Old 26th January 2007, 16:53   #41  |  Link
jeffy
Originally Posted by The Scientist View Post
OK, just making sure it was the registry access part that was giving problems.
Yes the codec stuff wont work, I disabled them.
Two more file HERE
One more thing: What country you from?, well your PC..... Do you use "," as a decimal seperator? like 2,5?
Well, I would like to know what's going on
I don't know why, I clicked C:\Program Files\avi.NET BETA3XP\avi.NET4.exe or C:\Program Files\avi.NET BETA3XP\avi.NET3.exe, it gave me some sort of error, but I didn't take a note, clicked Continue and I closed it. Clicked 4 and 3 again and none give any errors. Examining continues on my part.
Decimal separator is a comma "," on this version, yes. Didn't make any trouble with former avi.net versions.
jeffy is offline   Reply With Quote
Old 26th January 2007, 16:57   #42  |  Link
weaver4
I don't see it in the DGIndex download......
I thought it came with that package because another tool that I use had it in the DGIndex directory.
But you can get it here.
http://jsoto.posunplugged.com/audiotools.htm
weaver4 is offline   Reply With Quote
Old 26th January 2007, 16:58   #43  |  Link
ricardo.santos
ricardo.santos's Avatar
....Both weaver4 and ricardo.santos in the thread, wow, deja vu, takes me back....
ricardo.santos is offline   Reply With Quote
Old 26th January 2007, 17:00   #44  |  Link
ricardo.santos
on a sidenote since youre rewriting avi.net have you thought about making it multilingual, release the lang file or similar for the community to translate?
Old 26th January 2007, 17:28   #45  |  Link
weaver4
I have always liked your program over other programs for a couple of reasons, so I was really glad you started working on it again.
1) I like the fact I can use the real quantizer value for single pass encodes. AutoGK won't let me do that.
2) Also when I do two pass I like to use 1000kbs for 640x288 and 1300kbs for 640x352. In AutoGK I am forced to calculate the file size. I even made a bitrate calculator to do to this: http://forum.doom9.org/showthread.php?t=109307
3) I have never made a XviD movie with avi.net and it not play on either of my SAPs
4) Quality of video is as good as AutoGK.
Old 26th January 2007, 17:39   #46  |  Link
jeffy
I wonder why....
SUMMARY upon loading:
- Version compiled for XP, contained in the beta 3, filesize of the ZIP file: 1813647 bytes does NOT throw any errors now.
- avi.NET1.exe - NO errors
- avi.NET2.exe - NO errors
- avi.NET3.exe - ERROR below
- avi.NET4.exe - ERROR below (different from 3)
1&2 will create the AVI file, 3&4 will do nothing.
For 3:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
   at System.Single.Parse(String s, NumberStyles style, NumberFormatInfo info)
   at avi.NET.Form1.Form1_Load(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
avi.NET
    Assembly Version: 2.4.9.9
    Win32 Version: 2.4.9.9
    CodeBase: file:///C:/Program%20Files/avi.NET%20BETA3XP/avi.NET3.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
For 4:
   at System.Number.ParseDecimal(String value, NumberStyles options, NumberFormatInfo numfmt)
   at System.Decimal.Parse(String s, NumberStyles style, IFormatProvider provider)
   at System.Convert.ToDecimal(String value, IFormatProvider provider)
   at System.String.System.IConvertible.ToDecimal(IFormatProvider provider)
   at System.Convert.ToDecimal(Object value)
mscorlib
avi.NET
    CodeBase: file:///C:/Program%20Files/avi.NET%20BETA3XP/avi.NET4.exe
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
Old 26th January 2007, 17:48   #47  |  Link
The Scientist
The Scientist's Avatar
yes, 1 and 2 no errors because they contain no reg stuff on startup.
BETA 4 released.
The Scientist is offline   Reply With Quote
Old 26th January 2007, 17:55   #48  |  Link
weaver4
The Scientist: Can I offer a suggestion. One of these days, probably soon, you will be tempted to add X264 to your avi.net.
I would like to suggest that you not do it. Many of the programs that try to do to much...do too much. You probably would want to have different containers for X264 like MKV and MP4, then you will need different muxes, you will need different audio coders like ogg and such and then pretty soon you will end up with something rather....ugly.
