Old 7th May 2017, 22:21   #201  |  Link
dapperdan
Did the Netflix rep say they were supporting work on the Eve encoder and seeing an extra 5% improvement? That's pretty cool.
dapperdan is offline   Reply With Quote
Old 8th May 2017, 09:06   #202  |  Link
easyfab
http://www.streamingmediaglobal.com/...ticleID=118062
OT @dappedan
"he mentioned that they weren't using the stock open-source VP9 encoder available from Google. Rather, they were encoding with technology from a company called Two Orioles, which was founded by Ronald Bultje, a lead VP9 developer. Ronca mentioned that in particular, Netflix had found that the open-source VP9's two-pass rate control mechanism was suboptimal, and that Bultje's encoder is currently about 8% more efficient than Google's."
/OT
"Google's Frost claimed that AV1 was currently 30-35% more efficient than VP9"
Is correct that's nice .
easyfab is offline   Reply With Quote
Old 8th May 2017, 12:53   #203  |  Link
dapperdan
That does introduce ambiguity into their comments about e.g. AV1 is 20% better than VP9, do they mean libvpx or eve encoded VP9? Since that could mean a further 8% difference.
Old 20th May 2017, 14:34   #204  |  Link
Gravitator
I do not get normal (smeared squares) AV1 playback through tmodLAV.
Samples > https://www.elecard.com/videos
Gravitator is offline   Reply With Quote
Old 20th May 2017, 14:51   #205  |  Link
mzso
Which other options are there to play AV1 videos?
Old 20th May 2017, 14:53   #206  |  Link
sneaker_ger
You are dealing with experimental software and the bitstream hasn't been frozen yet. A sample created with yesterday's encoder might not work with today's decoder. Such things are expected. If you think you found a "real" bug in either encoder or decoder report it to the developers.
Old 20th May 2017, 15:10   #207  |  Link
Gravitator
Elecard MPEG Player (only my processor can not cope - it slows down).
Old 20th May 2017, 15:13   #208  |  Link
mzso
Do you know of recent samples one can download?
Old 20th May 2017, 15:17   #209  |  Link
sneaker_ger
I don't.
Old 20th May 2017, 16:30   #210  |  Link
wiak
here is the thing "its not finished, so a newer or older decoder will not work, it has to be exact"
there is one way to do it, its to encode a file and use
./aomdec file.webm| mpv -
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview)
"Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat
wiak is offline   Reply With Quote
Old 1st June 2017, 17:58   #211  |  Link
stax76
stax76's Avatar
How does 2 pass work?
D:\Projekte\VS\VB\StaxRip\bin\Apps\ffmpeg\ffmpeg.exe -i D:\Temp\staxrip\Eli_temp\Eli.avs -f yuv4mpegpipe - | D:\Projekte\VS\VB\StaxRip\bin\Apps\aomenc\aomenc.exe - --passes=2 --pass=1 --target-bitrate=1167 -o D:\Temp\staxrip\Eli_temp\Eli_out.webm
av_interleaved_write_frame(): Broken pipe
Error writing trailer of pipe:: Broken pipe
frame= 1 fps=0.0 q=-0.0 Lsize= 191kB time=00:00:00.03 bitrate=46971.0kbits/s speed=0.0618x
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 39397.984375%
Conversion failed!
Old 1st June 2017, 18:06   #212  |  Link
wiak
Conversion failed!
1. you cant pipe
2. its default
3. so far i know
Old 1st June 2017, 18:17   #213  |  Link
stax76
stax76's Avatar
Is there a avs/vs reader then?
Old 1st June 2017, 18:19   #214  |  Link
sneaker_ger
I vaguely remember you having the same problem with the VP9 encoder. With auto-2pass piping doesn't work because it cannot rewind the pipe. But manual 2pass should be possible or is that feature not available in the AV1 encoder? Or does it really not support pipe input at all?
Old 1st June 2017, 18:21   #215  |  Link
stax76
stax76's Avatar
staxrip uses ffmpeg for VP9 but I don't remember how it works. I've tried with avs input:
C:\WINDOWS\system32>D:\Projekte\VS\VB\StaxRip\bin\Apps\aomenc\aomenc.exe D:\Temp\staxrip\Eli_temp\Eli.avs --target-bitrate=1167 -o D:\Temp\staxrip\Eli_temp\Eli_out.webm
Fatal: Specify stream dimensions with --width (-w) and --height (-h)
edit:
C:\WINDOWS\system32>D:\Projekte\VS\VB\StaxRip\bin\Apps\aomenc\aomenc.exe D:\Temp\staxrip\Eli_temp\Eli.avs --target-bitrate=1167 --width=1280 --height=720 -o D:\Temp\staxrip\Eli_temp\Eli_out.webm
Pass 1/2 frame 0/0 0B 0b/f 0b/s 0 us (0.00 fps)
Failed to initialize encoder: Invalid parameter
rc_twopass_stats_in requires at least two packets.
Old 1st June 2017, 18:24   #216  |  Link
stax76
stax76's Avatar
Is there a place to get support from the developers?
