Old 23rd October 2014, 17:00   #21  |  Link
Orf
YAP author
Updated to 0.7.0.1, nasty bug with disappeared seek bar and couple of other bugs introduced in 0.7 was fixed
Orf is offline   Reply With Quote
Old 23rd October 2014, 20:02   #22  |  Link
turbojet
The problem with not playing any files still exists for me.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
Old 24th October 2014, 04:56   #23  |  Link
Orf
YAP author
turbojet, try to reset options to their default values
Old 24th October 2014, 06:04   #24  |  Link
turbojet
After reset, still the same.
Old 24th October 2014, 14:22   #25  |  Link
Orf
YAP author
turbojet, did you import folder or file ? What's the extension of target media file ? Is that extension listed under "Options\Import\Supported media extensions" option ? What method of import do you use: Import folders dialog, import files dialog, drug & drop to main window, file browser menu ?
Old 24th October 2014, 21:00   #26  |  Link
turbojet
file, mkv/mpg, yes, drag and drop and import files dialog.
Old 25th October 2014, 07:30   #27  |  Link
Orf
YAP author
turbojet, I still don't understand what's happening. Pls do the following: open player, import file you say you can't import, open message panel (M), press Ctrl+A, Ctrl+C there, copy the text here
Old 26th October 2014, 06:23   #28  |  Link
turbojet
Copying doesn't work but the error is: SQLite: FOREIGN KEY constraint failed
Old 26th October 2014, 08:55   #29  |  Link
Orf
YAP author
Ah, I see, so we got an error here. Can you give me the debug log (located at "%localappdata%\YAP\YAP.log") to examine? After that you can delete YAP DB file, located at "%localappdata%\YAP\DB\YAP.db", I hope this should restore import functionality for you.
Old 26th October 2014, 22:20   #30  |  Link
turbojet
Deleting yap.db didn't help. Here is what's in the log:
26.10.2014 16:18:32.723 Version 0.7, built on 10/23/14 started
26.10.2014 16:18:32.918 SQLite engine 3.8.5 initialized
26.10.2014 16:18:32.919 Database is empty, creating new one
26.10.2014 16:18:32.963 Database created
26.10.2014 16:18:32.997 Command line (0 parameter(s))
26.10.2014 16:18:33.003 Resize(1680, 1016)
26.10.2014 16:18:33.840 OnImageChange
26.10.2014 16:18:33.842 OnLibraryChange
26.10.2014 16:18:33.845 OnChange(0)
26.10.2014 16:18:33.852 OnStateChange(plsStopped)
26.10.2014 16:18:33.859 OnCurrentChange(0,0)
26.10.2014 16:18:37.377 Resize(656, 404)
26.10.2014 16:18:39.081 Parse "E:\Watch\Sons of Anarchy.S07E07.Greensleeves.mpg"
26.10.2014 16:18:43.417 Resize(1680, 1016)
26.10.2014 16:18:44.235 ImportThread: SQLite: FOREIGN KEY constraint failed
26.10.2014 16:18:46.509 ClosePlayer.Execute
26.10.2014 16:18:46.514 Destroy
26.10.2014 16:18:46.550 Finished
Old 27th October 2014, 07:33   #31  |  Link
Orf
YAP author
turbojet, can you share mpg mentioned in the log, or any other media that gives you the same error and PM me the link ?
Old 27th October 2014, 19:55   #32  |  Link
turbojet
It's every file I've tried with 0.7*, mpg, mkv, mp4 avi. All work fine in earlier versions.
Old 28th October 2014, 04:33   #33  |  Link
Orf
YAP author
Well, I've already understand that. But it works on all of my test machines just like before. So it is somehow related to 1) your media files or 2) your machine configuration. I've ask for sample from you just to make sure it is not 1). If it's not we'll see what to do next
Old 28th October 2014, 20:17   #34  |  Link
turbojet
It's really any file but here's a link to an open video that doesn't play in 0.7.* but does in 0.6.* http://download.blender.org/peach/bi...ny_640x360.m4v
Could it be some language issue with sqlite? I'm using english.
Old 29th October 2014, 19:14   #35  |  Link
Orf
YAP author
turbojet, thanks for the link, I've tested it and it is imports and plays fine on three different configurations (including one with English locale). And by the way both import process and SQLite pretty much transparent to locale settings. Technically the error you encounter means that import process tries to insert invalid data inside DB (which is wrong) and SQLite integrity check do not allow it (which is correct). Still not sure why it happens to you. I'll add stack trace to import in next version, may be it'll give me some clues...
Old 30th October 2014, 15:21   #36  |  Link
Orf
YAP author
turbojet: I've PM you the link, pls check this version and if error still exists, copy the log again, it should give me some more info
Old 30th October 2014, 16:18   #37  |  Link
Gravitator
Привет!
Support LAV x64 (To be useful for HEVC) ? How about the SVP...
Gravitator is offline   Reply With Quote
Old 30th October 2014, 18:08   #38  |  Link
Orf
YAP author
Gravitator:
Currently YAP is 32 bit only, addin' support for custom directshow filters is work in progress and will be available in 7.1
Old 8th November 2014, 10:42   #39  |  Link
Orf
YAP author
0.7.1 released
 (+) Filters used in Directshow graph are fully customized now, including
      adding any third party filters, audio renderer selection and more.
      New settings are located under Directshow Filters category
      of Advanced options dialog. Selection of video and audio renderer is also
      availible from full screen options
 (+) Advanced options dialog added (for advanced options which configuration
      requires complicated UI and therefor is not available in fullscreen mode)
 (+) Database updating mechanism added
Old 8th November 2014, 20:28   #40  |  Link
turbojet
0.7.1 opens files again, thanks!
