Old 10th November 2016, 22:05   #40021  |  Link
VictorLS
sneaker_ger, huhn
Thanks guys. That all desired settings (but for faster change them I want possibility to type digits from keyboard in fields directly and may be cusomize one click presets - there is many space in properties and color & gsmma tabs for that). Of course, sometimes 0-255 is better, sometimes 16-235 - depends on played video.
Originally Posted by sneaker_ger View Post
You don't have any GPU driver "video enhancements" activated, do you?)
I always turned off any "video enhancements" even if they was turned on by manufacturer as default. So I don't like .NET and so AMD (was ATI) Control Panel I not even installed I turned off all "video enhancements" by watching key {} in HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\VIDEO\Video0 and changing keys like this:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Video\{A104160B-A34F-400E-AC50-C14942E8E718}\0000]
"TRDenoise"="0"
"DXVA_WMV"="0"
And reboot after changes.
Question about HDR: do all see trees "in fire" between green trees from 11 to 21 second in Samsung_HDR_Wonderland.ts http://demo-uhd3d.com/fiche.php?cat=uhd&id=153 especially if compare with EVR? I've never seen so saturated colors in nature so I think the truth between madVR and EVR - am I wrong?
VictorLS is offline   Reply With Quote
Old 10th November 2016, 22:26   #40022  |  Link
Originally Posted by VictorLS View Post
sneaker_ger, huhn
no if the file is correct created madVr knows the levels and will handle them correctly.
a file that is full range without full range flag is broken and nothing else.
Old 10th November 2016, 22:31   #40023  |  Link
Ver Greeneyes
If a file is wrongly detected as full range when it should be using TV range, or if it's detected as TV range but it actually needs to be expanded twice, just use the hotkey Ctrl+Shift+Alt+I to adjust the source levels used by madVR.
Old 11th November 2016, 00:06   #40024  |  Link
sauma144
I cross my fingers and hope this weekend will be THE weekend.
sauma144 is offline   Reply With Quote
Old 11th November 2016, 06:27   #40025  |  Link
VictorLS
huhn, Ver Greeneyes
Thanks once more (it's a pity this forum havn't Thanks button).
And what about my question about HDR file?
sauma144
What did you mean? May be you are Formula1 fan as I am? I cross my fingers about Lewis Hamilton but not all in his hands due to broken engines across this season.
Old 11th November 2016, 07:21   #40026  |  Link
with the HDR problem please make a screen with the OSD(control+j).
this file has Bt 2020 colors and no display is able to display them and it is a HDR demo i wouldn't be shocked if the this file was created with wrong colors in mind but i haven't watch it.
edit: and madshi doesn't answer questions right now not until "THE" weekend. which is when it's done
Old 11th November 2016, 07:59   #40027  |  Link
VictorLS
I'll do it after 14:00 GMT+3
I am novice in this thread so can you provide link what is waiting for THE weekend?
Old 11th November 2016, 08:24   #40028  |  Link
people are hyped about the new scaling algorithm "NG1".
which will be released "when it's done".
http://forum.doom9.org/showpost.php?...ostcount=39948
Old 11th November 2016, 09:12   #40029  |  Link
Mistery 73
hello folks, I need some advice you think is best to create a 3d lut with BT2020 BT 709 or use the mad in upscalink 1080p to 4K know that my projector does not have a gammut of BT2020 do you advise me to do?
thank you
Mistery 73 is offline   Reply With Quote
Old 11th November 2016, 09:19   #40030  |  Link
what has upscaling to do with colorspaces?
if your devise doesn't have a gamut of BT 2020 (of cause it doesn't) a proper 3D LUT will take care of it.
Old 11th November 2016, 12:14   #40031  |  Link
VictorLS
Thanks. As I assume will be less aliasing with "NG1", don't it?
Promised screenshot Samsung_HDR_Wonderland.png (3,2MB) http://rgho.st/6YhK6hTpN
Old 11th November 2016, 12:39   #40032  |  Link
the image is very vivid in general your screen is just washed out.
have a look here at black clipping.
http://www.avsforum.com/forum/139-di...libration.html
1-16 are NOT suppose to blink.
Old 11th November 2016, 13:48   #40033  |  Link
Sunset1982
Why is your refresh rate 47,952? Where is the benefit to 23,976?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 11th November 2016, 14:08   #40034  |  Link
VictorLS
My monitor not support 23,976 (in EDID there is nothing other then 60Hz at all, but 50, 48 and 47,952Hz are supported natively through VGA and DVI although with message "Out of range"), so I set 47,952=23,976*2 - for progressive scan it is the same, but for interlaced vertical frequency of monitor must be equal frequency of fields - else will be double or stuttering artifacts.
Old 11th November 2016, 16:03   #40035  |  Link
madshi
Sorry guys, NG1 is still not ready for release this weekend. I'm hopeful I'll have a first (probably not completely finished) version out by next weekend.
To hold you over, here's another little teaser. First some words about performance:
There will be several quality/speed levels. NG1 "low" quality will probably have a similar speed to Jinc AR*) or super-xbr*). Or at least that's what I'm aiming at. I still need to test how much I can downscale the algorithm before quality breaks down completely. NG1 "high" quality (which both teasers are made with) will probably have a similar speed to NNEDI3-64*).
Here's a photo comparison. Please note that in the NG1 image only the luma channel was upscaled with NG1. The chroma channel was upscaled with Bicubic60. Waifu2x doesn't make that compromise, which explains the difference in chroma quality:
original -- | -- Jinc AR -- | -- super-xbr 100 -- | -- NNEDI3 256 taps + SuperRes 4 -- | -- NG1 (wip) -- | -- waifu2x
Some of you guys didn't like the name "NG1". I'm open for other suggestions. Please feel free to post your ideas. If there's no suggestion that jumps out at me, I'll probably stick with "NG1", though.
I'm listening to your comments, but I'll reply to all old and new posts only after the new version is released.
*) without SuperRes
Old 11th November 2016, 16:20   #40036  |  Link
Sunset1982
Thanks for your update madshi! Take your time...
Old 11th November 2016, 16:34   #40037  |  Link
Razoola
Name proposal... 'Prismē'
Old 11th November 2016, 16:46   #40038  |  Link
steakhutzeee
steakhutzeee's Avatar
Hi
Using madVR v0.90.24 on MPC-BE.
As i can see here https://linustechtips.com/main/topic...ck-on-windows/ i can use LAV filters instead of the internal ones. You suggest me to do this?
Thanks
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 11th November 2016, 17:28   #40039  |  Link
if you want ordered chapter support yes.
Old 11th November 2016, 17:32   #40040  |  Link
cork_OS
cork_OS's Avatar
NG1 is excellent, but waifu does some magic on horizontal lines:
CrystalClear
cork_OS is offline   Reply With Quote
