Old 12th March 2007, 22:03   #161  |  Link
Originally Posted by Hans Ohlo View Post
could you fill us in if you do this yourself or someone other is doing it (and mybe a eta ?
I will attempt it myself. No ETA. It works in the JVT decoder, so there is an extant example of how to do it.
Guest is offline
Old 12th March 2007, 22:23   #162  |  Link
bond
Please point me to the spec and section number that describes this index. Thank you.
http://standards.iso.org/ittf/Public...12_2005(E).zip
basically chapter 8.15, stts and ctts atoms
Ogg Theora | Ogg Vorbis
bond is offline
Old 12th March 2007, 23:37   #163  |  Link
ilhyfe
I just tested this software, but it doesn't work with the streams I use. I record from satelite with DVBVier PRO in .ts and .mpg format, but it seemd DGAIndex doesn't like the streams I record. Does anyone have an idea what I can do to solve it?
BTW: The most common errors are:
1. "Found NALU type 0, len xxx undefined, ignore NALI, moving on"
2. "Found NALU w/ forbidden_bit set, bit error? Let's try..."
3. "Garbage at start of bitstream... skipping it"
ilhyfe is offline
Old 12th March 2007, 23:41   #164  |  Link
Yes. As clearly stated several times in this thread (in bold!), if you want support make an elementary stream available for testing. You see, my magic wand is broken, so I have to do it the old-fashioned way.
You didn't try to open the TS or MPG file, did you? I haven't added container support yet, again, as clearly stated several times.
Guest is offline
Old 13th March 2007, 00:00   #165  |  Link
ilhyfe
Hehe, I did. I demuxed the movie now with elecard xmuxer and DGAIndex works. Bit while opening the .avs script I get this error:
AVCSource: Could not open one of the input files (test.avs, line 2).
ilhyfe is offline
Old 13th March 2007, 01:27   #166  |  Link
HookedOnTV
PM'd you links to another file that doesn't seem compatable. This one is from another channel and it is 720p. Basically the same behavior except that ffdshow will play it fine. File indexes fine but no decoding.
HookedOnTV is offline
Old 13th March 2007, 02:45   #167  |  Link
Please provide the stream if you want support. Thank you.
Guest is offline
Old 13th March 2007, 02:48   #168  |  Link
Your first one was PAFF so forget it. This second one appears to have no IDRs or recovery points, which confuses the heck out DGAVCDecode. I'm investigating further because libavcodec does spit out a good first frame, so DGAVCDecode ought to be able to as well.
EDIT: The second one does have recovery points. Should be decodable...stand by.
Guest is offline
Old 13th March 2007, 18:03   #169  |  Link
ilhyfe
I recorded a new stream (10 MB) for you, but now I get "Field pictures not supported". Since I don't know how to cut my old streams (a ~6GB), I can't send you a sample yet.
ilhyfe is offline
Old 15th March 2007, 10:42   #170  |  Link
thany
I can't get it to work
DGAVCIndex works just fine, as it generates a dga file. Then I create an avisynth script like this:
loadplugin("DGAVCDecode.dll")
AVCSource("tloeg.dga")
But when I open it in Vdub, it says
Avisynth open failure
AVCSource: Could not open one of the input files.
F:\Download\tloeg.avs
The first chunk of the dga file looks like so:
DGAVCIndexFile2
F:\Download\tloeg.avc
SPS 6
PPS 96
IDR 157
FRM 7 0
PPS 1488
FRM 5 3
PPS 1662
FRM 6 1
PPS 2144
FRM 6 2
PPS 2629
FRM 5 6
PPS 2806
FRM 6 4
PPS 3291
FRM 6 5
PPS 3772
FRM 5 9
PPS 3946
FRM 6 7
PPS 4427
FRM 6 8
PPS 4911
FRM 5 12
PPS 5088
FRM 6 10
PPS 5572
FRM 6 11
PPS 6053
FRM 5 15
PPS 6227
FRM 6 13
PPS 6708
FRM 6 14
PPS 7192
FRM 5 18
PPS 7369
FRM 6 16
PPS 7851
FRM 6 17
PPS 8330
FRM 5 21
PPS 8504
FRM 6 19
PPS 8983
FRM 6 20
SPS 9465
PPS 9555
FRM 7 24
PPS 10942
FRM 6 22
PPS 11424
FRM 6 23
PPS 11903
FRM 5 27
PPS 12077
FRM 6 25
PPS 12559
FRM 6 26
PPS 13044
FRM 5 30
PPS 13221
FRM 6 28
PPS 13706
FRM 6 29
PPS 14188
FRM 5 1
PPS 14362
FRM 6 31
PPS 14843
FRM 6 0
PPS 15327
FRM 5 4
PPS 15504
FRM 6 2
PPS 15988
FRM 6 3
SPS 16469
PPS 16559
FRM 7 7
PPS 17945
FRM 6 5
PPS 18426
FRM 6 6
PPS 18910
