Old 14th May 2009, 03:42   #1  |  Link
880
VOBInput.dll truncates audio...
I tried to decode Dolby Digital audio from AC3 in a VOB file to PCM WAV (also convert 5.1 down to stereo). I found that when I used VOBInput.dll (version 1.3.0.0) it stopped encoding six minutes before the audio ended.
Then I demuxed the AC3 with VobEdit, and used just the AC3 with BeSweet. That worked fine. Both logs are below.
VOBInput.dll which failed
BeSweet v1.4 by DSPguru.
Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org)
Using azid.dll v1.8 (b825) by Midas  (midas@egon.gyaloglo.hu).
Using hip.dll v1.13 by Myers Carpenter <myers@users.sf.net>
Logging start : 05/13/09 , 21:20:12.
BeSweet.exe -core( -input G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.vob -output G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.wav -2ch -logfile G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.log ) -azid( -s stereo -c normal -L -3db ) -ota( -d 400 )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] |  Input : G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.vob
[00:00:00:000] |  Output: G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.wav
[00:00:00:000] |  Substream ID: 0x80
[00:00:00:000] |  Floating-Point Process: No
[00:00:00:000] |  A/V Delay found : 401msec
[00:00:00:400] +-------- AZID -------
[00:00:00:400] |  Output Stereo mode: Stereo
[00:00:00:400] |  Total Gain: 0.000dB, Compression:  Normal
[00:00:00:400] |  LFE levels: To LR -3.0dB, To LFE 0.0dB
[00:00:00:400] |  Center   mix level: BSI
[00:00:00:400] |  Surround mix level: BSI
[00:00:00:400] |  Dialog normalization: No
[00:00:00:400] |  Rear channels filtering: No
[00:00:00:400] |  Source Sample-Rate: 48.0KHz
[00:00:00:400] +---------------------
[00:36:40:816] Conversion Completed !
[00:36:40:816] Actual Avg. Bitrate  : 1536kbps
[00:01:06:000] <-- Transcoding Duration
Logging ends : 05/13/09 , 21:21:18.
BeSweet alone which worked
Logging start : 05/13/09 , 21:27:29.
BeSweet.exe -core( -input G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.ac3 -output G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.wav -2ch -logfile G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.log ) -azid( -s stereo -c normal -L -3db ) -ota( -d 400 )
[00:00:00:000] |  Input : G:\Lost_RiffTrax\Ep1 VIDEO_TS\VTS_01_1.ac3
[00:00:00:400] |  Input Channels Mode: 3/2, Bitrate: 448kbps
[00:42:17:136] Conversion Completed !
[00:42:17:136] Actual Avg. Bitrate  : 1536kbps
[00:01:12:000] <-- Transcoding Duration
Logging ends : 05/13/09 , 21:28:41.
880 is offline   Reply With Quote
Old 14th May 2009, 11:29   #2  |  Link
tebasuna51
tebasuna51's Avatar
These soft are abandoned (BeSweet and the bugreport in http://www.dvd2svcd.org/ for VOBInput.dll don't work), use DGIndex to extract ac3 (or also decoded wav with or without downmix) from VOB files.
ac3, besweet, vob, vobinput
