Old 2nd March 2014, 11:57   #1  |  Link
alexVS
DVD-lab (chapters, and video stream problem)
I worked with DVD-lab for a long time, but just found out some strange problem. During import of chapters, some of them were missing on DVD-lab timeline.
I imported frame numbers, that I took from m2v-video file using VirtualDudMod. I took only I-frames.
Before that I made m2v in Womble Mpeg Video Wizard, joining small 10-minutes fragments one-by-one into large file.
It looks like in junction points GOP structure is incorrect.
For example:
End of clip 1: .......IBBPBBPBBPBBPBBII
Begin of clip 2: BBIBBIBBPBBPBBP........
End of clip 2: ...........PBBPBBIBBPBI
Begin of clip3: BBIBBPBBPBBPBBIBBP..........
Does it mean that Womble Mpeg Video Wizard produces incorrect MPEG2 video stream in joining points or is there a problem in DVD-lab, placing chapters in such stream?
alexVS is offline   Reply With Quote
Old 2nd March 2014, 18:58   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Both may be the case. Can not speak about Womble.
On Import DVDlab will omit some chapters it finds not trustworthy.
I use to insert/correct these by hand anyway.
chapters, dvd, error, frames, lab