FRM 5 10
PPS 19087
FRM 6 8
PPS 19572
FRM 6 9
PPS 20054
FRM 5 13
PPS 20228
FRM 6 11
PPS 20710
FRM 6 12
PPS 21195
FRM 5 16
PPS 22219
FRM 6 14
PPS 22704
FRM 6 15
PPS 23189
FRM 5 19
PPS 102847
FRM 6 17
PPS 111355
FRM 6 18
SPS 141724
PPS 141814
IDR 141874
FRM 7 0
PPS 286164
FRM 5 3
PPS 381650
FRM 6 1
PPS 436848
FRM 6 2
PPS 488249
FRM 5 6
PPS 584625
FRM 6 4
PPS 632564
FRM 6 5
PPS 684384
FRM 5 9
PPS 796977
FRM 6 7
PPS 857664
FRM 6 8
PPS 904314
FRM 5 12
PPS 983756
FRM 6 10
PPS 1026181
FRM 6 11
PPS 1064744
FRM 5 15
PPS 1139978
FRM 6 13
PPS 1181892
FRM 6 14
PPS 1221000
FRM 5 18
PPS 1296883
FRM 6 16
PPS 1339205
FRM 6 17
PPS 1383369
FRM 5 21
PPS 1481305
FRM 6 19
PPS 1534642
FRM 6 20
SPS 1587835
PPS 1587925
FRM 7 24
PPS 1771298
FRM 6 22
PPS 1830881
FRM 6 23
PPS 1903379
FRM 5 27
PPS 2046878
FRM 6 25
PPS 2122813
FRM 6 26
PPS 2183204
FRM 5 30
PPS 2294158
FRM 6 28
PPS 2366403
FRM 6 29
PPS 2427841
FRM 5 1
PPS 2514537
FRM 6 31
PPS 2564817
FRM 6 0
PPS 2614611
FRM 5 4
PPS 2680869
FRM 6 2
PPS 2723513
FRM 6 3
PPS 2761543
FRM 5 7
PPS 2824438
FRM 6 5
PPS 2864656
And it keeps going like that. Did something go wrong?
thany is offline
Old 15th March 2007, 11:12   #171  |  Link
ilhyfe
Some problem here...
ilhyfe is offline
Old 15th March 2007, 13:51   #172  |  Link
I need a stream to help you. I am getting tired of saying it.
Guest is offline
Old 15th March 2007, 14:36   #173  |  Link
thany
Alright alright, here you go.
Unfortunately, the whole stream is a little too much (like, 13GB), so I'm only publishing the first 1MB. Hope that's enough.
thany is offline
Old 15th March 2007, 16:38   #174  |  Link
Rename it to "tloeg.264"
I'll fix that in the next release.
Guest is offline
Old 15th March 2007, 20:28   #175  |  Link
thany
Works like a charm, thanks
thany is offline
Old 16th March 2007, 16:42   #176  |  Link
Eastermeyer
Happy Easter!
Eastermeyer's Avatar
Just tried to use DGAVCIndex. But the Indexing-Tool isn't doing anything , even after an hour.
I am using WinXPH SP2 and a raw h264-File created with Haali Splitter / Dump Filter (Graphedit).
Here is a 15MB Sample cutted with a binary splitter from the beginning auf the h264-file :
http://files.to/get/395915/41023/cut.h264
Sorry for my terrible English!
I am from Germany.
Eastermeyer is offline
Old 16th March 2007, 17:52   #177  |  Link
It doesn't look like an ES and VLC crashes when trying to play it. Also, Elecard XMuxer doesn't like it. So it's not a valid ES.
What is the original container format?
Guest is offline
Old 16th March 2007, 18:07   #178  |  Link
Eastermeyer
Happy Easter!
TransportStream.
Oh I am very sorry , it seems to be Haali Splitter's fault. It seems to work with a File demuxxed by Intervideo Filter. But it's PAFF , so unsupported.
I am from Germany.
Old 16th March 2007, 18:52   #179  |  Link
I'm beginning to get disillusioned with libavcodec. I keep running into crashes and obscure bugs. I am unable to debug/trace the code due to the inability to build it in my windows development environment. And of course the lack of PAFF is very irritating. So I am considering starting again with the JM reference software, which I can actually build and debug in my environment. It should be possible to optimize it to an acceptable level (borrowing from libavcodec source for key things like transforms, etc.). Then we would have proper open source for a full featured decoder that is usable in standard windows development environments, as opposed to kludgy pseudo-unix environments.
Any thoughts?
Guest is offline
Old 16th March 2007, 18:58   #180  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
I have to admit, that is a good idea. But you have to consider, would it be easier to start from scratch, or to just go through the old code of libavcodec and make bug fixes and so on. Personally I don't know enough code to make a judgement on this, but if you feel up to it neuron2, more power to you.
In short, I vote for the whole overall and start from scratch idea.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline
