Old 11th October 2005, 23:43   #101  |  Link
shorton
Picked up from other thread Here. Possibly this thread is more appropriate to get help with Rawsource.
EDIT: Corrected the file descriptions, added comment about working backwards to 4:2:2 known good format may be adequate:
drmpeg's sourcefiles:
I believe this one is 4:2:0 planar format:
http://www.w6rz.net/wbars.yuv
I *think* this one is 4:2:2 Cb Y Cr Y format and is the format drmpeg was shooting for:
http://www.w6rz.net/ycsd.SIF
Also tried:
We want to use a raw 4:2:2 single frame file. IF someone has an example of a 4:2:2 YCbCr file drmpeg may be able to work backwayrd to produce that file format for me.
test.avs:
#I tried the following (uncommenting the lines sequentially of course)
#All of these opened the image, but it was visually incorrect. All of these #crashed VirtualDub on exit:
# c1 = RawSource("ycsd.yuv", 720, 480, "I420")
# c1 = RawSource("ycsd.yuv", 720, 480, "YV12")
# c1 = Rawsource("ycsd.yuv", 720, 480, "UYVY")
# c1 = RawSource("ycsd.SIF", 720, 480, "YV12")
# c1 = RawSource("ycsd.SIF", 720, 480, "I420")
#These 2 opened the image, it looked visually OK, but it crashed VirtualDub #on exit:
# c1 = RawSource("wbars.yuv", 720, 480, "YV12")
# c1 = RawSource("wbars.yuv", 720, 480, "I420")
AssumeFPS(c1,29.97)
Hope that's of some help.
shorton is offline   Reply With Quote
Old 12th October 2005, 05:47   #102  |  Link
drmpeg
You forgot to try:
c1 = RawSource("ycsd.SIF", 720, 480, "UYVY")
which I believe should open the image correctly.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
drmpeg is offline   Reply With Quote
Old 12th October 2005, 11:32   #103  |  Link
WarpEnterprises
C64
WarpEnterprises's Avatar
cannot reproduce the crash.
can you give me the complete message?
WarpEnterprises is offline   Reply With Quote
Old 12th October 2005, 12:56   #104  |  Link
shorton
Originally Posted by drmpeg
You forgot to try:
Ron
Ron: No dice. I tried:
AssumeFPS(c1,29.97)
I attached a screen shot of what it gives.
Old 12th October 2005, 13:02   #105  |  Link
shorton
You get the standard We're sorry Virtualdub has encountered and error and needs to close. Here is the technical information that produces:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="VirtualDub.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="auxsetup.exe" SIZE="16384" CHECKSUM="0xC21C7E7D" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1.4" FILE_DESCRIPTION="VirtualDub Setup Utility" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.4" ORIGINAL_FILENAME="Setup.exe" INTERNAL_NAME="Setup" LEGAL_COPYRIGHT="Copyright © 1998-2001 Avery Lee, All Rights Reserved" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="08/07/2005 23:10:13" UPTO_LINK_DATE="08/07/2005 23:10:13" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="vdicmdrv.dll" SIZE="6656" CHECKSUM="0xF8FDB301" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1.3" FILE_DESCRIPTION="VirtualDub installable video compressor/decompressor" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.3" ORIGINAL_FILENAME="vdicmdrv.dll" INTERNAL_NAME="vdicmdrv" LEGAL_COPYRIGHT="Copyright © 1998-2000 Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="08/07/2005 23:10:04" UPTO_LINK_DATE="08/07/2005 23:10:04" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="vdremote.dll" SIZE="7168" CHECKSUM="0xC73C2F6F" BIN_FILE_VERSION="1.5.10.1" BIN_PRODUCT_VERSION="1.5.10.1" PRODUCT_VERSION="1.5.10-sp1" FILE_DESCRIPTION="AVIFile-to-VirtualDub-Frameserver glue library" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.5.10-sp1" ORIGINAL_FILENAME="vdremote.dll" INTERNAL_NAME="vdremote" LEGAL_COPYRIGHT="Copyright © 1998-2004 Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.10.1" UPTO_BIN_PRODUCT_VERSION="1.5.10.1" LINK_DATE="08/07/2005 23:10:08" UPTO_LINK_DATE="08/07/2005 23:10:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="vdsvrlnk.dll" SIZE="5120" CHECKSUM="0xA25D1808" BIN_FILE_VERSION="1.5.10.1" BIN_PRODUCT_VERSION="1.5.10.1" PRODUCT_VERSION="1.5.10-sp1" FILE_DESCRIPTION="VirtualDub server communication library" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.5.10-sp1" ORIGINAL_FILENAME="vdsvrlnk.dll" INTERNAL_NAME="vdsvrlnk" LEGAL_COPYRIGHT="Copyright © 1998-2004 Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.10.1" UPTO_BIN_PRODUCT_VERSION="1.5.10.1" LINK_DATE="08/07/2005 23:10:07" UPTO_LINK_DATE="08/07/2005 23:10:07" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="vdub.exe" SIZE="7738" CHECKSUM="0xAA3D561D" BIN_FILE_VERSION="1.6.5.0" BIN_PRODUCT_VERSION="1.6.5.0" PRODUCT_VERSION="1.6.5" FILE_DESCRIPTION="VirtualDub command-line driver application" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.6.5" ORIGINAL_FILENAME="vdub.exe" INTERNAL_NAME="VirtualDub" LEGAL_COPYRIGHT="Copyright © 2005 Avery Lee" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.6.5.0" UPTO_BIN_PRODUCT_VERSION="1.6.5.0" LINK_DATE="08/07/2005 23:11:17" UPTO_LINK_DATE="08/07/2005 23:11:17" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="VirtualDub.exe" SIZE="736768" CHECKSUM="0xDB7684B9" BIN_FILE_VERSION="1.6.10.0" BIN_PRODUCT_VERSION="1.6.10.0" PRODUCT_VERSION="1.6.10" FILE_DESCRIPTION="VirtualDub" COMPANY_NAME="" PRODUCT_NAME="VirtualDub" FILE_VERSION="1.6.10" ORIGINAL_FILENAME="VirtualDub.exe" INTERNAL_NAME="VirtualDub" LEGAL_COPYRIGHT="Copyright © 1998-2005 by Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.6.10.0" UPTO_BIN_PRODUCT_VERSION="1.6.10.0" LINK_DATE="08/07/2005 23:13:26" UPTO_LINK_DATE="08/07/2005 23:13:26" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="rawsource.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="rawsource.dll" SIZE="49152" CHECKSUM="0xFBA36F1B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="10/03/2005 06:31:18" UPTO_LINK_DATE="10/03/2005 06:31:18" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
Old 12th October 2005, 14:12   #106  |  Link
Wilbert
AssumeFPS(c1,29.97)
Works for me I zipped all my files in the attached package. Try that (correct all paths in the script) and report back.
Old 12th October 2005, 15:13   #107  |  Link
shorton
Thanks Wilbert. I had not explicitly called the plugin in my script. Maybe that caused the problem. Anyway, I used the contents of your zip file in it's own directory to ensure nothing else was there to mess with it. I also removed Rawsource.dll from my Avisynth plugin folder before running your sample script where it was called explicitly. I did get the file to open in a more correct looking manner.
Before I remembered to remove the old Rawsource.dll, Virtualdub still crashed on exit. After I removed the old one it did not, however, it does not appear to be closing cleanly still. Inside Virtualdub, the MRU list isn't updated with that file if it's opened then closed.
Also I tried opening the avs in both encoders, both encoders just close instantly as soon as I open the file, without error or message of any sort.
So as I muddle through trying to do the right thing to help you help me, I added to the script to see if I could improve on CCE opening, but it did not work. Specifically for CCE I tried:
LoadPlugin("H:\_Patterns\rawtest\rawsource.dll")
c1=RawSource("H:\_Patterns\rawtest\ycsd.SIF", 720, 480, "UYVY").loop(30)
convertToYUV2(c1)
AssumeFPS(29.97)
With this version of the script, both the encoder and Virtual dub just shutdown without error or messages of any kind so maybe I'm doing something wrong in that script?
I don't know if it's related, but I don't think the image is quite right. Attached is a reduced jpeg of what I get. Ron made it and I believe it should look like the jpeg posted previously (post #99). Looks like luma's getting whacked. There should be some background gray on each bar set. Ron will be able to confirm.Nevermind this point, see below
Old 12th October 2005, 15:31   #108  |  Link
shorton
Nevermind on this particular point. The levels looked off due to using remote control application to get home to files. Once I uploaded the jpeg, then viewed directly (not in remote control application) it looks correct. Excuse static.
So, now how to get it to open in encoder(s) without crashing them?
