20th July 2010, 14:05 | #3361 | Link |
Hey. Great software.
Although, why not put it default to x264 in MKV? And perhaps, too, to "copy (original) audio." More importantly, I think the de-noise filters should best be put to off by default. Unless I'm wrong. Yours, twipley |
20th July 2010, 16:46 | #3362 | Link |
Fighting spam with a fish
@twipley
You can create your own profile with your preferred settings and then load this when you start the program. That way you can always be outputting to H264 in MKV (remember x264 is a compressor, not a standard) and keep your original audio. |
20th July 2010, 23:12 | #3364 | Link |
[QUOTE=Macgyver;1418412]The source, a HD-PVR file, plays flawlessly, but when I run it though this is the notation I get as it converts it.
The video is fine, but the audio is slightly out of sync when the avi is played back. Any ideas? The report is attached. **** update ******* Ran the Mpeg2/TS file through mpeg2repair which, when the conversion is run, the are now no errors, YET still an audio lag. ************** update ********* I'm the only one with a/c sync errors? Sorry to have bothered ya all. |
21st July 2010, 04:29 | #3365 | Link |
I had problems with some conversions but through other programs; the error always was the source, and choosing DVDFab as the "disc extractor," main-movie option, in most cases fixed the issue.
Dunno if this can be of any help to you. :S EDIT: sometimes I was also helped by this post: http://forum.doom9.org/showthread.ph...06#post1006806 Last edited by twipley; 21st July 2010 at 04:35. |
21st July 2010, 10:06 | #3366 | Link | ||||||||
HDConvertToX author
as eac3to suggest is better to send a sample to madshi Quote:
could you try to remux it with projectX or pva strumento ? Quote:
what player are you using ? have you tried with vlc ? Quote:
or change decoder for your capture Quote:
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
21st July 2010, 15:19 | #3367 | Link |
ffdshow has default options set. It wasn't loading when I watched the original file in ZoomPlayer or WMP. It did when I enabled Raw video in ffdshow codecs, but no change in encoding results. Could you take a look at the sample?
21st July 2010, 23:50 | #3368 | Link | |
Interestingly though, when I allow Beyond TV's Divx conversion to run, there isn't a problem. Leads me to believe there is a problem with HD-CTX. |
22nd July 2010, 06:59 | #3369 | Link |
HDConvertToX author
@*Touche*
there is something very weird with your files all the samples have 25 fps, but there is a speedup on dss decoding you can try opening the hdconverttox_testni1.avs in mpc and let's play it (or virtualdub) and check for information another try is to force for dss decoding the changefps to 12.5 or similar anyway i doubt that's a problem of hdc could you post the original sample ? (since Testni1.avi don't have cursor i don't think it's the original) BHH
22nd July 2010, 11:21 | #3370 | Link |
Hmm, it is the original. I have the cursor when I play it.
"you can try opening the hdconverttox_testni1.avs in mpc and let's play it (or virtualdub) and check for information" What information should I check for? And how come FFmpegsource doesn't speed it up? |
22nd July 2010, 16:37 | #3371 | Link |
HDConvertToX author
ffmpegsource rely on ffmpeg, directshowsource rely on... directshowsource!
these are two different kind of decoding, each one with pro and cons BHH
22nd July 2010, 21:30 | #3372 | Link | ||
# Language index in use langidx: 0 # English id: en, index: 0 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: English # Vob/Cell ID: 1, 1 (PTS: 0) timestamp: 00:00:28:920, filepos: 000000000 timestamp: 00:00:31:720, filepos: 000001000 (lots more timestamps but I've deleted them due to character limits) # Portugues id: pt, index: 1 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Portugues # Dansk id: da, index: 2 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Dansk # Norsk id: no, index: 3 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Norsk # Finish id: fi, index: 4 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Finish # Svenska id: sv, index: 5 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Svenska # (Not detected) id: --, index: 6 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 7 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 8 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 9 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 10 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 11 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 12 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 13 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 14 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 15 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 16 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 17 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 18 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 19 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 20 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 21 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 22 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 23 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 24 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 25 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 26 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 27 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 28 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 29 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 30 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected) # (Not detected) id: --, index: 31 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: (Not detected)
http://avideojokeaday.blogspot.com |
24th July 2010, 04:42 | #3373 | Link |
Practising Schemer
Two questions, when I am accepting PGC and select Multi Episodes, would there be any way to have all multi episodes added to queue as individual encodes?
Can I set a fixed width to use so that once file has been analysed and cropped that all adjuetments are made to the fixed width? Eg if I set width to 720 and I want it to stay at that regardless of analysis but leave height adjustable. |
25th July 2010, 14:37 | #3374 | Link |
Practising Schemer
Would it be easy to enable a set Fixed height option in the profile text.
#Crop&Resize Crop Obey to AR=0 Follow ITU Resizing=0 No Resize Crop=0 Anamorphic=0 Set MOD Width=16 Set MOD Height=16 Set Height = 720 Set Width = 400 No AutoCrop=0 |
27th July 2010, 03:42 | #3375 | Link |
hello,
Ever since I upgrade to latest version, I find that the final file is not made onto wherever I save it, and I have to mux the .avi and .mp3 from jobx folder manually. Is there any log file I can post to help identify the problem? Jackkoho (numerous time donor) |
27th July 2010, 07:30 | #3376 | Link | ||||
HDConvertToX author
in this way no change is made on width/height Quote:
you can download the "beta3" package build (some post above) BHH
27th July 2010, 17:08 | #3377 | Link | |
Practising Schemer
For Each PGC it seems I need to reanalyse the ifo to access the next PGC. |
27th July 2010, 19:08 | #3378 | Link |
HDConvertToX author
yes, you are right, you must reopen the ifo
BHH
29th July 2010, 13:04 | #3380 | Link |
@ buzzqw
Hey Mate. just writing in regards to Linux compatibility. I remember a few years back you had said that Automkv will run on Linux using Wine (limited) wine 1.2 was released a few days ago http://www.winehq.org/announce/1.2 Loads and loads of changes here. I can play most modern games fine using wine and am wondering what you think about using hdconvertox on wine?? I am going to try run an encode using WINE however Ii am not an expert. I know there are many options in hdconvertox, some which when turned on may trip a bug in wine. If we get good results running on Linux, maybe it could get mentioned it on the main page. I would be happy to help attempt a tutorial for getting it running on wine although I have never done one before, but I’m sure I’ll be able to sort it out.. Cheers!!
Computers are like air conditioners: they don't work properly if you open windows |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
