Old 20th February 2019, 14:16   #54881  |  Link
alexnt
So which decoder should I use?
I 'm talking about AVC files, I only download a sample of HEVC file.
Can someone post a screenshot of mpc->options->internal filters?
alexnt is offline   Reply With Quote
Old 20th February 2019, 14:24   #54882  |  Link
clsid
DXVA2 copy-back
Just enable all internal filters.
Old 20th February 2019, 14:27   #54883  |  Link
Originally Posted by madjock View Post
Ah ok, well I guess thats where all these guides and comments mess things up, as usually its the first thing people recommend.
i know and will have a bright future one day but that day isn't here yet and there is nothing nev can do about the issue is on madVR side.
DXVA copyback or D3D11 copyback whatever works best for you.
the mpc->option->internal filter should be left at default default settings are default for a reason.
there is an rumour that intel HD 4600 can do HEVC 8 bit which should be rarely of any use but still.
so D3D11 copyback with HD 4600 should give you the most powerful decoder on your system.
Old 20th February 2019, 14:27   #54884  |  Link
madjock
Yeah lets not talk about this part...
"I have a 4690k and r9 290 and I know(because I have seen it) that madvr did't behave with the same way in the past."
Windows 10-1809 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 385.28 | Yamaha RX-V377 | Philips 65PUS6703 - 65"
Old 20th February 2019, 14:41   #54885  |  Link
alexnt
Asked because I have seen some guides that disable everything in transformation filters part.
Old 20th February 2019, 14:49   #54886  |  Link
the internet is a wild place and there are reason to do that i even have disabled them myself.
but and that important it there is no reason todo that if you are not playing around with test/beta version and testing other stuff.
the internal lavfilter version is fine. if there is a major change you can count on clsid that he will release a new mpc-hc version that is updated.
Old 20th February 2019, 14:50   #54887  |  Link
clsid
Pretty much every guide out there is full of bad advice.
As a rule of thumb:
Don't change any default settings unless you understand what a setting does and why changing it makes things better for you.
Old 20th February 2019, 15:01   #54888  |  Link
el Filou
el Filou's Avatar
@alexnt If it still happens after the whole reinstall and reset settings, post a screenshot of Task Manager's 'details' tab sorted by CPU usage.
You can also get Process Explorer from the Windows SysInternals tools suite to get more details
HTPC: W10 1803, E7400, 1050 Ti, DVB-C, Denon 2310, Panasonic GT60 | Desktop: W10 1809, 4690K, HD 7870, Dell U2713HM | MediaPortal 1/MPC-HC, LAV Filters, ReClock, madVR
Old 20th February 2019, 15:19   #54889  |  Link
madjock
I think we know why the CPU is so active now
AMD r9 290 does not support hardware acceleration of HEVC/H.265, nor does it do 4K H.264. So that's the simple reason for high CPU usage.
Old 20th February 2019, 16:06   #54890  |  Link
alexnt
OK guys I believe I found the culprit. It was that key in registry.
Everything works as intended though I tested through remote desktop. I told you that it was not a normal behavior.
Thank you all for your time.
Why the uninstaller doesn't remove that key???
Old 20th February 2019, 16:16   #54891  |  Link
would you risk deleting advances profiles from user just by installing the software? some have advanced uninstall options for that but i would leave it there.
and the real way to reset setting isn't uninstalling software it is using the reset option.
Old 20th February 2019, 16:19   #54892  |  Link
alexnt
reset didn't do the job
Old 20th February 2019, 16:22   #54893  |  Link
madjock
Surely your CPU usage will still be the same as your card does not decode these files, and thats what your original query was ?
Old 20th February 2019, 16:26   #54894  |  Link
alexnt
No the cpu usage is not the same as I don't have hevc files. My movies are avc except for that hevc sample I downloaded yesterday for testing purposes. I ll upload a video proof later.
Old 20th February 2019, 16:32   #54895  |  Link
tp4tissue
tp4tissue's Avatar
restore default settings.bat
this resets madVR including the registry you can find it in the madVR folder.
next you are playing an HEVC file with an R9 200 series card? then the CPU has to do the work this GPU doesn't support HEVC. the video has to be decoded that'S not madVR job.
there are settings that can use quite a lot of CPU cycles.one would be black bar detection.
and don't recommend DXVA native with it madVR can't deal with interlaced content at all. as long as this isn't fixed it shouldn't be blindly recommended to user if there is an alternative that works with all kind of normal content.
On one of my pcs, the restore setting. bat actually doesn't work. It's weird, and I never figured out why it didn't work ?
I've never moved the directories, so where are these settings stored ?
Ghetto | 2500k 5Ghz
Old 20th February 2019, 16:33   #54896  |  Link
tp4tissue
tp4tissue's Avatar
Wait wait wait,, I thought the Great Huhn, Only recommends DX11. no one dare challenge Great huhn
Under what case does Dxva2 work better than DX11
Ghetto | 2500k 5Ghz
Old 20th February 2019, 16:34   #54897  |  Link
madjock
No its fine I believe you, but it looked like you were playing h.264 files in the screenshots and I thought the card could not decode them, but I just read something that said it can, but still not sure about the CPU.
As long as you are happy thats all that matters
Old 20th February 2019, 16:47   #54898  |  Link
did you try it as an admin?
no need for a video proof i already said stuff like blackbar detection can eat CPU cycles which is off by default there are other things too.
why don't you quote me on that with context?
https://forum.doom9.org/showpost.php...ostcount=54917
Old 20th February 2019, 16:48   #54899  |  Link
alexnt
I play 264 indeed, not 265. My gpu can't decode 265 as I was informed today.
If I have time I will upload this video.
Thanks again for the reg key
Old 20th February 2019, 16:51   #54900  |  Link
tp4tissue
tp4tissue's Avatar
So is DX11, the Go-To under all circumstances outside of Interlaced.
Ghetto | 2500k 5Ghz
