxes my avi to mkv as soon as I select it! Is this the desired behavior
Christine Dawson, -- Spam-Links removed by Koepi -- |
24th June 2009, 09:50 | #1325 | Link | ||
HDConvertToX author
if you click YES: you will be allowed to select more then 1 audio tracks, otherwise, if you select NO, you will be forced to select only the first audio track BHH
24th June 2009, 11:05 | #1327 | Link |
HDConvertToX author
copy mode works only for avc codec, and not for avi input
BHH
24th June 2009, 11:52 | #1328 | Link |
Thanks, Buzz. I used Spyware Terminator to scan my pc, and he found the .dlls of HDC, the spyware "Backdoor.Hugipon.DGDG" in Applicattions\hooksurcode.dll.
http://img199.imageshack.us/img199/3122/spywarehdc.jpg Sorry, i not used post images in foruns. Last edited by Havokdan; 24th June 2009 at 11:58. Reason: Add image link |
24th June 2009, 13:12 | #1331 | Link |
HDConvertToX author
0.4 should be enough to be not sbr
anyway, it's a matter of detection, if your player play it correctly i will not hassle too much BHH
25th June 2009, 01:41 | #1332 | Link |
buzzqw, the Archos 605 (and the 5) can benefit from a much better setting. This is the maximum setting (not the most sane) playable on the 605 and the 5.
--keyint 250 --bframes 8 --mixed-refs --trellis 2 --ref 10 --deblock 0,0 --subme 9 --direct auto --me umh --no-ssim --merange 32 --weightb --b-adapt 2 --b-pyramid --partitions all --aq-strength 1.0 --psy-rd 1.0:0.4 I personally use this setting for my 5. --keyint 250 --bframes 4 --mixed-refs --trellis 2 --ref 6 --deblock 0,0 --subme 9 --direct auto --me umh --no-ssim --merange 32 --weightb --b-adapt 2 --b-pyramid --qcomp 0.8 --partitions p8x8,b8x8,i4x4,i8x8 --aq-strength 1.0 --psy-rd 1.0:0.4 |
25th June 2009, 01:52 | #1333 | Link |
HDConvertToX author
thanks Chengbin
i will check profile and add it BHH
25th June 2009, 04:26 | #1334 | Link |
Mate more trouble.
Did some videos last night came out perfect with telecine from 29 to 23 fps. This morning did some more. Must have ticked something I was not supposed to. Cant figure it out but all videos encoded this morning came out with lenthy video. Eg: video/audio length before encode 2.23/2.23. After encode 2.59/2.23 length. So audio seems fine while video was extended?? thanks |
25th June 2009, 07:48 | #1336 | Link | ||
HDConvertToX author
you should use different input name BHH
25th June 2009, 10:53 | #1340 | Link |
HDConvertToX author
i thinking about adding a panel for profile editing, but not for adding
what do you think about ? BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
