25th May 2018, 09:01 | #50981 | Link |
Hi Guys,
A few pages back I posted about the Club 3D CAC 1080 Display Port 1.4 HDMI 2.0 A (B) Hdr Active displayport to hdmi adapter, and if anyone has bought one, and would like the latest firmware for it, PM me (I am working with the manufacturer on ironing out a few bugs).
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 25th May 2018 at 09:07. |
25th May 2018, 09:12 | #50982 | Link | |
And I think Nvidia is really working strange in a way of custom mode. One of funny thing, when my hdmi on 60hz I need to enable on my TV black level of hdmi "Low". When it changes on 24hz with MADvr I need to enable black level of hdmi to "Normal". It's so weird that signal of black seems changing because of refresh rate. Last edited by Koltos; 25th May 2018 at 09:15. |
25th May 2018, 09:38 | #50984 | Link | |
I then went to Nvidia Control Panel/Customise, changed the Refresh Rate to 24 or 23 in the upper refresh rate box (only allows 2 numbers) Then go to Timing, select GTF, then select Manual and the GTF settings stay there, then change that refresh rate in lower right to 23.976 and save. Give that a go and see how you get on. I went from frame drops every X minutes, to frame repeats every 38. When you start a video it says frame drops every X this then goes to days then jumps over to frame repeats, the gist is there are multiple clocks involved and you will waste more time messing with it and getting nowhere, and apart from being fixated on something I never cared about before I am quite happy. |
25th May 2018, 15:12 | #50986 | Link | |||
When using a "process HDR content" 3D LUT, you can override the metadata that is being sent to the display in madVR's HDR settings. I don't know if disabling that checkbox means the movie metadata is passed through.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization |
25th May 2018, 21:00 | #50987 | Link |
Yes, this is what I tried. Or 4000 for the mastering display peak. I seem to get best results using the measured peak nits for a video as the mastering display's peak and 700 for target peak. It has a similar brightness as passthrough. At 10K mastering display peak all movies are pretty dark, with a dim "normal" brightness, but highlights do look good.
I would not be surprised if LG was normally pushing the mid-range into the highlights but the image is still too dark with all my HDR content using a 10K 3DLUT. I did try messing with the metadata options sent to the display but I am not sure they help much, I do not remember a big difference between them. Also I wanted to leave them set to the same values I used when profiling the display.
madVR options explained |
25th May 2018, 21:18 | #50988 | Link |
Can you imagine any reason why madVR 0.92.12 may delay video rendering by about 4-6 seconds of blackness after a player starts? The statistics OSD reports about 100 dropped frames and appears not before the video as well; ProcessExplorer reports 0% GPU usage during this delay; EVR CP renders immediately.
25th May 2018, 23:36 | #50991 | Link |
help setting
Hello everyone, I'm new to the forum, sorry my English, I ask you some advice, in "the display modes" having a 4k TV is better to set in the string of resolutions 2160p23,2160p24 ect ect always? even with 1080p files? in "chroma upscaling" NGU is ok? or too strong?
In "image upscaling" better JIN (upscaling) or NGU (doubling)? here I have a lot of confusion. My video card is an asus amd rx 560 strix o.c. Thanks to everyone bye !!! I forgot with NGU I have very high temperatures, 65 ° GPU Last edited by giulianoprs; 25th May 2018 at 23:39. |
26th May 2018, 00:17 | #50992 | Link | |
NGU Anti-Alias or any other NGU scaler is good for chroma upscaling. For image upscaling/doubling, NGU Sharp or NGU Anti-Alias are also good choices. That temperature is not that high and won't do any damage. If it bothers you, use something other than NGU for chroma/image upscaling.
