Old 13th September 2008, 17:23   #41  |  Link
Diodato
Works right of the box. But I have the CUDA SDK installed.
WinXP SP3
E6600@3.0GHz
8800 GTS 512MB
nVidia display drivers v177.84
Source: sat DVB-S2 stream (1920x1080, HP@L4.0)
FPS: 45-50
CPU: 6-11%
Nice work Donald!
Diodato is offline
Old 13th September 2008, 17:41   #42  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
it would be nice if somebody could test speed during transcoding from blu-ray -> x264 rip. (software decoding vs hardware decoding)
Atak_Snajpera is offline
Old 13th September 2008, 17:42   #43  |  Link
That can't be done until I complete DGAVCDecodeNV. Coming soon as I've already worked through all the quirks of using the GPU.
Guest is offline
Old 13th September 2008, 18:02   #44  |  Link
Sagekilla
x264aholic
I had to delete all the dlls except nvcuvid.dll on my laptop, but I got it working on my laptop. I installed the SDK beforehand to make sure this would work. I still don't want to try anything since I have several processes -- including a scheduler --- depending on nvapi.dll that I don't feel safe replacing my system32 copy.
C2D @ 2.16 GHz
8600M GT
Vista SP1 w/ CUDA 177.84 drivers + toolkit
12 - 17% CPU
38 - 48 fps (averaging 46ish, only dips to 38 rarely)
Source: Pirates of the Carribean 3, blu-ray rip
So it's definite something went bad with my desktop. I'm going to disregard this since I'll be reinstalling XP on it anyway.
@neuron2: Let me know when you get a working copy. I'll be glad to do some beta testing for you on my laptop. My last transcode (PoTC3) took 80 hours on a 2 GHz Opteron 170. Decoding Blu-Ray + light filtering (Read: MVDegrain3) + high compression in x264 => 0.6 - 0.7 fps in x264. So, this would be a HUGE benefit to have
Sagekilla is offline
Old 13th September 2008, 18:19   #45  |  Link
lucassp
Works right out the box with ForceWare 177.92 (no CUDA SDK/Toolkit installed) on: 8800GT 512MB, XP SP3, C2D E8400@3,5GHz!
lucassp is offline
Old 13th September 2008, 18:24   #46  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
Ok, before I go ahead and install the CUDA kit, here are the error messages I'm getting:
- Upon opening DGAVCIndexNV, I recieve the warning message, "ERROR: cuInit failed (100)" Hit yes to continue blah blah, cancel to supress...
- Attempting to open an AVCHD video file gives me this error message, "GPU decoder: Failed to create video decoder"
- When closing the program I get a warning. "cuvidDecodePicture: 400" Hit yes to continue blah blah, cancel to supress...
The two DLL files you included with the program were actually already in the SysWOW64 folder (basically System32 for 64-bit Windows OSes), and the same error messages came up before and after I replaced them. Using an 8800 GTX. I'm going to install the 3 files right now. I've done this before to test the Folding@Home GPU client so it should be no problem to install.
"I'll take a potato chip... and eat it!"
Yoshiyuki Blade is offline
Old 13th September 2008, 18:27   #47  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
It's working fine for me.
worked right out of the zip on my
8600 GT (512MB)
XP x64 SP2
Phenom 9850
took 2 mins to run through my AVC .TS that's 24min @ 720p60.
the standard libavcodec version couldn't even decode these .TS files either!
while it was saving the project i was watching the process explorer graphs for it, was using 25% CPU utilization (1 core)
about 50% of the 25% was attributed to kernel times for the I/O
in play mode it does 43 fps with 20% cpu utilization, half still with kernel times
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline
Old 13th September 2008, 18:46   #48  |  Link
Daodan
unrecognized user
Tested a bit with a 25mbit 1080p30. With display disabled I get ~40fps with 8800gt 256mb and 10% off e6400 oc. I get 120fps with coreavc in timecodec. The cuda way should be faster however while encoding that output as well.
zzz
Daodan is offline
Old 13th September 2008, 18:49   #49  |  Link
Sagekilla
x264aholic
I found what might be a bug -- If I exit DGAVCNV while previewing a movie (disable display is checked) I simply get an error message from windows telling me the program has stopped working. No other debug info. On another note, I've also noticed the issue with half the CPU usage being towards kernel usage. Take a look here: http://img.photobucket.com/albums/v6.../kernusage.png
Old 13th September 2008, 18:53   #50  |  Link
lucassp
Originally Posted by Yoshiyuki Blade View Post
Using an 8800 GTX.
It doesn't work with G80 GPU's: Geforce 8800 GTX, 8800 Ultra, 8800 GTS 640MB/320MB!
lucassp is offline
Old 13th September 2008, 18:56   #51  |  Link
Sagekilla
x264aholic
I think those GPUs have bitstream decode only.. I could be wrong.
Old 13th September 2008, 18:58   #52  |  Link
Yoshiyuki Blade
Novice x264 User
Yeah, I posted concerns on the main thread here: http://forum.doom9.org/showthread.ph...05#post1182305. It was still worth a shot though.
I installed all the necessary files with pretty much the same errors as before. Gonna try it on my bro's 8400M GS.
Old 13th September 2008, 19:11   #53  |  Link
CruNcher
CruNcher's Avatar
Btw for all Nvidia users please can some confirm this behaviour (especialy on G92) http://forum.doom9.org/showthread.php?t=140767 would be nice if you could post your results there about this issue if you have the time
It is about Time
CruNcher is offline
Old 13th September 2008, 19:23   #54  |  Link
crypto
@DVBPortal
crypto's Avatar
Originally Posted by Sagekilla View Post
@neuron2: On my both my computers I received the error message on simply opening DGAVCNV saying:
ERROR: cuInt failed (100)
Hit Yes to continue ....
GPU decoder: Failed to create video decoder.
Same here, I also get both errors. The first when starting DGAVCIndexNV. The second when loading a stream. Plus when ending
Hit Yes to ....
CUDA is installed. Badaboom is running ok.
crypto is offline
Old 13th September 2008, 19:26   #55  |  Link
menlvd
waiting for DGAVCIndexNV.dll ...
menlvd is offline
Old 13th September 2008, 19:31   #56  |  Link
Inventive Software
Turkey Machine
@crypto: what card you running? Tried the DXVA checker Donald linked to in the 1st page?
ATTENTION EVERYBODY: This does NOT work with first generation 8 series cards based on the G80 GPU. These include the 8800 GTX, 8800 GTS 320MB / 640MB, and 8800 Ultra cards, as they do not have the VP2 PureVideo decoding engine.
Those with these cards reporting them working would do well to tell me so I can edit this statement.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 13th September 2008, 19:31   #57  |  Link
Sagekilla
x264aholic
I still have to work out some issues with my desktop -- I'm not fully sure what's wrong with the system so it could be a number of things. My problem may or may not be related to yours.
Old 13th September 2008, 19:33   #58  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
that would be DGAVCDecodeNV.dll
Old 13th September 2008, 19:41   #59  |  Link
crypto
@DVBPortal
crypto's Avatar
OK, I got it running.
Here are my results with TS 1080i PAFF 25 Hz:
FPS is 42-45
CPU is at 0 (That's zero) ???
@Inventive Software
GTS 8600 on Vista Ultimate 32 Bit Q6600
crypto is offline
Old 13th September 2008, 19:47   #60  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Where do i read the FPS?
The FPS box at the bottom is empty here.
(8800 gts g92)
bob0r is offline
