31st December 2005, 12:02 | #21 | Link | |
Starting from AviSynth v2.5. If some filters doesn't support a specific sample type, they are converted to the format preserving most quality (most often floats). Float samples are also automatically converted back to 16bit before delivering them as output. SoxFilter converts audio to 32 bit integers. Amplify: 8bit and 24bit Audio samples are converted to float in the process, the other audio formats are kept. Normalize: The audio sample type is converted to float or is left untouched if it is 16 bits. SSRC Shibata Sample Rate Converter is a resampler. Audio is always converted to float. ... Then a first conversion to a specific format don't guarantee maintain this format along a DSP function. We can analyze each DSP to search the optimum format. |
2nd January 2006, 04:53 | #23 | Link |
I don't understand how does it work.
I want to know how to do any format to ac3 output. Could it be reached from command line? Is ac3 output configurable (channels, hz, kbps, etc.) Once the script is created, with which app i will obtain the final ac3 audio file? TIA.
Prodater64 |
2nd January 2006, 11:58 | #24 | Link | |
c{2}=last with: c{2}=ConvertAudioToFloat(last) All internal plugins used (GetChannel, MixAudio, Amplify and MergeChannels) support float format (also Normalize if you want use this DSP after the Downmix). In a simple test the differences between the int16 and float methods are below 0.0001 (-80.76 dB) |
3rd January 2006, 15:22 | #25 | Link | |
FAVC Man
8th January 2006, 14:30 | #26 | Link |
BeHappy New Year!
I make some mod's to BeHappy and I have also a petition, all included in: http://personal.telefonica.terra.es/...a/behappym.zip Here is a brief description: 1) I don't know how generate UniqueID, then for new extension I copy the Downmix UniqueID and I make a little change. Works for me. 2) Downmix: Mod <AudioDSP> Append DPL I option and c{2}=ConvertAudioToFloat(last) in <ScriptPrologue> 3) SSRC: New <AudioDSP> multioption. The samplerate conversion utility. 4) Mono -> Stereo: New <AudioDSP> without comment. 5) TimeStretch: New <AudioDSP> Only to check this function with 'tempo' parameter and two common presets. Maybe we need a complex emergent window to select between the three parameters 'tempo', 'pitch' and 'rate' and their associate values (like Belight 'SoundTouch'). At last the most used 'tempo' need a capture box to put manualy exact values (a slider don't work). Maybe at 'Tweak' section?. 6) MPASource: New <AudioSource>: Tested this decoder plugin (avisynth.org) and work ok for mp3 and mp2 inputs. 7) ffmpeg MP2: New <AudioEncoder>: Tested ffmpeg like mp2 encoder. 8) TODO: We can use avs input to emulate the BeSweet input .mux (6 mono wav like input), with this merge.avs: m1 = WAVSource("D:\Test\Mono_FL.wav") m2 = WAVSource("D:\Test\Mono_FR.wav") m3 = WAVSource("D:\Test\Mono_C.wav") m4 = WAVSource("D:\Test\Mono_LFE.wav") m5 = WAVSource("D:\Test\Mono_SL.wav") m6 = WAVSource("D:\Test\Mono_SR.wav") MergeChannels(m1, m2, m3, m4, m5, m6) But I don't know how split a multichannel wav in mono wavs with BeHappy. Maybe Dimzon can include a new 'Destination' item 'Mono wavs Writer' inside BeHappy code, or anybody can make a 'decoder' with standar input support. I think is easy to do, but out of my knowledge. I only can can write a simple standalone app to do this job with a multichannel wav file input, included (Wav2mono.zip) in behappym.zip. I appreciate test and comment. |
10th January 2006, 11:35 | #27 | Link | ||||
BeHappy/MeGUI developer
Unfortunally I can't download it now Quote:
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
10th January 2006, 14:12 | #28 | Link | |
Thanks for the reply.
