Old 22nd February 2010, 17:30   #1441  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Because along with the actual TrueHD data there are the bytes that make up the Matroska container itself.
Latest MKVToolNix is v56.1.0
Mosu is offline
Old 24th February 2010, 05:41   #1442  |  Link
Foofaraw
Is there a newer (or other) gui that MKVextractGUI 1.6.4.1 ? It doesn't seem to support everything.
Foofaraw is offline
Old 24th February 2010, 07:45   #1443  |  Link
sneaker_ger
MKVcleaver
sneaker_ger is offline
Old 25th February 2010, 06:03   #1444  |  Link
Foofaraw
Thanks sneaker_ger!
Now if only I can figure out why the WDTVLive has problems with some mkv's depending on what created them and which xml files are in it....
Foofaraw is offline
Old 25th February 2010, 18:14   #1445  |  Link
jeremy33
there is a bug when we try to mux and .mp4 video.
jeremy33 is offline
Old 25th February 2010, 21:26   #1446  |  Link
73ChargerFan
73ChargerFan's Avatar
You can try the following:
1. Anything that mosu asks you to do.
2. Rename the .mkv file you made and play it again.
3. Try muxing using an earlier version of mkvtoolnix.
4. Try muxing using GDSmux, included within the Haali Media Splitter package.
5. Use Mediainfo on each file, select text mode, and post the results here.
73ChargerFan is offline
Old 25th February 2010, 23:14   #1447  |  Link
jeremy33
I just demux my file with tsmuxer and it worked.
My file was created with the latest megui 0.3.4.2 and x264 1442.
jeremy33 is offline
Old 26th February 2010, 13:45   #1448  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
http://www.bunkus.org/videotools/mkv...-219-setup.exe
Mosu is offline
Old 26th February 2010, 14:37   #1449  |  Link
jeremy33
I'll try that.
jeremy33 is offline
Old 1st March 2010, 20:32   #1450  |  Link
fingershop
Track Sizes
Is there a way to get the sizes (in Bytes or MB or whatever) of all the tracks in an mkv file? or for specific tracks?
Thanks
fingershop is offline
Old 1st March 2010, 20:37   #1451  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Not with one of the programs from mkvtoolnix -- at least not without external scripting around mkvinfo's output.
Mosu is offline
Old 2nd March 2010, 04:32   #1452  |  Link
fingershop
Thanks. I saved the output of mkvinfo to a file, imported it into Excel, and got the total sizes of each track. Oddly, it may be just as quick to use mkvextract to see those track sizes directly.
Old 2nd March 2010, 08:56   #1453  |  Link
sneaker_ger
You could also use AVIMUX Gui for that, it will the show the size of each video and audio track in MBytes (one decimal).
Old 2nd March 2010, 09:15   #1454  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Both mkvinfo and mkvextract have to parse the whole file (as does AVIMuxGUI btw) in order to get the track sizes as there's no header field for this information in Matroska files.
Mosu is offline
Old 2nd March 2010, 17:38   #1455  |  Link
[)370|\|470!2
dentist-experimenter
[)370|\|470!2's Avatar
Just wondering if there's a way to make this crappy app to respect splitting filesize. 4499 MB instead of 4475 huh? If it's not too much to ask.
20 years and ubuntu has just restored my faith in humanity ...lol
[)370|\|470!2 is offline
Old 2nd March 2010, 17:42   #1456  |  Link
Inspector.Gadget
I'm convinced "[)370|\|470!2" doesn't actually know what the word "crap" means, or else he wouldn't use it to describe the most popular and feature-rich Matroska muxing application in the world.
Inspector.Gadget is offline
Old 2nd March 2010, 17:45   #1457  |  Link
nurbs
He also doesn't seem to know that you can't split (most) video files in arbitrary places.
nurbs is offline
Old 2nd March 2010, 18:02   #1458  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
He also doesn't know that asking nicely and politely is usually the best way to get good answers.
Mosu is offline
Old 2nd March 2010, 20:12   #1459  |  Link
[)370|\|470!2
C'mon, the question was corny, thought it'd be obvious. This bug/feature/whatever that is that sits in there - for how long... forever? Which means that author has no intention to look into it really. Oh, and yet another good reason for me to stay away from this app and quit giving it a try, which would've prevent me from wasting two hours for nothing today, thanks for asking.
Sorry if it was too sincere/not polite enough.
Old 2nd March 2010, 21:05   #1460  |  Link
MatLz
I often say "maybe"...
MatLz's Avatar
Instead of continue to troll, you should ask 'why?'. Maybe the discussion would be more constructive...
MatLz is offline
