#361 | Link |
PgcEdit daemon
Thanks for your kind words. :-)
Unfortunately, I can't easily implement the option to convert a single chapter. It's mainly because the MVC decoders cannot currently "seek" to a certain point in the original video files. Therefore, all pictures must be decoded sequentially, starting with the first one. If you want to do a short test, you can easily edit the _ENCODE.cmd file to change the total number of frames to encode. The command to edit looks like this: Code:
"D:\Tcl\work\BD3D2MK3D\toolset\avs2yuv.exe" ^ "_ENCODE_3D_MOVIE.avs" -frames 132312 -o - ^ | "D:\Tcl\work\BD3D2MK3D\toolset\x264_x64.exe" ^ --crf 20 --preset slower --level 4.1 --vbv-bufsize 78125 --vbv-maxrate 62500 ^ --threads 4 ^ --frame-packing 3 --qpfile chapters_3D.qpfile --frames 132312 ^ --output "00801.264" --demuxer y4m --stdin y4m - If you need to encode exactly the first chapter, you can get the number of frames from the the "chapters_3D.qpfile" file. (Each line contains the frame number corresponding to the start of each chapter.) With that trick, you can easily convert only the beginning of the file. But it is not possible to encode only a segment of the input file that doesn't start at the beginning. I suggest also to use the "ultrafast" preset in the last tab, if disc space and image quality are not important for your test. You can also change the preset manually in the _ENCODE.cmd file (in purple above).
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 26th April 2015 at 11:16. |
#363 | Link | ||
PgcEdit daemon
BD3D2MK3D v0.64
The process of analysing all subtitles from the original subtitle file is very long. Therefore, I have added a sub-menu in the Settings menu to select the method to use to generate the palette. There are 3 options:
Anyway, I think that with the default option to check a single subtitle only, BD3D2MK3D should already produce much better VobSub streams than before. And of course, if you want perfect subtitles, you should use the BD SUP format instead of VobSub (but take care and verify if your players are compatible with the BD SUP format). Most of the other modifications in this version are also related to the Palette. For example, I have added a Tool to generate a palette from any subtitle file in BD SUP or XML/PNG format. See the version history for details: Quote:
#364 | Link |
Hi r0lz,
in last version of your soft I have error. I select streams, set up CRF, preset mode etc. (as always) click on Do it! and in few minutes pop up this error message can't read "outext": no such variable can't read "outext": no such variable while executing "if {$palettefile == "" || ! [file exists $palettefile] || ($outext != "idx" && $outext != "sub")} { if {[string first "--palette-mode" $options] ==..." (procedure "ConvertSubs" line 58) invoked from within "ConvertSubs $tmp3dxml1 $outfile1 0 false $tohardcode $language 24p 24p $resize720 $palettefilename $::bds2sOptions" (procedure "ConvertSubtitleTo3DMVCMain" line 198) invoked from within "ConvertSubtitleTo3DMVCMain $supfile $sub3dfile $in3dp $sbsformat 1 $::additionaldepth $filter $forced $forceforced $::config(gen_palette) $framerate ..." (procedure "GenerateAvs" line 990) invoked from within "GenerateAvs" invoked from within ".nbf5.gf.gen invoke " invoked from within ".nbf5.gf.gen instate {pressed !disabled} { .nbf5.gf.gen state !pressed; .nbf5.gf.gen invoke } " (command bound to event) I tried 3 different movies and same error. Is somewhere older version BD3D2M3D? In this thread I found only actually version. |
#365 | Link |
PgcEdit daemon
BD2D2MK3D v0.65
Oops, sorry. A last minute copy/paste is the culprit.
Here is a fixed version: Code:
# v0.65 (May 2, 2015) # - Bug fix: Error when converting the subtitles to 3D Download: BD3D2MK3D.7z
#367 | Link | |
PgcEdit daemon
BD3D2MK3D v0.66
The new version of MkvMerge has changed the way it deals with the BD TrueHD+AC3 files. It is now possible to mux opnly the 5.1 AC3 core, or the 7.1 THD, or both. By default, both streams are muxed. Therefore, I had to modify slightly BD3D2MK3D to include only the relevant part, according to the "core" option in tab 2. And I have finally modified many things related to the audio streams, and added several tools.
This version has also some improvements related to the chapter files, and a few bug fixes. As usual, I have also updated the third party exes, including x265. Please note that since x265 is updated every day, I will continue to update it each time a new version of BD3D2MK3D is released, but I will not announce the update any more. Quote:
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 24th May 2015 at 07:35. |
#369 | Link |
PgcEdit daemon
The BD SUP format doesn't use the palette. To change the palette, you must save in DVD VobSub (IDX/SUB) format. Change the setting in the "Output format" dropdown at the top of the window.