I would recommend that when you get this bug you make a whole new executable for it (X264.Net) and model the gui off of avi.net, keep it simple.
Just my thoughts.
Old 26th January 2007, 17:55   #49  |  Link
The Scientist
Thanks
Old 26th January 2007, 18:33   #50  |  Link
jeffy
Keeping faith & fingers crossed
Huge
Well, downloaded beta4. This time I let the installer remove the beta3 completely, manually deleted whatever was left in the folder C:\Program Files\avi.NET BETA3XP and installed it in the same but empty folder.
Beta2 & Beta1 in different folders still work. Beta3 completely removed.
Beta4:
No good news, error below, after I click "Continue", again "Parse Audio" error and again no AVI file is being created (.TEMP folder again only .d2v & .mpa, no .avs):
mscorlib
avi.NET
    CodeBase: file:///C:/Program%20Files/avi.NET%20BETA3XP/avi.NET.exe
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
Old 26th January 2007, 18:51   #51  |  Link
ricardo.santos
when i clicked on beta 4 the following message appeared:
Clicked on details and the following code appeared:
System.ArgumentOutOfRangeException: Value of '25' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'.
Parameter name: Value
at System.Windows.Forms.NumericUpDown.set_Value(Decimal value)
mscorlib
avi.NET
CodeBase: file:///C:/Programas/avi.NET/avi.NET.exe
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
clicked to continue, mainmenu aapeared clicked to load a vob and the following message appeared:
Old 26th January 2007, 19:16   #52  |  Link
jeffy
Technical reference System.InvalidCastException & System.ArgumentOutOfRange
Well, I sent this link to The Scientist, but it might be also useful for other .net programmers
http://forums.microsoft.com/MSDN/Sho...96555&SiteID=1
Now I would like to add this one also, maybe division by zero:
http://paintdotnet.12.forumer.com/vi...834595ee91bf02
Old 26th January 2007, 19:18   #53  |  Link
The Scientist
Cool, at least you're both getting the same errors and at least I know what's causing them.
By the way all that Debugging text is not needed, only the first few lines after ************** Exception Text **************.
In the quant box of the old avi.NET what number format was displayed inside, would it be 2.5 or 2,5?
Old 26th January 2007, 19:20   #54  |  Link
The Scientist
Yes thanks, I know about these, the problem is the "." and the "," between different countries, bloody thing always gets me...
Old 26th January 2007, 19:26   #55  |  Link
ricardo.santos
in version 2.2.2.0 i get 2,5 when i open avi.net
Old 26th January 2007, 19:31   #56  |  Link
The Scientist
Thanks, I've just changed my system to Sweden and can now mimic the problem, I can sort it now.
Old 26th January 2007, 19:49   #57  |  Link
jeffy
2.2.1.0 = 2,5
2.4.9.9 beta 1,beta 2 = 2,5
2.4.9.9 beta 4 =1,0
If you really do not need that much of Debugging text, I will shorten it next time, I thought maybe some of the files associated with .net framework might not be quite right, therefore I attached a full version.
Old 26th January 2007, 20:13   #58  |  Link
The Scientist
Right I'm getting somewhere now.....
I also found another problem, DivX quant pass on non-english system..... XviD was unaffected but DivX would not except the 2,5, 3,5, 4,5 e.t.c and treat it as 2, 3, 4 e.t.c so all previous versions on non english systems would have been incorrect.
I should change my locale and test more often
Old 26th January 2007, 21:07   #59  |  Link
The Scientist
Beta 5 is up.
If you've used an earlier beta then you need to remove a key from the REG before using: HKEY_LOCAL_MACHINE\SOFTWARE\CloneAD\avi.NET
Old 26th January 2007, 22:11   #60  |  Link
jeffy
Beta 5 is up.
Removed the key, grabbed the beta 5 version, again even deleted the folder, and installing over to C:\Program Files\avi.NET BETA3XP.
Good news, started immediately without an error. Encoded without an error as DivX (Xvid selected, but I know the codecs are disabled for now). So great, to me it seems you have found a working solution!
