Old 2nd September 2007, 09:21   #81  |  Link
Schrade
Schrade's Avatar
Originally Posted by bmnot View Post
What's the best method (top, bottom field) to de-interlace 480i DVD vob's when converting them with ripbot? I don't know the difference.
DVD video is generally Top Field First. DV video from camcorders is almost always Bottom Field First.
Schrade is offline   Reply With Quote
Old 2nd September 2007, 14:15   #82  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
@Ichika
Hey, I really like this program you've made, but I was wondering why you add a border of 2 pixels at the bottom when resizing to any of the PSP resolutions?
PSP always removes 2 bottom lines and then centers picture on the screen. Try to replace original Addborders with this AddBorders(0,0,0,2,255). You will see blue lines at the bottom but they are not visible on PSP.
And for the new version, the "-1.25" parameter in TextSub just makes my subs out of sync.
Try to change default 25 value to 23.976 or 29.97
and some avi's as well but it's just the info.txt error that some others have been getting, though these avi's load fine on my friend's computer
I know that issue from the begining. Sometimes Windows does not allow to write info.txt. Try to restart your PC and do not open RipBot264temp directory. Also make sure your path and filenames do not contain national characters like ą,ż,ź,ń, and so on
Atak_Snajpera is online now   Reply With Quote
Old 5th September 2007, 12:37   #83  |  Link
max24
Is the function to be read in planned files AVS and to Encoden. If I was glad about it! Nice program Thanks
max24 is offline   Reply With Quote
Old 12th September 2007, 22:54   #84  |  Link
Atak_Snajpera
v1.5.0 is now available
Good advice for people encoding TS files. I highly recommend to scan stream for errors before encoding. You can use Transport Stream Packet Editor (TSPE). If you want to demux audio use xport. BTW Annoying problem with missing file info.txt has been fixed finally
Old 13th September 2007, 00:05   #85  |  Link
MarcioAB
MarcioAB's Avatar
Hello,
Version is 1.5.0
1) Is that possible to open an avisynth script (avs) ? (how).
2) Receiving "invalid point operation" when trying to open any video (mp4).
Thank you.
MarcioAB is offline   Reply With Quote
Old 13th September 2007, 00:20   #86  |  Link
Atak_Snajpera
Stupid bug with decimal symbol. I will fix that in couple minutes.
Sorry but script cannot be opened by RipBot264. My app is designed to generate AVS script automatically. However you can copy necessary lines to Script editor.
Old 13th September 2007, 00:24   #87  |  Link
deets
cool i noticed that as well
deets is offline   Reply With Quote
Old 13th September 2007, 00:29   #88  |  Link
Atak_Snajpera
I forgot to check if new version is working with other decimal symbol than "." I assume you use ","
Fixed version will be available after midnight
Old 13th September 2007, 02:49   #89  |  Link
The Scientist
The Scientist's Avatar
I get this as soon as I run (on Vista x86) the program:
The Scientist is offline   Reply With Quote
Old 13th September 2007, 07:43   #90  |  Link
Atak_Snajpera
I also use vista but I have never seen something like this
Old 13th September 2007, 10:11   #91  |  Link
AMED
AMED's Avatar
i got a this at startup as well, XP SP2
After i click ok, ripbot seems to open fine but when i open a .VOB is get this.
is there any chance of getting support for nero aac encoder?
A Man Eating Duck
AMED is offline   Reply With Quote
Old 13th September 2007, 15:02   #92  |  Link
deets
is the fixed version up so i can add to the site
i didnt get any error on vista 64 except the floating point one
Old 13th September 2007, 21:36   #93  |  Link
Atak_Snajpera
I've just came from work...
Floating point has been fixed. Download v1.5.0 again. Sorry guys but I couldn't connect to forum.doom9.org yesterday night so I wasn't able to post anything. Let me know if you still have that strange error.
I doubt you will hear difference between CT and nero. Some people even claim that CT gives better quality in HE than nero.
Old 13th September 2007, 23:19   #94  |  Link
The Scientist
Same error here.
Old 13th September 2007, 23:31   #95  |  Link
Atak_Snajpera
try with this
http://www.mediafire.com/?ajfo5tdeym2
Old 13th September 2007, 23:42   #96  |  Link
The Scientist
Still no good.
The program *does* run after this error.
Old 13th September 2007, 23:53   #97  |  Link
Atak_Snajpera
This error appears only if you use limited account (Guest or Standard User for example). Try with administrator account or set compatibility to XP SP2
Old 14th September 2007, 00:14   #98  |  Link
deets
yeah i still get the floating point error with the new version and just the exe download using vista 64
Old 14th September 2007, 00:17   #99  |  Link
Atak_Snajpera
Could you make a screenshot? I really don't know what to say? Yesterday I made few encodings for PSP with "." and "," set in windows (Regional and Languages Options) and everything was ok!
Old 14th September 2007, 01:04   #100  |  Link
deets
http://www.bontragerphotography.com/rip.png
the error screen?
