Old 23rd December 2007, 13:30   #461  |  Link
Nicholi
Don't forget to use the --timecode-scale parameter. Otherwise it doesn't matter what you write in the timecodes file/etc, everything is rounded to 1ms by default.
Nicholi is offline
Old 23rd December 2007, 19:07   #462  |  Link
delacroixp
Emperor building empire
delacroixp's Avatar
@ shambles & madshi
Originally Posted by shambles View Post
i know... but i'm a perfectionist when it comes to something i feel passionately about
Yeah, I see. I like perfect solutions, too.
Originally Posted by Thunderbolt8 View Post
me too
i always mux with 23.9760239 fps. Ive also demuxed some blu-ray files with mencoder (ratatouille) and here the video for example was reported to be 23.976025 fps (which is quite close to 24000/1001 as well).
Me too... but doesn't perfection include human limitations.
Arn't we looking for perfect 'human' solutions... a cat may see better and demand higher standards and perhaps in a million yrs time humans will have the capacity to appreciate movies with 1000 FPS, 100 megaPixel resolution and 128-bit colour detail.
Surely, mathematical solutions that go beyond human abilities to tell the difference... also fall into the realm of imperfection.
Pascal
DualRomeEPYC . Storinator
delacroixp is offline
Old 9th January 2008, 18:30   #463  |  Link
DreckSoft
I see you released new test versions. I tried the one from 02.01.
According to the changelog:
* mkvmerge: bug fix: Rewrote the timecode application
code. Additionally force the "previous cluster timecodes" that
libmatroska uses to the current timecode. This seems to get rid of
libmatroska's assertions about the local timecode being to
small/big to fit into an int16. It also seems to get rid of some
of mkvmerge's errors about the packet queue not being empty.
if should now be possible to rewrite timestamps on mkv files created with GDSMux which previously failed most times.
I tested it on Ratatouille Blu-Ray. Steps:
Merge all movie files into one (copy /b ....)
Remux with TSRemux
Mux to MKV using GDSMux
Add audio stream and rewrite timecode with MKVMerge
Last step failes with:
The file 'D:\Ratatoille.mkv' has been opened for writing.
'die' called: common.cpp/safememdup() called from file src/common/common_memory.h, line 91: malloc() returned NULL for a size of 381332 bytes.
DreckSoft is offline
Old 10th January 2008, 01:00   #464  |  Link
Thunderbolt8
check (if you can playback that file until the error) if the glitches around ~40 mins are still present. if it doesnt work the way you did, then check it with copy /b and then demux the video stream with xport and remux it with mkvmerge (so dont use tsremux and gdsmux) please.
btw. where to find these test versions?
Thunderbolt8 is offline
Old 10th January 2008, 08:53   #465  |  Link
kurt
sidekick
kurt's Avatar
http://www.bunkus.org/videotools/mkvtoolnix/win32/pre/
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline
Old 14th January 2008, 08:41   #466  |  Link
DreckSoft
The resulting file has only 6kb so the error is at the very beginning.
Demuxing and remuxing gives async audio. It is sync at the beginning and end (I think) but not in the middle of the movie, so that's not an option.
Old 14th January 2008, 09:38   #467  |  Link
Lele-brz
Lele-brz's Avatar
would it be possible with the upcoming release to force the Cues Section at the beginning of the file?
thanks
Lele-brz is offline
Old 14th January 2008, 22:32   #468  |  Link
bokonon
can someone please help me with an error I've been getting. I'm using MKVMerge GUI v.2.1.0 'Another Place to Fall' and the file plays fine in windows media player
bokonon is offline
Old 19th January 2008, 03:38   #469  |  Link
GasKid
Don't know whether this has been asked before, since this is such a big thread to go through.
I'm now using mkvmerge GUI to cut a sample from a file, e.g. I want the part from 300s to 400s, when I split with mkvmerge, it returns 3 files, and only the one in the middle is what I want. So I have to delete the other 2 files manually.
Is there any way to prevent generating the other 2 parts what I don't want?
GasKid is offline
Old 20th January 2008, 00:03   #470  |  Link
Thunderbolt8
for me its in sync (or not that much desync that its already noticeable) with xport so long until these glitches occur and then it becomes noticably desync
Old 20th January 2008, 00:07   #471  |  Link
Brother John
(schein)heilig
Brother John's Avatar
No. Cutting out single parts is not what the function is designed for.
Brother John
When lost in BeSweet's options, have a look at the Commandline Reference.
DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen!
Brother John is offline
Old 20th January 2008, 06:52   #472  |  Link
GasKid
OK thanks.
Then I think I have to find another application to do this for me.
GasKid is offline
Old 20th January 2008, 20:15   #473  |  Link
bob0r
Pain and suffering
bob0r's Avatar
@Mosu:
How hard would it be to support .yuv files like these:
ftp://ftp.ldv.e-technik.tu-muenchen....quences/1080p/ ?
Quote from #matroska:
shouldn't be hard to add raw support
after all the size of each frame is fixed
all that's needed is the pixel format
the rest is known (width and height)
it would be awesome to add .yuv files to .mkv and simply play them, to compare x264-aq encodes with the original,
bob0r is offline
Old 22nd January 2008, 20:13   #474  |  Link
joseph5
OK thanks.
You can try AviDemux.
joseph5 is offline
Old 23rd January 2008, 04:37   #475  |  Link
delacroixp
delacroixp's Avatar
@ GasKid
OK thanks.
Maybe you can put in a feature request though Mosu is an ardent advocate of the KISS principle and vehemently avoids creeping featurism
which can ultimately destroy an otherwise simple but elegant piece of software.
Perhaps I should add my own feature request for "vertical signalling".
AR signalling works well for full screen but an 800x448 encode signalled with 1.7703 will display at 793x448 (window mode) instead of 800x452 .
Of course, you can avoid the "horizontal shrink phenomenon" by always over encoding the height... eg, 800x464 and all's well !!!
I guess it's more of an MKV spec issue !
Pascal
Old 23rd January 2008, 13:55   #476  |  Link
Joniii
Mosu, any chance of VC-1, DTS-HD High Resolution and DTS-HD Master Audio support in the future?
Joniii is offline
Old 23rd January 2008, 21:42   #477  |  Link
Joniii
Something I just noticed, dunno if it's a bug or what. I demuxed MPEG-4 part 10 ES from Basic Instinct Blu-ray. Demuxed .avc plays fine itself but when I add it into .mkv it takes alot longer for wmp11 to load that .mkv comparing to other backups. When I seek it also takes forever for playback to start again. Also rainbow frames alot. If I mux that .avc into TS, everything works fine.
Joniii is offline
Old 24th January 2008, 22:35   #478  |  Link
rickardk
Same thing with Ratatouille (Blu-ray), Revolver (Blu-ray) and Million Dollar Baby (HD DVD). If remuxed with gdsmux you don't have the rainbow frames but the mkv is unsearchable and will not load in mkvmerge for rewriting timestamps
rickardk is offline
Old 24th January 2008, 23:00   #479  |  Link
madshi
Have you tried the latest mkvtoolnix beta build? It has fixed the failing timestamp rewriting for me. See here:
madshi is offline
Old 24th January 2008, 23:11   #480  |  Link
rickardk
Yes, does not work with Ratatouille or Revolver. Not tried with Million Dollar Baby yet.
Even if I don't rewrite the timestamps the rainbow frames are introduced when just running thoose titles through mkvmerge
rickardk is offline