Old 1st June 2017, 18:31   #217  |  Link
wiak
#aomedia @ irc.freenode.net probobly your best bet, or there is http://aomedia.org/contact/
btw aoem isnt even done yet sooo
Old 1st June 2017, 18:38   #218  |  Link
sneaker_ger
Try with y4m input via pipe:
aomenc --pass=1 --passes=2 --fpf="statsfile.txt" -o "output" -
aomenc --pass=2 --passes=2 --fpf="statsfile.txt" -o "output" -
Old 1st June 2017, 18:44   #219  |  Link
stax76
stax76's Avatar
Thanks, got it working now as it seems.
https://postimg.org/image/vbjihxjml/
Encoding video using aomenc May 2017
@echo off
D:\Projekte\VS\VB\StaxRip\bin\Apps\ffmpeg\ffmpeg.exe -i D:\Temp\staxrip\Eli_temp\Eli.avs -f yuv4mpegpipe - | D:\Projekte\VS\VB\StaxRip\bin\Apps\aomenc\aomenc.exe - --passes=2 --pass=1 --target-bitrate=1167 --fpf=D:\Temp\staxrip\Eli_temp\Eli.txt -o D:\Temp\staxrip\Eli_temp\Eli_out.webm
cmd.exe /C call D:\Temp\staxrip\Eli_temp\Eli_encode.bat
ffmpeg version 3.3.1 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 6.3.0 (GCC)
Input #0, avisynth, from 'D:\Temp\staxrip\Eli_temp\Eli.avs':
Duration: 00:00:43.41, start: 0.000000, bitrate: 0 kb/s
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 480x272, 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> wrapped_avframe (native))
Press [q] to stop, [?] for help
Output #0, yuv4mpegpipe, to 'pipe:':
Metadata:
encoder : Lavf57.71.100
Stream #0:0: Video: wrapped_avframe, yuv420p, 480x272, q=2-31, 200 kb/s, 29.97 fps, 29.97 tbn, 29.97 tbc
Metadata:
encoder : Lavc57.89.100 wrapped_avframe
Pass 1/2 frame 1/0 0B 0 us 0.00 fpm [ETA unknown] [K
Pass 1/2 frame 2/1 176B 2963 us 674.99 fps [ETA unknown] [K
Pass 1/2 frame 3/2 352B 5649 us 531.07 fps [ETA unknown] [K
Pass 1/2 frame 4/3 528B 8217 us 486.80 fps [ETA unknown] [K
Pass 1/2 frame 5/4 704B 10686 us 467.90 fps [ETA unknown] [K
Pass 1/2 frame 6/5 880B 12733 us 471.22 fps [ETA unknown] [K
Pass 1/2 frame 7/6 1056B 14736 us 475.03 fps [ETA unknown] [K
Pass 1/2 frame 8/7 1232B 16749 us 477.64 fps [ETA unknown] [K
Pass 1/2 frame 9/8 1408B 18797 us 478.80 fps [ETA unknown] [K
Start: 19:32:48
End: 19:32:53
Duration: 00:00:04
Encoding video second pass using aomenc May 2017
@echo off
D:\Projekte\VS\VB\StaxRip\bin\Apps\ffmpeg\ffmpeg.exe -i D:\Temp\staxrip\Eli_temp\Eli.avs -f yuv4mpegpipe - | D:\Projekte\VS\VB\StaxRip\bin\Apps\aomenc\aomenc.exe - --passes=2 --pass=2 --target-bitrate=1167 --fpf=D:\Temp\staxrip\Eli_temp\Eli.txt -o D:\Temp\staxrip\Eli_temp\Eli_out.webm
Stream mapping:
Metadata:
Metadata:
frame= 27 fps=1.4 q=-0.0 size= 5164kB time=00:00:00.90 bitrate=46956.7kbits/s speed=0.0458x
frame= 28 fps=1.3 q=-0.0 size= 5355kB time=00:00:00.93 bitrate=46956.6kbits/s speed=0.0429x
frame= 30 fps=1.3 q=-0.0 size= 5738kB time=00:00:01.00 bitrate=46956.6kbits/s speed=0.0433x
frame= 31 fps=0.9 q=-0.0 size= 5929kB time=00:00:01.03 bitrate=46956.6kbits/s speed=0.029x
frame= 32 fps=0.8 q=-0.0 size= 6120kB time=00:00:01.06 bitrate=46956.6kbits/s speed=0.0281x
frame= 34 fps=0.8 q=-0.0 size= 6503kB time=00:00:01.13 bitrate=46956.5kbits/s speed=0.0274x
frame= 35 fps=0.8 q=-0.0 size= 6694kB time=00:00:01.16 bitrate=46956.5kbits/s speed=0.0257x
frame= 36 fps=0.7 q=-0.0 size= 6885kB time=00:00:01.20 bitrate=46956.5kbits/s speed=0.0246x
frame= 38 fps=0.7 q=-0.0 size= 7268kB time=00:00:01.26 bitrate=46956.5kbits/s speed=0.0241x
frame= 39 fps=0.4 q=-0.0 size= 7459kB time=00:00:01.30 bitrate=46956.5kbits/s speed=0.013x
frame= 40 fps=0.3 q=-0.0 size= 7650kB time=00:00:01.33 bitrate=46956.5kbits/s speed=0.0107x
frame= 42 fps=0.3 q=-0.0 size= 8033kB time=00:00:01.40 bitrate=46956.4kbits/s speed=0.0103x
Old 1st June 2017, 19:38   #220  |  Link
mzso
Too bad Montgomery stopped with the Dalaa blogs. Now there's no info (that mere mortals can comprehend) about what stuff they're experimenting with.
