Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 30th October 2008, 08:36   #1  |  Link
buzzqw
HDConvertToX author
AutoMen 5.3 for Linux!
Thanks to PureBasic cross compiling i was able to tweak automen and porting to Linux
Automen 5.3 is tested under Ubuntu 8.04 i386 (on virtualbox) , repository medibuntu (for mencoder and mplayer update builds)
you need mencoder, mplayer, xterm (this should be already installed)
http://www.64k.it/andres/data/automen/automen53.tar.gz
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 1st November 2008, 16:35   #2  |  Link
buzzqw
HDConvertToX author
update to 5.3
added queue
fixed path with space
added thread option
BHH
Old 5th November 2008, 23:18   #3  |  Link
mocham
This is really nice! Can you add a deinterlacing option to it?
mocham is offline   Reply With Quote
Old 6th November 2008, 08:55   #4  |  Link
buzzqw
HDConvertToX author
near threads parameter (where is none) you can select varius deinterlacer/itvc filters
BHH
Old 6th November 2008, 09:00   #5  |  Link
mocham
BHH
Doya! didn't see that! Thanks..
Old 6th November 2008, 17:44   #6  |  Link
mocham
I was encoding some MPEG2-TS files with this frontend, it works really nice! I've searched far and wide and found only a frontend called "mvpod" and now your program AutoMen are the only 2 useful mencoder frontends for Linux.
mvpod has a great method for batch encoding, but lacks a deinterlacing option, I've talked to the author about it and he plans to add it someday.
I was wondering if AutoMen can accept a list of files to be batch encoded? I see the Queue feature, however, I'm working with about 100 short MPEG2-TS files that I want to batch encode and it's cumbersome to select and queue each one. Can I pass "ls" to AutoMen, or can you modify it to accept all files in a directory or all files with a certain extension? Thanks!
Old 6th November 2008, 17:50   #7  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
h264enc is also a working mencoder frontend, although a CLI one. It can do much more than AutoMen for Linux can do
Old 6th November 2008, 17:51   #8  |  Link
buzzqw
HDConvertToX author
.. it should accept a "list.txt" of file (with full path) ...
but never tryed on linux build (automen for linux is a porting of automen.. for windows)
please report if working.. i will try when at home
BHH
Old 6th November 2008, 20:53   #9  |  Link
mocham
Actually I use your script all the time, it's the only thing that I find usable for one-off conversions. The batch mode is slightly cumbersome. I tend to want to batch convert a bunch of files with the same settings. There seems to be more frontends and scripts that can do this with ffmpeg but not mencoder.
Old 7th November 2008, 00:23   #10  |  Link
microchip8
microchip8's Avatar
Yes I know. Decent batch processing is a bit difficult to implement in a shell script. What you can do though is configure one file and save the settings to the batch file. Then open up the batchfile and paste over and over again the blocks for each file you want to encode. The only thing you actually need to change in each block of commands, is the input and output file, and if you're remuxing from AVI to MKV or MP4, also change the input and output there
automen, linux, mencoder