26th May 2018, 01:25 | #50993 | Link | ||
I've mentioned in one of your avsforum threads that I have an E6 so I'll use mine as an example of what I'm trying to say here. Any portion of content exceeding ~130 nits will begin to "build up" the longer it remains on screen. When calibrating/profiling my primary monitor (E6) I move everything off of it (no desktop icons, no task bar, no wallpaper, etc). I change the background color to 45/45/45 rgb. Since madtpg does not stay minimized after measurements, I push it into the corner and resize it (no chance of retention or burn in from interface elements). When I toss a windowed "60% white" pattern on the screen for 60 seconds, when I return to the desktop I can clearly see a glowing rectangle where the white pattern was. This is retention, and goes away after a few minutes. If you measure say, 30%, it will be brighter than it should. It's very important to know how your display behaves in this regard. This is likely why you have a dimmer picture with DisplayCAL. I'm getting closer to being ready to use DisplayCAL, but I'm assuming white drift compensation will be counter-productive in this case, adding more white patterns in the list. I think the only solution for the time being is to create a custom pattern list manually to keep retention from happening. I've been trying to avoid doing this, as it's a huge pain in the ass lol. And like Florian said, the tone mapping can also screw with it. You'd need to have a separate 3D LUT for the various nit levels specified in the metadata. 85% of 4000 nits would be mapped differently than 85% of 1000 nits. How accurate the metadata is, is another can of worms. --------- Quote:
You cannot LITERALLY follow their procedure. It is impossible. Also, that was for the 2016 oled series like my E6, and does not apply to yours at all. While you can't follow their literally, it is possible to follow their targets... HOWEVER this can only be done by using the service menu controls (lowering Sub-Brightness and Sub-Contrast, using the 2-point "white balance" controls), and aligning 20-point controls with the normal Brightness/Contrast controls. This is a very tedious process. Aside from me and harlekin, I've not seen anyone even try this approach to calibrating these displays. I don't blame them, this does sound completely too stupid to work. I'm not suggesting anyone try this either, just that this is something I've done and can't prove or disprove my claim. |
26th May 2018, 04:52 | #50994 | Link |
Soul Architect
On a ASUS laptop with Geoforce GTX 1050, if I use madVR with DirectX9, sometimes the video driver will be unstable, such as video occasionally freezing or going blank, especially when switching monitor, and sometimes even BSOD. (although I'm not 100% certain these instabilities are caused by madVR but it appears so)
If I render using DirectX11, it appears to be more stable, but the seek bar doesn't display properly and often goes black when hovering the mouse. (and full-screen dedicated mode only displays a black screen) Anyone else have these issues? On my previous laptop, with a Radeon 7670M, it was perfectly stable under Direct9 but DirectX11 wasn't working well. |
26th May 2018, 07:31 | #50995 | Link |
Hi guys
Spotted a bug with confirmed by friend too, from madVR9213 up to madVR9214 (latest) 10Bit for "D3D11 fullscreen windowed" didn't work anymore (it says 8 bit). Do you have the same ? Cheers.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
26th May 2018, 08:23 | #50996 | Link | ||
26th May 2018, 09:34 | #50997 | Link | |
Here it's working nicely d11 fullscreen windowed output 10 bit. but as you know i have amd card. |
26th May 2018, 10:12 | #50998 | Link |
Are you using MPC-HC? If yes, have you tried another NVIDIA driver version? I remember that in one of their release notes some time ago it said there was a bug where playback would freeze/stutter at the start with MPC-HC.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
26th May 2018, 10:23 | #50999 | Link |
I noticed a few folks having problems getting custom modes to work ( i think on Nvidia cards).
I am on driver version 391.35 (and have tried the latest drivers), and I could not get custom modes to work with the latest versions of MadVR. However, I went back to MadVR v0.92.7, and voila, custom modes work perfect, and for my set up, using 10bit rgb @ 4K 23.976 too (one drop frame every 8 hours or so). If you dont want to stay on 0.92.7, simply use that version to set custom mode, and then go back to your preferred version of Madvr. This may, or may not work for others, but it works here, so I see no reason why it would not work for other setups using nvidia.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 26th May 2018 at 10:36. Reason: Typo |
26th May 2018, 10:30 | #51000 | Link | |
