Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 14th January 2009, 15:09   #61  |  Link
yeye69
linux version. Any source file, like mpeg2, h264 and vc1, in any container like m2ts, ts and mkv. Previous version had worked with such files.
MEncoder dev-SVN-r28311-4.3.2
and last dumb question: have you hit "Analyze with..." ?
if you mean a choosing mediainfo or mencoder, I'v tried each of both
yeye69 is offline   Reply With Quote
Old 14th January 2009, 15:41   #62  |  Link
buzzqw
HDConvertToX author
that's strange!
i have tested on debian lenny 32bit and fedora 10 64bit, with mencoder/mplayer build 26940 (debian-multimedia latest build) and 28189
i will update my mplayer build.. but..
could you try this http://www.64k.it/andres/data/autox264/autox264.tar ?
thanks
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 14th January 2009, 16:45   #63  |  Link
yeye69
The same result. Let's begin newly, step by step confirmation.
First, choose a source file, for example, this one http://www.kdenlive.org/videos/avchd-test-1.mts , then name of destination file.
Next step is ...
Old 14th January 2009, 17:20   #64  |  Link
buzzqw
HDConvertToX author
OK!
i am unable to analyze with mplayer too :, with latest mplayer build
BUT is ok with previus mplayer build...
i will check...
BHH
Old 14th January 2009, 17:29   #65  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
that file works with mplayer -demuxer lavf
(mplayer dev-SVN-r28269)
Old 14th January 2009, 17:46   #66  |  Link
buzzqw
HDConvertToX author
thanks a lot froggy1
i will add a workaround
BHH
Old 14th January 2009, 17:57   #67  |  Link
buzzqw
HDConvertToX author
ok, please redownload the autox264.tar.gz from first post
BHH
Old 15th January 2009, 08:34   #68  |  Link
yeye69
I understood my mistake, sorry for misleading. There is no button "Analyze with...", but if I click on blank field near the combobox "mplayer/mediainfo", that works. See attachment
Old 15th January 2009, 11:54   #69  |  Link
buzzqw
HDConvertToX author
@yeye69
if are using gnome as desktop manager make sure you have correctly installed the theme using
BHH
Old 15th January 2009, 13:14   #70  |  Link
yeye69
Yes, I'm using gnome as DE with the default theme on Fedora 10 (32 bit)
Old 15th January 2009, 13:20   #71  |  Link
buzzqw
HDConvertToX author
@yeye69
i am using gnome and Fedora 10 too! (but 64bit)
using the clearlooks theme the screen of application are as first post of this thread
something is wrong on your theme..., please try changing it (try with another theme for example)
EDIT: this is on my fedora 10 with fedora theme
EDIT2: are you using aurora button ?
BHH
Old 15th January 2009, 19:00   #72  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
small bug I noticed. When loading a megui profile, the bitrate is placed into the Final MB (or CRF) box, instead of the correct mplayer manual bitrate box.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 15th January 2009, 20:25   #73  |  Link
buzzqw
HDConvertToX author
@Merlin7777
i agree merlin7777 but if i set this as "manual bitrate" , users will not spot it and every encode will be a bitrate of 1000 ....
would be better to simply ignore the value in profile (if not crf profile) ? what do you think ?
BHH
Old 16th January 2009, 14:57   #74  |  Link
buzzqw
HDConvertToX author
update windows build
now it accept d2v input file. Autox264 will automatically build an avs script around this input
fixed some glitch on m2ts files
BHH
Old 18th January 2009, 14:39   #75  |  Link
flebber
Practising Schemer
Simple question but I cannot get it too work, how do I import megui profiles on Windows XP sp3. I have a dop down box with 'NONE' written in it I cannot use the preset button too select profiles, so I placed xml files in the AutoX264 folder I created and then restarted AutoX264 but no go.
How do you do it?
Is there an option to save profiles you create within AutoX264?
cheers
flebber is offline   Reply With Quote
Old 18th January 2009, 14:41   #76  |  Link
buzzqw
HDConvertToX author
in the same place as autox264 create a folder named "profiles"
copy into "profiles" folder all the XML files from megui x264 profiles
relaunch autox264
no
BHH
Old 18th January 2009, 15:06   #77  |  Link
flebber
Practising Schemer
Sorry I am coming up with an error during encoding.
http://farm4.static.flickr.com/3299/...6a10c95c_o.jpg
Old 18th January 2009, 16:30   #78  |  Link
buzzqw
HDConvertToX author
you are using some options not present in your mencoder build
please add the job to queue.. and copy&paste here the line of encoding
make sure you are using the latest mencoder version (from sherpya site)
BHH
Old 19th January 2009, 09:45   #79  |  Link
flebber
Practising Schemer
I am using the mencoder that came with Automen, I will look for the Sherpya version
"C:\Documents and Settings\flebber\Desktop\AutoMen50_FULL\mencoder.exe" -vf harddup,crop=320:176:0:32,scale=288:156,hqdn3d=2:1:2 -sws 2 -aspect 1.3333 -priority idle -of rawvideo -o autox264.h264 -nosound -ovc x264 -x264encopts bitrate=32352:pass=1:threads=auto:bframes=3:8x8dct:direct_pred=auto:me=umh:subq=6:b_adapt=2:turbo=2:frameref=5:deblock=-1,-1:aq_mode=1:aq_strength=1.2:psy-rd=rd=1.0[0]:weight_b:trellis=2:mixed_refs:nodct_decimate:nofast_pskip:b_pyramid "C:\Rip\Source Video\Killswitchengage_HolyDiver_400(0).flv" -nosound
"C:\Documents and Settings\flebber\Desktop\AutoMen50_FULL\mencoder.exe" -vf harddup,crop=320:176:0:32,scale=288:156,hqdn3d=2:1:2 -sws 2 -aspect 1.3333 -priority idle -of rawvideo -o autox264.h264 -nosound -ovc x264 -x264encopts bitrate=32352:pass=2:threads=auto:bframes=3:partitions=i4x4,i8x8,p8x8,b8x8:8x8dct:direct_pred=auto:me=umh:subq=6:b_adapt=2:turbo=2:frameref=5:deblock=-1,-1:aq_mode=1:aq_strength=1.2:psy-rd=rd=1.0[0]:weight_b:trellis=2:mixed_refs:nodct_decimate:nofast_pskip:b_pyramid:qblur=0.5 "C:\Rip\Source Video\Killswitchengage_HolyDiver_400(0).flv"
"C:\Documents and Settings\flebber\Desktop\AutoMen50_FULL\mencoder.exe" -mc 0 -noskip -aid 1 "C:\Rip\Source Video\Killswitchengage_HolyDiver_400(0).flv" -ovc frameno -oac faac -faacopts br=96:mpeg=4:object=2 -channels 2 -af volnorm=2 -of rawaudio -o audiox264-pid1.aac
"C:\Documents and Settings\flebber\Desktop\AutoMen50_FULL\mkvmerge.exe" -o "C:\Rip\Produced\Killswitch_Engage-Holy_Driver.mkv" --default-duration 0:23.976fps --aspect-ratio -1:1.8648 autox264.h264 audiox264-pid1.aac
Old 19th January 2009, 10:07   #80  |  Link
flebber
Practising Schemer
Yes updating mencoder has resolved it I downloaded the version from http://oss.netfarm.it/mplayer-win32.php and it works well now.
gui, linux, mencoder, windows, x264
