Old 2nd August 2009, 06:36   #61  |  Link
SomeJoe
Originally Posted by Revgen View Post
Sorry, missed that one ...
@neuron2:
Thanks for the new version. Downloading and testing now ...
- SomeJoe
SomeJoe is offline   Reply With Quote
Old 2nd August 2009, 07:38   #62  |  Link
SomeJoe
Finished my tests. Deinterlace=2 now working perfectly, thank you.
I'm in an interesting situation -- I have two identical machines, both are quad core Q6600's running Windows XP SP3 with NVidia 9500GT cards. The new CUVID server 1.0.5 runs perfectly on one machine, but issues the same error that others are getting on the other machine.
The difference is that Visual Studio 2005 with all service packs and patches is installed on one machine, the other does not have it.
CUVID Server 1.0.5 runs fine on the machine with Visual Studio 2005 installed, the error message appears on the other machine.
Currently using CUVID Server 1.0.4 on both machines as a work-around.
- SomeJoe
Old 2nd August 2009, 13:33   #63  |  Link
Thanks. With all those clues I should be able to find out what is wrong.
Old 2nd August 2009, 14:34   #64  |  Link
Please re-download NV beta 5 and test the server again. I think it should be fixed.
Coming next: resizing.
Old 2nd August 2009, 14:45   #65  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
it now works here, what was the problem exactly?
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 2nd August 2009, 14:48   #66  |  Link
Somehow, the project settings got changed to "multithreaded DLL" instead of "multithreaded". I have no idea how that happened.
Old 2nd August 2009, 15:00   #67  |  Link
That's old-speak for "video card".
Anyway, never mind that. It apparently was a problem with my project settings. Is the fixed version working for you now?
Old 2nd August 2009, 15:04   #68  |  Link
rack04
I deleted my post since I didn't read all the way through the tread to see that you already fix it.
Yes it works great now. Thanks!
rack04 is offline   Reply With Quote
Old 2nd August 2009, 15:21   #69  |  Link
GZZ
The best money spent on a tool in a LONG time.
Hardware resizing will properly help alot on the speed (when going 1920x1080 to 1280x720) ??
GZZ is offline   Reply With Quote
Old 2nd August 2009, 15:37   #70  |  Link
Revgen
CUVIDServer works now. Thanks.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 3rd August 2009, 01:30   #71  |  Link
SomeJoe
Tested new Beta 5, now working on both machines no problems.
Hardware resize would be awesome.
Does NVidia expose a hardware IVTC in their API? Decomb package Telecide/Decimate works very well but is slow with HD material because it runs single-threaded within AviSynth. (I have not messed with MT AviSynth, so perhaps it could be sped up using that, but I haven't tried).
It's no big deal if they don't - I have only needed to IVTC HD material a very few times.
- SomeJoe
Old 3rd August 2009, 13:36   #72  |  Link
IVTC for hard telecine is not available.
Old 4th August 2009, 14:27   #73  |  Link
NV beta 6 adds GPU resizing
Here is integrated GPU resizing:
http://neuron2.net/dgavcdecnv/NVbeta6.zip
Example for conversion of 1080i29.97 to 720p59.94:
DGSource("file.dgm",deinterlace=2,resize_w=1280,resize_h=720)
Old 4th August 2009, 16:16   #74  |  Link
Varies
resizing without cropping? not sure o_O
what algorithm is used to resize? hardware? its better than spline\lanczos\blackman?
Varies is offline   Reply With Quote
Old 4th August 2009, 16:20   #75  |  Link
I'll add a source cropping rectangle.
I just wanted some feedback on the resizing at this point.
As I clearly say, it's implemented on the GPU. It is bilinear. I can't answer your last question without knowing your definition of "better".
Old 4th August 2009, 16:43   #76  |  Link
Varies
Be more specific in your concerns.
for example, i want to crop 1 or 3 px ^ ^ of course if i used crop() i must to crop 2 or 4 px, its wrong way ... therefore i used resize(1280,720,0,1,-3,0).
now i resize DGSource("file.dgm",deinterlace=2,resize_w=1280,resize_h=720) and than resize(1280,720,0,1,-3,0) ...again using main cpu.
better for upscale or downscale, halo oreols or artifacts when resizing
and why i see this picture last few days ? i don't use other gpu processes...
Old 4th August 2009, 17:07   #77  |  Link
Try killing the CUVID server.
Old 4th August 2009, 18:22   #78  |  Link
Varies
I restart PC but its dosn't help.
Old 4th August 2009, 19:18   #79  |  Link
Please post a sample of your source and give me the Avisynth script.
I assume this happens when you load the script into something. What is that something?
Old 4th August 2009, 20:26   #80  |  Link
GZZ
Tested the resize a little and it sure gives med a little speed boost. 1Pass before: ~38.5 fps, now its up to ~42 fps (CPU usage is around 40-45%). On 2Pass before ~15 fps, now it up to ~17 fps. My Geforce is a Passiv cooled 9500 GT (1 Gb ram, DDR2-800). The resize quality looks pretty good, not sure if there is any difference compared to the Spline36Resize(1280,720).Sharpen(0.2) I used before.
My Rig:
Core2Quad: Q9450, OC@3.0 Ghz
GPU: Geforce 9500 GT, 1 GB ram.
I'm happy and keep up the good work.
