Old 6th May 2006, 01:24   #201  |  Link
Kostarum Rex Persia
Banned
Very very nice, Dimzon.
Can you give me download link to newest BeHappy beta with this new ND AAC dialog? Direct link, if possible.
Thank you.
Kostarum Rex Persia is offline   Reply With Quote
Old 6th May 2006, 01:48   #202  |  Link
tebasuna51
tebasuna51's Avatar
To avoid the problem for wav's > 4GB and neroAacEnc
http://forum.doom9.org/showthread.ph...985#post823985
"I check wav's > 4GB with any value in DataLength and +36 in RiffLength and always work with neroAacEnc -ignorelength, then the problem is use same value for the two fields.
For BeHappy the solution is fill DataLength with 0xFFFFFEDC (0xFFFFFF00 - 36)."
Old 6th May 2006, 06:31   #203  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Thank you.
It is not complete yet, wait for 1-2 week...
dimzon is offline   Reply With Quote
Old 7th May 2006, 12:42   #204  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@dimzon i founded one small bug into enc_aacPlus.exe. When use LC-AAC and MP4 container i get fake SBR which have 88.2kHz instead 44kHz and in foobar says that is SBR present but insn't when i remuxed this file with YAMB everything is fine, that is probably because you forgot to clear switch -sbr in mp4box comandline for LC-AAC.
shon3i is offline   Reply With Quote
Old 7th May 2006, 15:44   #205  |  Link
tebasuna51
tebasuna51's Avatar
@Dimzon
Good news at http://forum.doom9.org/showthread.ph...472#post824472
New ffmpeg CVS_2006-04-28 works with BeHappy and preserve the 100% original wav volume. In my first test new ffmpeg is better than HeadAC3he v0.24-a13 with 6 db gain.
Old 8th May 2006, 08:37   #206  |  Link
thuongshoo
HI dimzon! . No program can know He-AAC
thuongshoo is offline   Reply With Quote
Old 8th May 2006, 10:12   #207  |  Link
jjseth
jjseth's Avatar
Here is a simply and basic BeHappy MusePack extension.
http://d.turboupload.com/d/584079/mpcextension.rar.html
The extension and the mppenc.exe from www.musepack.net must be in the BeHappy folder of course.
@dimzon:
Maybe you want improve the extension (change the uniqueID, or add a logo), or reject it
SethNet.tk
MKVextractGUI
Smile, tomorrow will be worst
Sorry my poor english
jjseth is offline   Reply With Quote
Old 8th May 2006, 10:21   #208  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
That is everything fine, that is MP4 container bug.
Old 8th May 2006, 11:24   #209  |  Link
tebasuna51
tebasuna51's Avatar
Hi Shet!. Nice to meet you here.
Thanks for your contribution. Works fine, and also .mpc decode is well supported by BassAudio.
Old 8th May 2006, 11:37   #210  |  Link
jjseth
jjseth's Avatar
Hi tebasuna51!!! Nice to meet you too.
My posts in Doom9 are a rara avis cause my english is ¿?¡?¿T?¿¡()((... but i'm an "always on" reader.
SethNet.tk
MKVextractGUI
Old 9th May 2006, 02:08   #211  |  Link
NorthPole
Originally Posted by dimzon
If You need some fix/improvement please let me know ASAP!
Just had a couple of suggestions if you have a chance.
Anyway to get a "Clear All Jobs" on the job control page.
(now you have to delete jobs one at a time)
Also, have the destination filename change to match the source filename anytime it changes after the inital selection.
(I usually convert 3 - 5 files at a time.)
Otherwise, I like it the way it is now. Thanks again.
NorthPole is offline   Reply With Quote
Old 9th May 2006, 02:10   #212  |  Link
NorthPole
Thanks for the tip.
Old 9th May 2006, 05:56   #213  |  Link
thuongshoo
really ? shon3i! What do you base on when you say that ?
I regret a thing that I dont know any program which can read AAC files except Gspot. Zen( author of MediaInfo) says that reading AAC files is a request
Old 10th May 2006, 13:22   #214  |  Link
buzzqw
HDConvertToX author
Hi Dimzon !
I would like to know if there is any update to BePipe ! i would use it in my mkvmagic (if you agree)
thanks
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 10th May 2006, 19:27   #215  |  Link
buzzqw
HDConvertToX author
sorry to bother but i have some problem with enc_AudX_CLI.exe
C:\Programmi\PureBasic\Prove>BePipe.exe  --script "import(^test.avs^)" | enc_AudX_CLI.exe - qqq.mp3
--q 2
 Aud-X multichannel encoder CLI frontend
 this algorithm has been prepared by: [Aud-X Team www.aud-x.com]
 BePipe by dimzon
Script used:
# BEGIN
import("test.avs")
# END
Scanning for Audio Stream...
Found Audio Stream
Channels=6, BitsPerSample=32, SampleRate=48000Hz
Writing Header...
Writing Data...
0%      System.NotSupportedException: Il flusso non supporta la ricerca. ---> "stream doesn't support seek" i can translate
   in System.IO.__Error.SeekNotSupported()
   in System.IO.__ConsoleStream.get_Position()
   in enc_AudX_CLI.WaveFormat.ReadWavHeader(BinaryReader reader)
   in enc_AudX_CLI.Main(String[] args)
Done!
this is my test.avs
loadplugin("C:\Programmi\PureBasic\Prove\exe\filter\nicaudio.dll")
nicac3source("C:\Programmi\PureBasic\Prove\aaa.ac3")
the same script is fine wth oggenc/lame/neroaacenc.exe
any suggestion ?
thanks
BHH
Edit: typos
Old 10th May 2006, 19:54   #216  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Did you have installed lastest Aud-X codec.
Old 10th May 2006, 20:19   #217  |  Link
buzzqw
HDConvertToX author
i use audxlib.dll and enc_AudX_CLI.exe present in enc_AudX_CLI.zip on dimzon gotnet page.
need i something other ?
BHH
Old 11th May 2006, 00:44   #218  |  Link
tebasuna51
tebasuna51's Avatar
The last alpha Bepipe still have the bug writing wav headers detected for BeHappy in my post:
http://forum.doom9.org/showthread.ph...076#post758076
Maybe enc_AudX_CLI.exe detect the error and abort. See the routine name in log:
" in enc_AudX_CLI.WaveFormat.ReadWavHeader"
Others encoders may ignore the error (isn't a important parameter).
In any case, I agree with buzzqw, Bepipe can be used in others app. (see NeroAacEnc thread) and may need a update.
Old 11th May 2006, 07:11   #219  |  Link
buzzqw
HDConvertToX author
@tebasuna51
Thanks for the info.
since avs2wav isn't so good i will hope in bepipe update !
BHH
Old 13th May 2006, 19:00   #220  |  Link
dimzon
dimzon's Avatar
@Dimzon
WOW! Really good news! Thanx a lot!
enc_AudX_CLI.exe bug will be fixed a little later...
behappy
