Old 30th November 2020, 22:08   #18761  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by LigH View Post
Maybe the other way round: x265 should be more efficient than x264, so a coarser quantization should be sufficient for similarly low perceived loss of quality. But not certainly either. It will always depend on the material and the audience.
Yep, I had it backwards. So x265 CQ18 would be the equivalent of x264 CQ14.
Ryushin is offline   Reply With Quote
Old 3rd December 2020, 22:00   #18762  |  Link
Ryushin
Ryushin's Avatar
Dolby Vision
Hi Atak,
Any idea if the tools exist yet to demux the Dolby Vision stream so it can can be added back in the muxing process?
Old 4th December 2020, 20:50   #18763  |  Link
GZZ
Add section marker to your custom script
#Custom
That marker is needed for my code to determine which section of script to remove.
It still dont work in the latest version when I edit a already added job (its added using the batch mode)
See video: http://gofile.me/6GaFo/OOs8P2fb (7mb)
GZZ is offline   Reply With Quote
Old 4th December 2020, 22:02   #18764  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Show me your custom scripts
Old 5th December 2020, 23:11   #18765  |  Link
GZZ
They are just plain
Loadplugin("E:\RipBot264v\Tools\AviSynth plugins\mvtools\mvtools2.dll")
super=MSuper(video,pel=2)
fv1=MAnalyse(super,isb=false,delta=1,overlap=4)
bv1=MAnalyse(super,isb=true,delta=1,overlap=4)
video=MDegrain1(video,super,bv1,fv1,thSAD=400)
I look in the other script (not mine) and they have #Borders or #After_Prefetch_Custom, I guess I have to add #Custom to mine to make it work properly ?
Old 6th December 2020, 05:53   #18766  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by GZZ View Post
They are just plain
Here's what they should look like, to work properly :-
(this is my MDgrain3 + enhance details custom filter, which will only work after the latest updates are installed)
Also VERY important, the "address" in red text HAS to match where you have your RipBot located !!!
#Custom
Loadplugin("C:\RipBot264v1.26.0\Tools\AviSynth plugins\mvtools\mvtools2.dll")
bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4)
bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4)
bv3=MAnalyse(super,blksize=8,isb=true,delta=3,overlap=4)
fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4)
fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4)
fv3=MAnalyse(super,blksize=8,isb=false,delta=3,overlap=4)
video=MDegrain3(video,super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=800)
LoadPlugin("%AVISYNTHPLUGINS%\Plugins_JPSDR\Plugins_JPSDR.dll")
LoadPlugin("%AVISYNTHPLUGINS%\CAS\CAS.dll")
Import("%AVISYNTHPLUGINS%\Scripts\MCAS.avs")
video=MCAS(video,1.0)
It is also important to add these type of custom filters to the RipBot264.ini file. eg:-
MTFiltersList=MDegrain1;MDegrain1_details;MDegrain2;MDegrain2_details;MDegrain3;MDegrain3_details;MDegrain4;QTGMC;HDRtoSDR;z_ConvertFormat;
See what that does for you, good luck.
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 6th December 2020, 08:53   #18767  |  Link
GZZ
#Custom
I think I got must of it correct. What is the difference between your MDegrain2 and MDegrain2_details script, what parameter have you changed ?
Old 6th December 2020, 11:17   #18768  |  Link
Pauly Dunne
Grumpy Old Man.
Yes you did...
It's just a combination of 2 filters, my custom MDgrain, and Ripbot's custom filter "EnhanceFineDetails"..that's all.
Old 6th December 2020, 11:51   #18769  |  Link
Atak_Snajpera
Yes you did...
You do not have to add those extra lines to ripbot264.ini file. (MDegrain2_details,MDegrain3_details)
Old 6th December 2020, 14:27   #18770  |  Link
Atak_Snajpera
They are just plain
I have already told you what to do here
https://forum.doom9.org/showthread.p...93#post1927793
Old 6th December 2020, 19:51   #18771  |  Link
GZZ
I must have missed it.
Old 6th December 2020, 21:52   #18772  |  Link
Atak_Snajpera
IT is funny because You have even quoted my reply...
Old 7th December 2020, 00:50   #18773  |  Link
Pauly Dunne
Grumpy Old Man.
OK, however, if I load this custom filter, then wouldn't the MDegrain function not be assisted by multi threading ??.
You can't load 2 custom filters, (from the drop down) that's why I combined these, and added to the .ini.
Old 7th December 2020, 11:40   #18774  |  Link
Pauly Dunne
Grumpy Old Man.
Atak, I had a strange occurrence today..I was processing a job, and it started "playing up" around chunk 117 (of 195), so I figured out that my Temp folder was full, so I went thru the completed jobs in RB, and deleted them.
When I re-started that Job, unfortunately it started from the beginning
Old 12th December 2020, 13:33   #18775  |  Link
Pulp Catalyst
What do i do regarding the procedure posting issues with encoding:
when indexing sometimes it gets stuck at random times (not repeatable and very random)
sometimes when "gathering information" after the indexing it's also got stuck a few times (again not repeatable so this tells me the ripped disk is most likely not at fault).
is there a main debug log i have to upload...i checked the temp folders and there seems a lot of files so was wandering what i need to post here to help with solution finding?
thanks
Pulp Catalyst is offline   Reply With Quote
Old 14th December 2020, 00:13   #18776  |  Link
Pulp Catalyst
i found another error when using KNLMeansCL (i have a quadro p400)
when i use the avs meter i get the below error?