BTW, why do you need to change it ? Normally, the latest versions of BD3D2MK3D should build and use the right palette automatically.
#371 | Link |
PgcEdit daemon
I don't understand what's wrong. Currently, BD3D2MK3D tries to generate the best palette, and IMO it works pretty well, although it's still not perfect. The subtitles you have loaded in the image posted in post #368 are well known to cause problems to BDSup2Sub. The problem is that in addition to the (totally) black outline, they use also a grey shadow. When BDSup2Sub uses its internal palette, that shadow is rendered with the default grey, and it is much lighter than the original grey of the outline. Therefore the subtitles look strange, especially when they are displayed over a dark background. That's exactly what the last versions of BD3D2MK3D avoid automatically. With the palette generated by BD3D2MK3D, the shadow has (or at least should have) a colour very similar to the original grey. It's a much darker grey than the one from the internal palette, and the effect of the shadow over a dark background should be satisfactory.
BTW, obviously, you have loaded the original BD SUP, and not the converted VobSub. Therefore, what you see in the image has exactly the same colours than in the BD. BD3D2MK3D cannot be responsible of any change in colours in that subtitle, since it has never modified it. And I don't see any brown colour in your picture. I have verified with an image editor, and the shadow is a pure grey. If it appears somewhat brown, it's probably due to the contrast with the blue background. To verify if the palette generated by BD3D2MK3D is correct, you should load the BD SUP in BDSup2Sub, then load the palette generated by BD3D2MK3D, and of course set the output format to VobSub. Then you can compare the original subtitle (on top) and the subtitle as it will be if you generate the IDX/SUB file with that palette. You will probably agree that the result is good, if not perfect. (Take in mind that the result cannot be perfect due to the limitations of the VobSub format.)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 27th May 2015 at 11:45. |
#373 | Link |
PgcEdit daemon
There is no precise reason. The director is free to consider that the right view is the main view, perhaps because he thinks that it is better. Normally, in the human vision, the two eyes are equal, and the "perfect 2D view" is the view generated by the brain and corresponding to a "third eye" located exactly between the two eyes. But in the movie, it is too difficult (and expensive) to shot 3 views at the same time, and the director has to select a view for the 2D version of the movie.
The real question is not why is it the right view in some rare cases, but why is it not the right view more often? There is no objective reason to consider that the left view is better than the right one. In the 3DBDs, the main view must be encoded in AVC, and the dependent view in MVC, because the 2D-only BD players cannot decode MVC. They "see" only the AVC stream, and show it exactly like a 2D BD.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 27th May 2015 at 11:54. |
#374 | Link |
Using make 3D tools
I wanted to give some depth to T&B subtitles (IDX/SUB) from a BD that had empty 3D-planes. I tried it with 'Convert subtitles to 3D (fixed depth)" from the 'Tools' menu, but then the L/R subtitles also shifted vertically. I tried this both with SUP and XML/PNG files.
After that I did it with 'Convert subtitles to 3D (with 3D-plane)" and filled in the desired depth in the XML file and this worked fine. (Later I saw that I could have left the XML alone and use the 'additional depth' input, but I didn't try that.) Is is an bug in your program that the first option had a flawed outcome or did I perhaps do something wrong? Last edited by sambal; 1st June 2015 at 18:16. |
#375 | Link |
PgcEdit daemon
Good question. Honestly, I don't encode in T&B mode, and I have not used the old conversion method (w/o 3D-planes) since a while. I do not support or develop it any more, and I should have removed it already. (If I have kept it, it's only because it offers the possibility to convert several subtitle streams in one shot.)
Anyway, I did only the GUI and I am not the author of the exe that is used by the old method (suppe3d.exe), and if it doesn't work as expected, I can't fix it because I don't have the sources, and the author is not active any more. So, if it appears that it doesn't work correctly, I will almost certainly remove it. Can you confirm that your movie is correctly encoded in real 16:9 half-T&B (1920x1080)? If the black borders of a Cinemascope movie have been cropped, it is normal that the vertical position of the subtitles is wrong. Same thing if the movie is encoded in Full-T&B.
#376 | Link |
I think I didn't made my problem clear. (English is not my native language..)
