Old 18th November 2007, 07:17   #441  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
Tags in Ogg are in UTF-8, so UTF-8 to be assumed
Hi, Mosu, a small thing about mmg 2.1.0 Unicode.
The 'tags' (title info etc) in Ogg (Ogg vorbis in my case) are in UTF8,
still MMG reads it as the current ACP (wrong assumption!) to fill the Track name editbox,
resulting a broken string.
If I type a text directly into the "Track name" editbox of mmg,
mmg is happy to accept a Unicode string.
It is just that it cannot 'extract' it from Ogg.
Plus, it complains:
Warning: The Ogg/OGM file ... contains chapter or title information. Unfortunately the charset used to store this information in the file cannot be identified unambiguously. mkvmerge assumes that your system's current charset is appropriate.
This might be so for OGM, but Ogg has well-defined specs, which say Tags are written in UTF-8.
Besides, if the "Track name" editbox is used, the TITLE from Ogg is ignored, so the above warning is maybe pointless and at least confusing. Well, --chapter-charset UTF-8 does work tho...
IMHO, for texts from Ogg, UTF-8, not the Users ACP, should be assumed. Just a thought. No practical trouble at all
Thank you very much!
Liisachan is offline
Old 21st November 2007, 12:48   #442  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
WavPack to MKV/MKA
Another thing. Tags (such as Title) at the end of .wv file are dropped when muxed to MKV/MKA, with the "Warning: wavpack_reader: non-audio block found".
Old 22nd November 2007, 02:33   #443  |  Link
dukey
could mkvextract write the audio delay in the audio filename ?
That would be useful.
Plus, how can one tell what the audio delay is for an mkv file ?
dukey is offline
Old 22nd November 2007, 04:25   #444  |  Link
Isochroma
I second that motion.
Isochroma is offline
Old 23rd November 2007, 04:23   #445  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I don't think mmg creates a soft delay for most audio formats, it'll pad with blank frames instead.
foxyshadis is offline
Old 23rd November 2007, 22:15   #446  |  Link
delacroixp
Emperor building empire
delacroixp's Avatar
@foxyshadis
I know nothing about 'mmg and mkv' so it's gr8 to add an interesting thought to the database...
Pascal
DualRomeEPYC . Storinator
delacroixp is offline
Old 24th November 2007, 07:48   #447  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Really? That's what this whole thread is about, mkvmerge and mmg.
What I meant by the comment is that after you mux, you no longer have any delay at all. You could demux and sync would be maintained. I'm not sure if this is the case for all formats, but definitely is for vorbis.
Old 24th November 2007, 13:31   #448  |  Link
J_Darnley
J_Darnley's Avatar
foxyshadis is correct. The mkvmerge docs say:
-y, --sync
Synchronize manually, delay the audio track with the id TID by d ms. The track IDs are the same as the ones given with −−identify (see section TRACK IDS).
d > 0: Pad with silent samples.
d < 0: Remove samples from the beginning.
o/p: adjust the timestamps by o/p to fix linear drifts. p defaults to 1000 if omitted. Both o and p can be floating point numbers.
Defaults: no manual sync correction (which is the same as d = 0 and o/p = 1.0).
This option can be used multiple times for an input file applying to several tracks by selecting different track IDs each time.
The silent sample only apply to vorbis tracks for AAC, AC3, DTS and MP3 it will duplicate the first frame. The docs say this list is outdated so Mosu or someone else will need to confirm.
Basically this means that once you use mkvmerge to manually sync an audio track it will be altered to be (approximately) that much longer or shorter so that if you ever need to remux you do not need to specify a delay for that track.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline
Old 12th December 2007, 20:39   #449  |  Link
Thunderbolt8
dont know if this has already been mentioned, but mkvmerge sometimes has not only problems with avc files, which were ran through gdsmux before, but also with some broadcasted mpeg2 files.
I remuxed about 6 of those recently and about 3-4 had a little video stutter at some frames in between. this doesnt result in sync issues though, but still looks well, not fluently when this occurs of course. its a small stop of the video 0,25-0.5 seconds, followed by a quick acceleration to have the video back in sync. this wasnt the case with the source .ts file and also not when it was remuxed with gdsmux, only after another mux with mkvmerge afterwards.
when I demux the streams with xport and then just mux them with mkvmerge then everything is fine.
Thunderbolt8 is offline
Old 12th December 2007, 22:03   #450  |  Link
madshi
Have you tried rewriting the timestamps? Another thing worth trying would be demuxing audio and then muxing a new MKV, where video comes from the "bad" MKV and audio comes from the demuxed audio files. That has worked for me sometimes to fix stuttering issues.
madshi is offline
Old 12th December 2007, 23:34   #451  |  Link
Thunderbolt8
i have used mkvmerge afterwards, yes, but havent tried that mixing up remuxed video and demuxed sound yet. not sure in how far mkvmerge does rewrite the timestamps automatically though, when I dont specify anything. I cant do that, because then, when I enter 23.976, 29.97 or this number in between which mpeg2repair sometimes reports (for example something like 24.53) the length is always wrong. it only works when I leave this field untouched.
Old 16th December 2007, 11:58   #452  |  Link
shambles
is there any way to to write the framerate as "24000/1001" and not "23.976" using a timecode file in mmg? i know if you demux the video es you can set it when remuxing but demuxing video when remuxing blu-ray/hd dvd (avc) is inadvisable as far as i've understood
shambles is offline
Old 16th December 2007, 17:49   #453  |  Link
Thunderbolt8
you can use a timecode .txt file and then set the rate for example to 23.9760239, which is already quite close to what you will receive when dividing 24000/1001 with a calculator
Old 19th December 2007, 09:15   #454  |  Link
madshi
Hmmmmm... Is HD DVD/Blu-Ray mastered in 23.976 or in 24/1.001? I'm not really sure myself. Either way, the difference is really marginal...
madshi is offline
Old 19th December 2007, 17:42   #455  |  Link
shambles
evodemux reports "Frame Rate = 23,976 (24000/1001)" for hd dvds and dgindex/dgavcindex report "Frame Rate: 23.976024 fps" for blu-rays, so i'm pretty sure they're all 24000/1001.. sure the difference is tiny but would still be nice to be able to do it right
shambles is offline
Old 19th December 2007, 18:03   #456  |  Link
madshi
FWIW, for a two hour movie the difference is 7.2ms... And as a comparison: One AC3 frame is usually 32ms long. So if you demux audio and video and try to find the correct audio delay and then use delaycut to achieve the final result, you can only move audio forwards/backwards by 32ms at a time. I'm saying this just to put the 7.2ms into the right perspective...
madshi is offline
Old 19th December 2007, 18:13   #457  |  Link
shambles
i know... but i'm a perfectionist when it comes to something i feel passionately about
shambles is offline
Old 19th December 2007, 18:22   #458  |  Link
madshi
Yeah, I see. I like perfect solutions, too.
madshi is offline
Old 19th December 2007, 18:35   #459  |  Link
Thunderbolt8
me too
i always mux with 23.9760239 fps. Ive also demuxed some blu-ray files with mencoder (ratatouille) and here the video for example was reported to be 23.976025 fps (which is quite close to 24000/1001 as well).
Old 20th December 2007, 04:03   #460  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
By confusing 2997/125 and 24000/1001, while the audio delay is just 3.6 ms / hour which is relatively minor, you'll get a lot of subs that are off by one frame. eg. the sub that starts @ 20:51.96 will start at Frame 30018 @ 2997/125, 30017 @ 24000/1001
