Old 30th June 2010, 00:30   #21  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Originally Posted by rack04 View Post
Stupid me! I meant HD DVD version of Serenity. Let me know what I need to upload to reproduce the problem. Thanks.
Just upload all XPL files from ADV_OBJ folder and send me on p.m.
Thanks
shon3i is offline   Reply With Quote
Old 30th June 2010, 00:48   #22  |  Link
rack04
Thanks
PM Sent.
rack04 is offline   Reply With Quote
Old 30th June 2010, 23:38   #23  |  Link
rack04
Works like a charm. Thanks for the update. Is there anyway ChapterGen can be updated to include the chapter names?
Old 3rd July 2010, 12:15   #24  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Not yet, but i will include that option in near future.
Old 11th August 2010, 17:54   #25  |  Link
Boardlord
Many thanks for this tool!
Would it be possible to add .cue support? It would be useful if one wants to burn an audio cd from a concert dvd Cheers!
Boardlord is offline   Reply With Quote
Old 18th August 2010, 19:49   #26  |  Link
manolito
manolito's Avatar
Bug report for DVDAuthor output:
From the DVDAuthor manual:
Specifies a comma (,) separated list of chapter markers. Each marker is of the form [[h:]mm:]ss[.frac]
The separator between ss and frac has to be a '.', not a ':' .
The current version 1.02 uses a ':' all the time which does not work.
Cheers
manolito
Old 14th November 2010, 14:42   #27  |  Link
mrr19121970
@shon3i
Nice tool, do you plan to support MUXMAN chapters?
See here for sample: http://forum.doom9.org/showthread.php?t=104723
Thanks,
mrr19121970 is offline   Reply With Quote
Old 19th November 2010, 14:47   #28  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Updated to 1.0.3
Old 19th November 2010, 15:57   #29  |  Link
mrr19121970
Great! That works a treat.
Old 20th November 2010, 05:47   #30  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Cool! Thanks for your hard work there Shon3i!
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 22nd November 2010, 00:19   #31  |  Link
manolito
manolito's Avatar
Thanks a lot, too, for the fixed DVDAuthor format.
I already assumed that you had forgotten my report...
Cheers
manolito
Old 26th November 2010, 19:03   #32  |  Link
manolito
manolito's Avatar
Still found another small bug which was already introduced with version 1.02:
When you have a ripped DVD structure on your HD and try to extract the chapters from the IFO file with the 'Open File' command, nothing happens. You can extract the chapters with the 'Open Disk' command, though. Version 1.01 did not have this bug.
Two more (really unimportant) things:
The typo in the output format list made it through all versions so far. The company is called Spruce, not Spuce.
And the new Muxman output format is redundant, it is the same as the Celltimes.txt format except for the first chapter point at 0. Muxman does not care if this chapter point at 0 is present or not.
And thanks again for this very nice tool...
Cheers
manolito
Old 29th November 2010, 14:25   #33  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Thanks for report 1.04 is on the way
Old 1st December 2010, 18:53   #34  |  Link
iSeries
Hi shon3i - have just discovered your tool and I'm certain it will do what I need!
I've got the text chapter output from an mkv file. If I input into ChapterGen eg:
CHAPTER01=00:00:00.000
CHAPTER01NAME=00:00:00.000
It doesn't load in. However if I take out the numbers after chapter name, eg:
CHAPTER01NAME=
It loads it ok. Is this normal? Also, do I need to add the quantizer type to the text file, eg -1 or will x264 automatically know what to do with it? Basically I just want to place an I frame at every chapter point.
iSeries is offline   Reply With Quote
Old 28th December 2010, 16:59   #35  |  Link
rack04
I have a NTSC DVD with soft pulldown. I extracted the chapter file using DVD Decrypter. If I remove the soft pulldown using DGDecode do I need to set the Input FPS to 29.970 or 23.976?
Old 3rd February 2011, 19:10   #36  |  Link
Subbat
Excuse my english... I'm french and I'm interest by use your soft with ifo input... and it doesn't work...
Thanks
Subbat is offline   Reply With Quote
Old 3rd February 2011, 20:02   #37  |  Link
Adub
Adub's Avatar
@Subbat
That is a terrible bug report. What exactly doesn't work? Do you get an error? Which IFO are you trying to load? Can you upload a sample?
Site:Adubvideo
Old 3rd February 2011, 20:49   #38  |  Link
Subbat
Originally Posted by Adub View Post
@Subbat
There's no error message... Just nothing happens... Look the message of Manolito which is post on 26th November 2010 19:03... When he report this bug...
PS : Thanks for your interest
Old 4th February 2011, 11:10   #39  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@Subbat or manolito can you send me one of that IFO's which won't open?
@iSeries i can't reproduce. It work for me, try with 1.0.4, and with newer x264 not need to set quantizer anymore
@rack04, check via some editor (eg Virtual Dub)
EDIT: Updated to 1.0.4
Old 4th February 2011, 12:19   #40  |  Link
Subbat
Hi shon3i,
All my ifo dosen't work... for exemple, this one : Voir le Fichier : VTS_01_0.rar
But, i just read your first message anymore, and i see that in v1.01, you said that for ifo, chapterGen must use chapterxtractor... If it's always true for the recent version, where does chapterxtractor must be install?