AVSMeter 3.0.6.0 (x64), (c) Groucho2004, 2012-2020
'C:/EncodingProgz/RipBot/Tools/AviSynth plugins/KNLMeansCL/KNLMeansCL.dll' cannot be used as a plugin for AviSynth.
edit
i went into the avisynth folder in ripbot264, i saw a install bat file...i ran this with admin level.
now i'm getting this
AviSynth+ 3.4 (r2925, master, x86_64) (3.4.0.0)
Number of frames: 218436
Length (hh:mm:ss.ms): 02:31:50.602
Frame width: 1920
Frame height: 1080
Framerate: 23.976 (24000/1001)
Colorspace: YV12
Frame (current | last): 138 | 218435
FPS (cur | min | max | avg): 5.785 | 0.194 | 5.789 | 4.417
Process memory usage: 3608 MiB
Thread count: 171
CPU usage (current | average): 5.6% | 6.9%
Time (elapsed | estimated): 00:00:30.788 | 13:44:10.055
i think maybe something was wrong with my avisynth install...perhaps that could also explain the strange issues with ripbot264 with stability, i will see in time...##
however the speed of the quadro p400 is...terrible for KNLMeansCL...anyone with experience is this speed right for my cards abilities? or is something wrong.
my script is
#MT
Import("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\Scripts\MTmodes.avs")
#PREFETCH_LIMIT=0
#VideoSource
LoadPlugin("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\lsmash\LSMASHSource.dll")
video=LWLibavVideoSource("\\Server\st4000dm000-2ae166_zdh0lhmf\NORMAL\01\Black.Hawk.Down.2001.EXTENDED.mkv",cachefile="D:\Temp\RipBot264temp\job1\Black.Hawk.Down.2001.EXTENDED.mkv.lwi")
#Deinterlace
#Decimate
#Crop
video=Crop(video,0,280,-0,-280)
#Resize
LoadPlugin("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\Plugins_JPSDR\Plugins_JPSDR.dll")
video=Spline36ResizeMT(video,1920,800)
#Tonemap
Loadplugin("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\HDRTools\hdrtools.dll")
Import("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\Scripts\HDRtoSDR.avs")
video=HDRtoSDR(video,"PQ")
#Levels
#Colours
#Denoise
#Custom
#Prefetch
video=Prefetch(video,12)
#After_Prefetch_Denoise
LoadPlugin("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\KNLMeansCL\KNLMeansCL.dll")
video=KNLMeansCL(video,d=1, a=2, s=4, h=4, device_type="GPU", device_id=0)
#Borders
Import("C:\EncodingProgz\RipBot\Tools\AviSynth plugins\Scripts\AutoBorders.avs")
video=AutoBorders(video,16.0/9.0)
#Subtitles
#AudioSource
Import("D:\Temp\RipBot264temp\job1\job1_a1.avs")
#Triming
#AVSameLength
#ColorSpace
#Return
Old 14th December 2020, 12:33   #18777  |  Link
Atak_Snajpera
Have you checked spec for your GPU? https://www.techpowerup.com/gpu-specs/quadro-p400.c2934
0.6 TFlops in FP32 is a pathetic performance. My cheap RX 570 Has almost 10 times more (5 TFlops).
https://www.techpowerup.com/gpu-spec...n-rx-570.c2939
No idea why you complain here...
Old 16th December 2020, 21:42   #18778  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by Ryushin View Post
I've starting to encounter the issue that I had a couple of years ago or so but finally went away after Atak fixed it. I think it started occurring again after the last update.
The issue is sometimes (happens about 1 in 5 to 1 in 10 times) when click OK to finish modifying a job (not sure about adding as I'm currently using batch to add the jobs) the "Encoding Settings" window stays open with some things clickable and other things that are not.
If I click "Done" again a second time in the Encoding Settings nothing happens in the window and it does not close, but clicking "Done" the second time wipes out the avisynth script when I got back in to edit the job after closing Ripbot as that is the only way to get control back. I can still use the main window to stop the "Encoding Client" before closing Ripbot
If the "Encoding Settings" window does not close and if I then close Ripbot without clicking "Done" a second time on the "Encoding Settings" window then the Avisyth script is still there.
This bug recently came back after the last update. It's been a good couple of years (or more since time flies) since I've seen this happen.
Hi Atak,
This bug is getting pretty annoying. I have to stop the encoding jobs. Close Ripbot, then start it back up, wait for it to load the jobs (800+ right now), then edit the file. Does not make any difference if I'm currently encoding or not. It's done it on five out of five jobs right now.
Edit: It can even happen when I edit a job, make no changes, then click Done again. it happened 13 out of 15 times. Rebooting the system did not help.
Old 16th December 2020, 23:20   #18779  |  Link
Atak_Snajpera
Record your desktop showing what you do from start to point where bug occurs. Upload video to YouTube or mediafire.com.
Old 17th December 2020, 12:33   #18780  |  Link
Pauly Dunne
Grumpy Old Man.
Hi Atak,
Hey Ryushin,
Now this may not have anything to do with your problem, but why the hell have you got so many Job's queued up !!!, that's just ridiculous.
Some of those jobs must be pretty old, and have possibly gone thru many auto updates, which can impact on already queued Jobs.
Haven't you got another pc, so you can spread the jobs around..it would be interesting to see if you loaded a couple of jobs on another "fresh" pc, the problem may disappear.
Anyway, that's my 10 cents worth...if Atak comes up with a solution, then it's all good.
Good luck.
