21st September 2011, 21:33 | #13021 | Link |
I have been using BD Rebuilder for quite a while now and have successfully rebuilt 60+ movies with no problems at all untill i try to rebuild The Adjustment Bureau.
It fails to encode for some strange reason. Any help would be appreciated. Thanks [21:20:40] BD Rebuilder v0.39.01 (beta) - Source: ADJUSTMENT_BUREAU - Input BD size: 40.99 GB - Approximate total content: [03:12:09.499] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:20:40] PHASE ONE, Encoding - [21:20:40] Processing: VID_00300 (1 of 24) - [21:20:40] Extracting A/V streams [VID_00300] - [21:22:57] Reencoding video [VID_00300] - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 13,680 frames - Bitrate: 11,466 Kbs - [21:22:58] Reencoding: VID_00300, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.39.01 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.11.96.14, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [21:23:20] - Failed video encode, aborted Last edited by Gavster; 21st September 2011 at 22:35. |
21st September 2011, 22:11 | #13022 | Link |
I have that one. I'll run it Now I have a reason to run it LOL!
I've made it through all of the smaller streams. I don't expect I'll have a problem. But without your setup information, I don't know. Last edited by omegaman7; 21st September 2011 at 23:10. |
22nd September 2011, 02:41 | #13025 | Link |
J Dobbs re. issues with aften recoding DTS-HD to AC3 448
Are there known issues which make it likely for aften to fail with this source . Should I even be bothering you posting a report and should I just avoid trying to get it to work?
If not, could you steer me to some information which might allow some solution. |
22nd September 2011, 04:30 | #13026 | Link | |
Adjustment bureau
using same audio and auto quality settings. I notice you have 24 av streams while mine had 138. I'm guessing that the newer version auto blanked those which don't appear in the log. Anyway, I hope you find out what's not working. |
22nd September 2011, 15:49 | #13030 | Link | |
1. Make sure you have "Uncompressed audio" enabled in FFDSHOW's audio configuration. Set it to "All Supported" 2. Open up Media Play Classic (it's included with BD-RB). 3. Open the offending AVS file (AUD_00001_4352.AVS) and see if it plays back. At least that way you'll know whether it is the decoding or the encoding that is causing the issue. Also, can you look at the file "00001.track_4352.dts" in Explorer and report the size. I'd like to be sure it demuxed properly. Last edited by jdobbs; 22nd September 2011 at 15:55. |
22nd September 2011, 17:13 | #13031 | Link | |
Aften failure
Yes the AUD_00001_4352.AVS file plays clearly in WMC And the size of the file is 1,453,497 KB. I have also tried a movie only conversion of "true grit" down to a BD-5 if only to see how good the video compression is, but fails at the same place with the same audio conversion settings. |
22nd September 2011, 17:28 | #13032 | Link |
Well, then the only other likely possiblity is that AFTEN is missing or has been corrupted somehow. Have you tried reinstalling BD-RB from the zip file? As a test, I just did audio encoding on a disc I have that uses "DTS-HD XLL" with v0.39.01 and it worked fine.
22nd September 2011, 18:22 | #13033 | Link | |
C:\accessories\BD_Reb\tools\aften.exe if you click on aften.exe it very quickly opens and closes a command window. I doubt it is corrupted, but I'm thinking maybe the path by which BD_reb calls aften.exe may not be correct. Workfiles exists as D:\BD REB WORK FOLDER\WORKFILES Last edited by sonate; 22nd September 2011 at 18:40. |
22nd September 2011, 21:50 | #13034 | Link |
Go to the DOS command window and paste in this command:
c:\accessories\BD_Reb\tools\wavi.exe "D:\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS" - | c:\accessories\BD_Reb\tools\aften.exe -v 1 -b 640 -readtoeof 1 - "D:\BD REB WORK FOLDER\WORKFILES\00001.track_4352.AC3" That should be the same command line that BD-RB is using. Tell me what error you get. Note: even though it rolls over into a couple of lines here -- it should all be on one line. BD-RB offsets from its execution path. So unless you're calliing BDRB.EXE from somewhere other than "c:\accessories\BD_Reb\" it should be correct. Last edited by jdobbs; 22nd September 2011 at 21:56. |
22nd September 2011, 22:35 | #13035 | Link | |
error reads, C:\Documents and Settings\Administrator>c:\accessories\BD_Reb\tools\wavi.exe "D: \BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS" - | c:\accessories\BD_Reb\tool s\aften.exe -v 1 -b 640 -readtoeof 1 - "D:\BD REB WORK FOLDER\WORKFILES\00001.tr ack_4352.AC3" Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. Error: Could not find PCM audio track in "D:\BD REB WORK FOLDER\WORKFILES\AUD_00 001_4352.AVS". input format: Raw PCM Signed 16-bit little-endian 48000 Hz mono output format: 48000 Hz mono (1/0) SIMD usage: MMX SSE SSE2 Threads: 2 ------------------- Last edited by sonate; 22nd September 2011 at 23:11. |
22nd September 2011, 23:11 | #13039 | Link | |
The only way it ever says "Channels=2" is if you are trying to encode to alternate format or you have have "Use 192Kbs encoding for AC3" selected in setup. It sounds like you're playing with your settings. Last edited by jdobbs; 22nd September 2011 at 23:16. |