It is not that the whole subtitle moves vertically, but the left image is shifted from the right one, so there are two subtitles above each other to be seen at a time. It is not a real problem, as with the 3D-planes method is works fine. I just thought you wrote the routine. But, if is is an error in the program, you might want to remove the whole option, as there are other methods available. |
#377 | Link |
PgcEdit daemon
Oh, well, if you create 3D subtitles, there must be two subtitles (stacked vertically for T&B and horizontally for SBS), exactly like the two images of the 3D movie. The 3D subtitles must be handled correctly by the player. They must be printed on the video BEFORE the split of the two images. Unfortunately, many players consider the subtitles as 2D and duplicate them to show the same thing over the two images. That works fine with 2D subtitles, but of course, you can't keep the correct depth that way. With 3D subtitles, you see the subtitle twice (with one subtitle somewhere near the middle of the screen in T&B).
In fact, the best way to display the 3D subtitles on a 3D TV is with an external player that doesn't handle the 3D. The player thinks that the movie and the subtitles are in 3D, and therefore it displays the 3D subtitles "normally", with one subtitle over each view. Then, the TV splits the two views (including the subtitles since it doesn't know that they are there) and display them in 3D. The result is usually perfect (unless the player resizes or moves the subtitles). However, I'm still not sure I understand you correctly. The two methods of generating the 3D subtitles should give identical results (except that it is possible to use the right depth with the method using the 3D-Planes). If I don't understand you, can you post here a screenshot of the same subtitle generated with the two methods, and explain with that example what are the differences?
#378 | Link |
I must have done something terribly wrong, cause now everything seems to work fine. I have tried it a couple of times now with different movies, but the error doesn't appear anymore. I am sorry for wasting your time on this matter.
However, there is an other issue I would like to report. If I choose from a subtitle both its normal and 'forced captions only' versions, I get afterward a message if the 'forced captions only' doesn't exist. But if I choose the 'forced captions only' without the normal version, I get a message immediately, and the program stops. |
#379 | Link |
I have a collection of over 40 3D bluray movies (left eye first).
some of these original 3D blu-ray's have right eye first. Blu-ray's Sammy, Drive Angry , dolphin tale, en Prometheus. When I play these movies the 3D effect seems to be reversed. The best way that I can explain it is that the part of the movie that should be in the foreground is in the background and the background appears to be in the foreground. This effect makes the movie un-watchable. Pushing the menu you have an option reverse the right eye with the left eye, and then it's oke. Is this a bug from the mede8er it's don't correct its zelf and play it wrong? Can't handel the mede8er these blu-ray's with right eye first? I have the 600x3D with 4.1 beta fimware. here is an option that it can be adjusted so that it will provide the good display? I heard with encoding the output gives Left eye first instead of right eye. is there any way without re - encoding to get it well? Last edited by De_Hollander; 10th June 2015 at 10:43. |
#380 | Link | ||
PgcEdit daemon
--------------------------- BD3D2MK3D --------------------------- Done with warnings! * No forced captions in "00160.track_4609.Fra_forced.3D.sup"! Stream skipped. Launch "_ENCODE.cmd" to encode the video (and optionally mux to MKV). Use a delay of 5005 ms if you mux the files yourself. Be sure to verify that there is enough disc space! --------------------------- OK --------------------------- I have not tried yet to hardcode the forced subtitles (without selection other subtitles in tab 2), but I guess that the result will be identical. So, I can't find any problem with the handling of the subtitles. Are you sure you use the latest version (v0.66) ? (I have recently modified many things in the code related to the subtitle streams, and older versions can perhaps have some bugs that are fixed in v0.66.) Also, what do you mean exactly with "I get a message immediately" ? What is the content of that message ? When does it show up ? Is it at the end of the process, like the "no forced captions" warning, or immediately when you click the Do it! button ? Note that I have already seen some BD discs with "bad" subtitle streams. Some short clips have subtitle streams totally empty (without forced or standard subtitles at all). In that case, BDSup2Sub errors out with a cryptic error message like "index 0 out of bounds" (or something similar). I have tried to intercept that message, and if it appears, BD3D2MK3D should display an error message similar to the "no forced captions" warning, but since that case is not frequent, I can't be sure that it is correctly handled. Anyway, in that case, the "index 0" message should appear in red in the console, and be in the BD3D2MK3D.log file. Anyway, again, if you can reproduce the problem, please let me know. And keep the log file. I may need it to understand what's happening. [EDIT] I did a test with the same short clip, but this time, I have selected no subtitle streams at all in tab 2, and selected the French forced only stream in the "hardcode subtitle on video" option in the last tab. Again, there is a (slightly different) warning at the end of the process, but everything went file, and I have encoded the clip without problem (and of course without hardcoded subtitles). Therefore, I can't find any bug in the handling of the forced subtitles.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 10th June 2015 at 13:59. |
