3rd February 2018, 19:20 | #48783 | Link |
Most of the next 5K posts have already been answered. How many people would actually read said book? Besides me, of course.
madVR options explained |
3rd February 2018, 19:51 | #48784 | Link | |
Madshi, is this 4k down-conversion with the RGB 4.4.4 conversion workflow in the 10bit 4k domain (and then down conversion to 2k) very demanding on the GPU card version ? (i know any 4k output would require a high end card, but hope the downconversion process is much less demanding) i am currently deciding on either a 1300gt or 1050gtx (2mb) card for my HTPC (priority being low power use, low heat generation for hot climate use, but max power for 2k madvr HT quality settings if possible) and only intend to use it for 1080p RGB 4.4.4 over hdmi to my 1080 display (which is a 10 bit panel with hdmi 1.4 input), but am hoping to be able to use high quality madvr settings specifically for this 4k downconversion (to 1080p RGB 4.4.4 @ 60 fpsec) system specs: i7 4770k, win 7 64 bit, 32 gb ddr3 ram Last edited by zapatista; 3rd February 2018 at 19:57. |
3rd February 2018, 20:13 | #48785 | Link | ||
Edit: Quote:
My 4K playback settings take 10.4ms per frame on my Titan X (Pascal), I can play for 4Kp60 but without a lot of headroom (60fps is 16.67ms per frame). NGU AA (med) chroma upscaling, SSIM1D100 LL AR downscaling. I recommend you save up for a 4GB 1050 Ti if you are concerned about maintaining RGB downscaling.
madVR options explained Last edited by Asmodian; 3rd February 2018 at 20:31. |
3rd February 2018, 21:32 | #48788 | Link |
@zapatista: I have a 1050 Ti and a 1080 display. I just tested letting madVR upscale chroma when playing 4K, and the card can barely handle 24p with Bicubic AR chroma, SSIM1D downscale, and high quality HDR conversion.
60p is out of the question even with Bicubic downscale. I'd recommend either getting at least a 1050 Ti or preferably 1060 6GB (but it cannot decode 10-bit VP9), or forgetting about upscaling chroma with 4K. IMHO you'd lose more image quality having to use a lower quality downscaler to compensate.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
3rd February 2018, 21:59 | #48789 | Link |
Watched 4K blade runner 2049 on my 1060 6GB using SSIM 2D LL, upscaling chroma separately turned off (of course) and HQ HDR hue with NGU AA low for chroma. Had to overclock the card for it to have enough headroom and the fan was going pretty hard.. If u want to take HDR seriously (24fps) on a full HD TV a GTX 1060+ is a must. Asmodian will be jumping straight on Volta no doubt
3rd February 2018, 22:29 | #48790 | Link |
GPU and CPU just stop
My config is
gtx 970 fx 8370 16 gigs of ram 4k monitor without hdr support. Windows 10 I can't setup madvr to render 4k HDR movies with potplayer and MPC-BE x64. With MPC it works for 2 minutes, and uses 75% of cpu, and 53% of gpu, but then it just stops and uses 1-2%, and video stutters, until i pause it for few seconds and then i can watch movie for another 2 minutes without stuttering. For these few seconds it uses no cpu and gpu. I also use LAV video decoder, and changing DXVA to d11 didn't helped. Tried different queue sizes, but none helped. Madvr settings Last edited by Pauls96; 3rd February 2018 at 22:47. Reason: deleted mpc info which i added in edit |
3rd February 2018, 22:37 | #48791 | Link |
Please post screenshots of madVR OSD (Ctrl+J) in normal and stuttering situations.
3rd February 2018, 22:58 | #48793 | Link | |||
note: some of the 4k files i will be playing might be HDR, i wasnt aware the conversion of HDR to SDR (all 1080 video being SDR i presume) would be an additional gpu load in the conversion process ( i thought the 4k luma 10bit would just be converted to luma 2k 10 bit, and my 360 nits 2k display would just clip anything it cant display ) i might be able to stretch my budget to a gtx 1050-TI with 4gb vram, but a 1060-6gb would be impossible. if i only have to loose the 60fpsec to be limited @ 30fpsec that would be a compromise i can work with (presuming the other 4k conversion steps to 1080 can work in madvr at high quality video settings) having seen the glory of 4k YUV 4.2.0 video converted to 1080p 4,4,4 RGB (if the conversion to RGB occurs in 4k), i really hope i can get this working on my current setup by just upgrading the video card to a 1050-TI 4gb vram Last edited by zapatista; 3rd February 2018 at 23:07. |
3rd February 2018, 23:13 | #48794 | Link | |
3rd February 2018, 23:41 | #48797 | Link | |
Definitely not beyond its boundaries but I believe Nevcairiel said it was pointless at typical refresh rates. Last edited by ryrynz; 3rd February 2018 at 23:43. |
3rd February 2018, 23:50 | #48798 | Link | |
i personally see no way this will ever work properly for a lot of reasons. simple example a good BFI implementation needs show the frame for a very short time like 12 ms out of 16ms the best you could do with a 120 hz screen is about 8 ms. |
4th February 2018, 03:09 | #48800 | Link |
I'm fairly certain then it's your CPU that's not up to snuff for 4K. Probably best to update your GPU to get HEVC hardware decode or just update the cpu/mobo.
Do you run into this same issue with EVR? You also said with mpc it runs for 2 mins, I assume your performance issues occur with potplayer also? Last edited by ryrynz; 4th February 2018 at 03:24. |