Old 12th October 2005, 15:52   #109  |  Link
WarpEnterprises
C64
(1) Ok, crash-bug found (buffer too small by 1)
(2) @shorton: your sample ( http://forum.doom9.org/attachment.ph...tid=4766&stc=1 ) looks like the width is slightly wrong.
(3) @Wilbert: is there a sample image of YV16? AFAIK in the above links there are only YUV2 and YV12 samples. I will add your code
(4) I will add display of the actual used byteoffset
Old 12th October 2005, 16:19   #110  |  Link
Wilbert
Yes, here: http://www.w6rz.net/ycsd.yuv
From this post: http://forum.doom9.org/showthread.ph...022#post722022
Old 12th October 2005, 20:16   #111  |  Link
shorton
Warpenterprises:
Excellent! Anxious to try the revision. Hopefully this will fix the encoder feed crash, too.
I think I have #2 solved. I used the copy of the file Wilbert was using and mine opened correctly except for the crashes (encoder).
Old 13th October 2005, 14:19   #112  |  Link
WarpEnterprises
C64
new version:
* no buffer crash
* YV16 format
* "show" parameter
* index.txt from yuvscan can be used directly
http://www.avisynth.org/warpenterprises/#rawsource
Old 13th October 2005, 15:04   #113  |  Link
shorton
@Warpenterprises & Wilbert:
Thank you. Very much.
I opened the ycsd.SIF sample file in Virtualdub. Now it appears to have closed closed cleanly, updating the VirtualDub MRU list on the way out.
I also encoded the sample file with CCE using:
c1 = RawSource("ycsd.SIF", 720, 480, "UYVY").loop(30)
AssumeFPS(c1,29.97)
I notice I needed no further conversion function/filter to feed to CCE. No color conversions prior to feeding the encoder is what we were looking for.
It did not crash the encoder. And the resulting mpeg looks correct so far.
Thanks again for the help guys. Sincerely appreciated. I'm going to get with drmpeg for my next steps on my project.
Best, Scott
Old 14th October 2005, 09:42   #114  |  Link
peter100m
@WarpEnterprises:
Thank you for the new version!
I've been trying it out with some more uncompressed Quicktime files now and noticed a strange behaviour. It works rather well but I can only use files with 5093 frames (720x576) or less.
The index file from Yuvscan has these values:
frame 5068:4242944000
frame 5094:4264710144
frame 5120:4286476288
Using the "show" parameter the byte position for frame 5093 is 4 263 680 000 (image), and the byte position for frame 5094 is -30 257 152 (image).
There seems to be an integer overflow somewhere. Would you mind looking that up (Im too novice to find the error in the source)?
thank you!
peter100m is offline   Reply With Quote
Old 14th October 2005, 11:40   #115  |  Link
WarpEnterprises
C64
The bytepos in the indexfile is read not correctly if >4GB. I will change it ASAP.
Meanwhile it should work if you simply leave only the first 4 or 5 entries in the indexfile.
As you can see the difference between every 25 frames is equal, so a "big_delta" of 21766144 (=4264710144 - 4242944000) will be used.
The error is here:
int num2;
ret = sscanf(p_del+1, "%d", &num2);
must be:
__int64 num2;
ret = sscanf(p_del+1, "%I64d", &num2);
Old 2nd November 2005, 06:18   #116  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
May I ask for frame sequence support ? (like imagesequence, imagereader)
Examples of standard video sequence:
(I420 files)
http://www.cipr.rpi.edu/resource/sequences/sif.html
Old 11th December 2005, 23:12   #117  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
No? It's a pity.
Warpenterprise,
please correct Rawsource documentation:
parameter "filename" is really "file".
Old 14th December 2005, 20:06   #118  |  Link
WarpEnterprises
C64
not really no :-)
but it doesn't fit nicely.
I'm thinking if if better can be combined with ImageSequence - give me some time.
Old 11th April 2006, 14:52   #119  |  Link
billou2000
any progress or tricks on the idea of having rawsource also working on single file sequences like imagesequence? (but obviously with raw yuv format files)...
I've been looking at it but couldnt find any solution yet.
billou2000 is offline   Reply With Quote
Old 11th April 2006, 22:45   #120  |  Link
ac-chan123
Becauser raw yuv file have no header like the raw sequenezes, simply put them togetter in one file(e.g using cat).
ac-chan123 is offline   Reply With Quote
