Old 26th March 2008, 10:44   #1041  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Please send me 50 Mb TS sample
Old 26th March 2008, 13:36   #1042  |  Link
ajamils
Originally Posted by ajamils View Post
@Atak,
Will it be possible for you (or someone who know what they are doing) to create a tutorial for converting 720p & 1080p file to Ps3 recognizable format (with 5.1 surround) for all the newbies like me ?
Even though your software is straight forward, I'm not having 100% success in conversion because I do not know what all the options mean and which ones should I select.
tutorial ???
ajamils is offline   Reply With Quote
Old 26th March 2008, 13:59   #1043  |  Link
survivant001
Whyyyyyyyyyyy ? Is that hard to burn directory directly in IMGBurn????
Why do you always write ajak?
to save a step on opening nero.. drag and drop.. burn
just double click on the iso.. I'm lazy
ajak.. ah aha h.. it's a typo. sorry
survivant001 is offline   Reply With Quote
Old 26th March 2008, 14:44   #1044  |  Link
Atak_Snajpera
I'm lazy too
Old 26th March 2008, 14:57   #1045  |  Link
~bT~
н∂-αиαтι
wot tutorial do u want. ripping to what format?
Old 26th March 2008, 14:57   #1046  |  Link
ajamils
I'm lazy too
I'm sure you can find enough strength to do a tutorial
Old 26th March 2008, 15:12   #1047  |  Link
ajamils
Tutorial about what settings to use for converting 720p and 1080p files for Ps3 without the loss of PQ or surround sound.
Old 26th March 2008, 16:55   #1048  |  Link
Ryu77
Ryu77's Avatar
Just do some research on the x264 codec and learn what the settings mean. Then research DTS and AC3 audio... Google, google and more google.
If you are unclear about output formats, look up (google) these terms m2ts, Blu-ray and AVCHD.
From there you should be clued in enough to use RipBot264 and get the desired results.
Oh and by the way use google!
Ryu77 is offline   Reply With Quote
Old 26th March 2008, 17:06   #1049  |  Link
ajamils
Thanks for the advise but like other people here....i'm lazy too
Old 26th March 2008, 17:59   #1050  |  Link
Ryu77
Ryu77's Avatar
With all due respect, I feel Atak said that out of cheekiness to you first making the "I'm lazy" statement.
Do you really think Atak is lazy with all the improvements he is making to RipBot264?
Again, no disrespect intended but how do you expect others to create a guide for you, if you wont put in a little bit of effort to learn some fundamentals required to even understand a guide if one was in fact created?
Old 26th March 2008, 18:29   #1051  |  Link
ajamils
I said it as a joke too and it was not meant to disrespect anyone. As for me asking about the tutorials, I just thought that it would be beneficial for all the new people to learn from the experiences of people like you(currently reading your threads on Afterdawn forum) and Atak instead of them spending many hours learning it themselves cuz after all not everyone has the same level of intelligence .
As for me being lazy, I've spent COUNTLESS hours reading different forums (to a point where my girl is getting annoyed because I spend more time reading forums than watching movies that we already have on Blu-ray ) and trying out different software/scripts to make things work and I'm still not 100% successful and that's why I wanted input for the the experts so that I at least have one side covered, while I learn/understand other ways of doing the same process.
Old 26th March 2008, 18:45   #1052  |  Link
~bT~
н∂-αиαтι
here, i made a lil tut for the lazy ones out there
http://maxupload.com/36F6A3B4
its a flash guide. make sure you have flash installed on your system. now don't ask me for a tut on that
Old 26th March 2008, 19:05   #1053  |  Link
ajamils
You that MAN !!! Thank you sir. Gonna check it out right now.
Old 26th March 2008, 19:16   #1054  |  Link
ajamils
Ok just watched the tut. Good stuff !! Now I have the following question
1) Why did you select output as "Blu-ray Disc" ? Wouldn't mp4 be better if I just want to copy the file to Ps3 instead of creating the whole Blu-ray structure (my understanding is that "Blu-ray Disc" output creates the whole file structure for a Blu-ray" and that's only if I want to "burn" the movie to a disc")
2) What does "CQ" under mode and "CRF" means ? Do we ever use that for converting movies for Ps3 ?
3) Why do we have to select "Lock Size" and "Size" (on the properties page?
Sorry for the newbie question and thanks again for the tut.
Old 26th March 2008, 19:27   #1055  |  Link
Atak_Snajpera
1) in order to get *.m2ts (AVC+5.1 sound). It can be copied on PS3 HD.
2) CQ means Constant Quality. CRF = Constant Rate Factor.
3) In order to use whole space on disc. Blu-Ray allows only two resolutions 1080p and 720p
Old 26th March 2008, 19:36   #1056  |  Link
ajamils
Thanks for the reply.
1) So if I use *.mp4, I will not get 5.1 sound ? Also, the Blu-ray mode outputs a folder, is the *.m2ts file inside it ? If so, I can just copy that file to Ps3 and everything will be ok ?
2) So we do not use CQ or CRF for blu-ray ?
Old 26th March 2008, 19:41   #1057  |  Link
Atak_Snajpera
PS3 probably still downmix to 2.0. ( I haven't checked that with latest firmware ...)
If you don't care about final size use CQ@22 otherwise if you are going to fit your movie on DVD then you must use 2-pass!
Old 26th March 2008, 20:02   #1058  |  Link
ajamils
I converted Rush Hour 3 to mp4 with AC3 audio and Ps3 info showed 5.1 Dolby (that was before the latest update). Also, since I'm not gonna burn a movie to DVD, will using SQ@22 take more time than the other option ?
Will the quality be the same with 2-pass or CQ@22 ?
(I'm sure I'm starting to annoy you with all the questions )
Old 26th March 2008, 20:08   #1059  |  Link
~bT~
н∂-αиαтι
^ yes, coz ur not trying to understand why we do things the way we do.
Old 26th March 2008, 20:18   #1060  |  Link
Atak_Snajpera
PS3 sees AC3 in mp4 container??? DTS as well???
Read MeGui tutorials ok?
