17th September 2014, 15:31 | #18002 | Link | |
Also, some nightly builds - even the newer ones - decode it fine. Something from the very latest nightly builds, broke the compatibility.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
17th September 2014, 15:48 | #18003 | Link |
That doesn't change the reason though. There were a lot of checks added against broken samples that otherwise caused a crash, as a side-effect that can cause invalid samples that worked before (by accident) to stop working, but the sample has always been invalid, so its not a big concern.
17th September 2014, 15:54 | #18004 | Link |
OK
Just to be sure that it's not a bug of the decoder/splitter or FFMpeg.
19th September 2014, 13:46 | #18005 | Link |
Any idea why i don't get the correct sound from this source?
I'm using the latest Lav filter and it works great with ffdshow. Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 51mn Bit rate : 5 606 Kbps Width : 1 920 pixels Height : 802 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.146 Stream size : 4.38 GiB (95%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 51mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 154 MiB (3%) Default : Yes Forced : No Last edited by jebediah; 19th September 2014 at 14:06. |
19th September 2014, 14:42 | #18006 | Link | |
SuperVirus
Also, and IMHO, 192kbps is not sufficient bitrate for 5.1 channels... So you have either a buggy version of MediaInfo, or a bad AC3 stream... Code:
Codec ID : A_AC3 Duration : 1h 51mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits |
19th September 2014, 19:33 | #18009 | Link | |
SuperVirus
As Kurtnoise said, without a sample file, there will be no solution to the problem (assuming that the problem is in the LAV filters, bien entendu). |
19th September 2014, 22:16 | #18011 | Link |
Can you find a tool that will allow you to edit it such that you can create a 5-10 second clip? If so, post that on a decent file sharing site and provide the link. People here love to analyze clips and provide feedback, but without a clip there are so many possibilities. Gotta meet 'em half way.
19th September 2014, 22:28 | #18012 | Link |
Get mkvtoolnix and start mkvmerge GUI. Drop the file into it and uncheck everything except the audio track. Go to the "global" tab, choose "split by parts based on timecodes" and enter "-1:00" (without the quotes) under "Parts". Now start muxing and upload the resulting file to a service like file-upload.net.
20th September 2014, 13:22 | #18015 | Link |
Its the same video decoder the 750 (Ti) had, not really "news", but it is plenty fast.
20th September 2014, 18:31 | #18017 | Link |
Bug with LAV Splitter (at least 0.58.2 and newer) playing WebM made from GIFs:
1.) Convert test.gif to test.webm with ffmpeg using: Code:
ffmpeg -i test.gif -an -c:v libvpx test.webm 3.) The video will look something like this: http://i.imgur.com/CTA8EYc.png In Firefox, Chrome, ffplay, VLC and MPC-HC using Haali's Splitter, the video is playing fine. test.gif and already encoded test.webm can be found here: https://www.mediafire.com/folder/yk7..._WebM-Matroska Last edited by Elbart_; 21st September 2014 at 07:50. Reason: typo |
21st September 2014, 04:59 | #18018 | Link | |
