7th November 2008, 13:34 | #6881 | Link |
I don't think VOB files ever contain chapter info. Certainly in a DVD structure, that information is in the .IFO file corresponding to the TitleSet. IFOEdit will extract chapter info from an IFO file for you.
7th November 2008, 15:18 | #6882 | Link |
First of all, many thanks to Madshi for his wonderful program. Now two ( probably stupid ) questions : when a m2ts file has more THD tracks what I have to digit to select only the second THD track?
Again; I have used various releases of eac3to but when I have a m2ts file like input it's never specified the language of the various audio tracks. I have tried also with -check but without success. Any help? |
7th November 2008, 15:56 | #6883 | Link |
1.0 Channels 64 kpbs
Hi!
I want to demux the german audio E-AC3 1.0 64 kbps. I tried to convert to .wav and to .ac3. Everytime ffmeg allerts that it cannot do it. Have anyone an idea? command line: eac3to h: bruce.log ------------------------------------------------------------------------------ EVO, 1 video track, 6 audio tracks, 12 subtitle tracks, 1:42:33 "Feature Presentation" 1: Joined EVO file 2: Chapters, 29 chapters with names 3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags 4: E-AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 5: E-AC3, French, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB 6: E-AC3, German, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB 7: E-AC3, Italian, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB "Italian" 8: E-AC3, Spanish, 1.0 channels, 64kbps, 48khz, dialnorm: -27dB "Cast" 9: E-AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB "Producer Commentary" |
7th November 2008, 19:59 | #6885 | Link | |
The command I use to convert: 1) eac3to h: 1) 3:bruce.mkv 6: bruce.ac3 2) eac3to h: 1) 3:bruce.mkv 6: bruce.ac3 -libav 3) eac3to h: 1) 3:bruce.mkv 6: bruce.wav and so on. |
7th November 2008, 22:06 | #6887 | Link | |
8th November 2008, 09:12 | #6888 | Link | |
AnyDVD HD: YES ErrorMessage: [libav] Spectral extension is not implemented. If you want to help, update your FFmpeg version to the newest one from SVN. If the problem still occurs, it means that your file has extension which has not been tested due to a lack of samples exhibiting this feature. Upload a sample of the audio from this file to ftp://upload.mplayerhq.hu/incoming and contact the ffmpeg-devel mailing list. [libav] error parsing the audio block Thanks for help! htpc |
8th November 2008, 10:38 | #6889 | Link |
Ok, this pretty much explains what's wrong, huh? Libav doesn't support the track because it uses some special features of the e-ac3 standard. Nero will work though.
Anyway, for the good of our community i suggest you run the following command Code:
eac3to h: 1) 3:bruce.mkv 6: bruce.eac3 -10mb btw, which movie is it? |
8th November 2008, 13:18 | #6890 | Link | |
The Blu-Ray Movie is "Enter the Dragon" in German: "Der Mann mit der Todeskralle". I will create a sample - but how can I upload it! btw: I have a second problem with the Blu-Ray of "Kingdom of Heaven". The Command is: eac3to I: 1) 4: kh.dts 4: DTS Master Audio , German 5.1 channels 24 bits, 48 khz, (core DTS, 5.1 channels, 24 bits, 1536 kbps, 48 khz) After a few minutes the message appears: [a04] This track is not clean. Processing aborted. [a04] Please clean the track with delaycut and then retry eac3to. What does this mean? |
8th November 2008, 13:24 | #6891 | Link | |
You can upload it in a file host like sendspace.
Do you need the master audio track or only the core? If the second, you can try the -core switch to see if it works. Last edited by nautilus7; 8th November 2008 at 13:27. |
8th November 2008, 14:02 | #6892 | Link | |
sidekick
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
8th November 2008, 14:47 | #6893 | Link | |
The command I use to convert: 1) eac3to h: 1) 3:bruce.mkv 6: bruce.ac3 2) eac3to h: 1) 3:bruce.mkv 6: bruce.ac3 -libav 3) eac3to h: 1) 3:bruce.mkv 6: bruce.wav and so on. Nero: NO AnyDVD HD: YES ErrorMessage: [libav] Spectral extension is not implemented. If you want to help, update your FFmpeg version to the newest one from SVN. If the problem still occurs, it means that your file has extension which has not been tested due to a lack of samples exhibiting this feature. Upload a sample of the audio from this file to ftp://upload.mplayerhq.hu/incoming and contact the ffmpeg-devel mailing list. [libav] error parsing the audio block Here is the Sample-Download: http://rapidshare.com/files/161812574/bruce.eac3 |
8th November 2008, 15:43 | #6894 | Link | |
What do you mean with re-rip? I have the Blu-Ray already on my hdd as ISO. |
8th November 2008, 16:01 | #6895 | Link | |
Do you have a slow connection and it's difficult to upload a bigger sample? If it's not a problem please make a 5 -10 MB sample. Thanks. How can be sure that the corruption is in the disc aswell? Maybe something went wrong the first time you ripped the disc. Rip the disc (either as iso or as folder) and try again. Last edited by nautilus7; 8th November 2008 at 16:11. |
8th November 2008, 17:05 | #6896 | Link | |
Sorry, obviously something went wrong. Here the 10mb-file: http://rapidshare.com/files/161846249/bruce10MB.eac3 Problem 2 (kingdom of heaven) I bought the bluray yesterday and after 2 times getting an error from eac3to by accessing to the BDROM direcly i ripped the whole blu ray to my hdd. Unfortunately, the error appears again. So i gather, there is an error on the bluray inthe hd-dts track But.....: playing the Blu-Ray directly from BDDVD or from the ISO with PowerDVD 8 everything wents fine! So, maybe the error is in eac3to??? Thanks! Last edited by htpc@rischer.at; 8th November 2008 at 17:14. |
8th November 2008, 18:07 | #6899 | Link | |
You can use Radlight Filter Manager for this purpose. And if you want eac3to to use Nero filters, you have to put this option at the end of the line: -nero (BTW, if you don't re-encode but just simply extract the audio (without changing it), decoders will not be used.) Last edited by rica; 8th November 2008 at 18:21. |
8th November 2008, 18:35 | #6900 | Link | |||||
I wonder why people continue to ask questions about tsMuxeR/TsRemux problems in this thread? This is the eac3to thread! If tsMuxeR or TsRemux don't work correctly then you should ask in the tsMuxeR/TsRemux threads for help. |
eac3to |