I tried TooLame v0.2k and v0.2l. The unique partial success I get is with TooLame v0.2l and this parameters: <ExecutableArguments>- "{0}"</ExecutableArguments> Partial because: - TooLame don't read the header and is treated as raw PCM, then there are a initial click and the data is treated as 44100 (default for TooLame) - Insert a: <UseRawPCM>true</UseRawPCM> seems don't work for this kind of extension. - Insert a parameter to override the default 44100 like: <ExecutableArguments>-s 48000 - "{0}"</ExecutableArguments> or <ExecutableArguments>- -s 48000 "{0}"</ExecutableArguments> Produce a: Error: Can't start encoder: Cannot process request because the process (1644) has exited. - With TooLame v0.2k the parameters: <ExecutableArguments>- "{0}"</ExecutableArguments> work without errors but the encoded file is incorrect (a click and a short silence). - Any other combination of parameters produce errors like: Error: Abnormal encoder termination 1 OR Error: Can't start encoder: Cannot process request because the process (596) has exited. Maybe I don't found the correct method. |
14th January 2006, 10:26 | #29 | Link | |
I asked a question on jan/2 http://forum.doom9.org/showthread.ph...695#post760695
Could somebody answer me, please. Quote:
Prodater64 |
14th January 2006, 13:11 | #30 | Link | |||||
http://forum.doom9.org/showthread.php?t=103069 Basically: 1) Open/Decode any audio source to obtain a uncompressed audio. You can use a specific audio decoder plugin (NicAudio for dts/ac3, MpaSource for mp2/mp3) or the generic DirectShowSource then the adequate installed filter is used. If you have ffdshow installed you can use Audio decoder configuration facility. 2) Use any DSP or Tweak option to modify the uncompressed audio. Then you can: Delay, Split, Downmix, Resample (SSRC), Stretch, Amplify, Normalize, ...(the Upmix option don't work now). 3) Recompress the audio (or save as wav) with any of the tested encoders. Quote:
2) Apply the desired DSP and/or Tweak options. (maybe nothing) 3) Select the output filename and ffmpeg ac3 encoder 4) Add to Job Control and run the job (in Job Control window) Quote:
16th January 2006, 18:42 | #31 | Link |
Tested TwoLAME 0.3.3 Release 2005-06-09, (The fork of the tooLAME project. ICL4.5), from http://www.rarewares.org/mp3.html
It work fine with BeHappy and is based in TooLAME 0.2mbeta, then can be used instead ffmpeg for mp2 encoder. There are new version 0.3.4 and 0.3.5 (Last updated 29-Nov-2005) in http://www.twolame.org/ , but I don't found any Windows compiled exe. Included in http://personal.telefonica.terra.es/...a/behappym.zip with other minor changes (interested see the readme inside the zip). |
16th January 2006, 18:47 | #32 | Link | |
16th January 2006, 18:55 | #33 | Link |
@Dimzon
Upload bhappym.zip: http://www.mytempdir.com/388248 |
16th January 2006, 19:05 | #34 | Link | |
according documentation SSRC can't convert any samplerate to any another. http://www.avisynth.org/SSRC but You can use ResampleAudio http://www.avisynth.org/ResampleAudio So I think better solution will be to write more intellectual function. It must check: does SSRC applicable to this samplerates and use ResampleAudio if not
23rd January 2006, 07:16 | #36 | Link |
great work dimzon. i switched over to behappy from besweet as encoding with nero 7's aac was becoming too difficult with besweet.
just one question - is it not possible to do 2-pass encoding with your tool because of the stdin input? |
23rd January 2006, 09:21 | #37 | Link | |
24th January 2006, 11:42 | #39 | Link | |
29th January 2006, 01:02 | #40 | Link |
Really liked the idea behind behappy and looking forward to the upmix option (if it is possible).
I had a question about the bepipe command line utility. Currently I am upmixing audio for recorded TV. I have been using fbr2k with a dsp plugin to convert and write the 6 channel wave. Then I was pluggin the wave into behappy to get the correct ac3 file. I tried to go directly from the mp2 to the ac3 in fb2k but can't because of the ac3 channel mapping problem. I had the idea of calling bepipe from fb2k to remap (i think its just frameserving) the audio and encode with ffmpeg. To see if it could worked I tried to get bepipe working from the command prompt with the following command line: BePipe.exe --script "WavSource(^incorrect.wav^) AudioDubEx(BlankClip(length=Int(1000*AudioLengthF(last)/Audiorate(last)),width=32,height=32,pixel_type=^RGB24^,fps=1000),last) 6==Audiochannels(last)?GetChannel(last,1,3,2,5,6,4):last AudioDubEx(Tone(),last)" | ffmpeg.exe -i - -y -acodec ac3 -ab 448 "correct.ac3" <incorrect.wav No luck. runs fine but doesn't remap the channels. Any suggestions? |
behappy |
