Old 15th December 2007, 06:18   #41  |  Link
Rectal Prolapse
Thunderbolt nailed it!
Rectal Prolapse is offline   Reply With Quote
Old 15th December 2007, 11:33   #42  |  Link
Thunderbolt8
enlightenment struck me!
Old 23rd December 2007, 13:07   #43  |  Link
bond
moved to hddvd/bluray forum, as i think this fits better there
Ogg Theora | Ogg Vorbis
Old 5th January 2008, 21:12   #44  |  Link
Luvpeaceguru
Any update on this tool?
Luvpeaceguru is offline   Reply With Quote
Old 12th January 2008, 18:33   #45  |  Link
A Pal
The Secret of the Blu-Ray-Region Codes
Hello,
I would like the know more about the structure of Blu-ray Region codes.
Here is what I found about DVD-Region codes:
In usual DVDs (not RCE), the Region code is stored in the file "VIDEO_TS.IFO" (table "VMGM_MAT"), byte offset 35 decimal (23 hex).
A "real" region free (for "pseudo-region-free," see below) or an RCE-protected DVD has the value 0 /00.
Here are the values of the Regions (decimal / hexadecimal) :
"Pseudo-region-free" (Regions 1-6 are supported, but Region 7 and / or Region 8 are not):
R1-R6: 192 / C0 R1-R7: 128 / 80 R1-R6 + R8: 64 / 40
Regions:
R1: 254 / FE R2: 253 / FD R3: 251 / FB R4: 247 / F7
R5: 239 / EF R6: 223 / DF R7: 191 / BF R8: 127 / 7F
DVDs made for more than one Region have other values, e.g. a DVD for Regions 1 and 4 has 246 / F6, one for 2 and 4 has 245 / F5, one for 2 and 5 has 237 / ED.
The RCE protection can be hidden in all .IFO files.
It is in one or several PGC's as PRE-command.
One must search in the Title-PGC's and Menu-PGC's of the .IFO files the command
'Set GPreg<n> mov <Player Region Code>'
and replace the expression <Player Region Code> by the number of the Region for which the DVD is made, e.g. for a DVD for Region 1, the modified command would be:
'Set GPreg<n> mov <1>'
Sometimes additional modifications are necessary.
But where and how are Blu-ray-Region codes saved, and what are the values? There are, fortunately, much fewer combinations possible than in the case of DVD Regions (ABC [= region free], A, AB [= BA], AC [= CA], BC [= CB], and C).
Perhaps someone could explain it to us.
Thank you very much in advance and many greetings,
A Pal
A Pal is offline   Reply With Quote
Old 24th January 2008, 22:42   #46  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Any news on this software?
We can really use a BD editor by now, to make some "MOVIE ONLY" BD-SL images
bob0r is offline   Reply With Quote
Old 27th January 2008, 08:33   #47  |  Link
Peer van Heuen
SlySoft Team Member
It's not as easy with Bluray.
a) the region code(s) are not stored on the disc at all.
b) The code in the movieobject.bdmv file does similar checks just like a DVD with the commands in the IFO files.
c) many Bluray discs do additional checking in Java code (JAR files).
SlySoft Inc.
Peer van Heuen is offline   Reply With Quote
Old 31st January 2008, 22:20   #48  |  Link
PleXuS
Is there a way to adjust the playlist?
Becoz i got wrong out time.. should be easy if i could adjust it
PleXuS is offline   Reply With Quote
Old 9th February 2008, 15:37   #49  |  Link
arrgh
Forced Subtitles in BluRay
is there a (simple) method to recognize forced subtitles in a BR?
arrgh is offline   Reply With Quote
Old 22nd February 2008, 09:56   #50  |  Link
Pelican9
Coder
Pelican9's Avatar
Help (files needed)
Could somebody send me a complete BD without the movie files?
The most important files: MovieObject.bdmv, index.bdmv, PLAYLIST\*.mpls, CLIPINF\*.clpi, (BDJO\*.*).
I would like to continue the developing of this tool, but I'm in Africa and I haven't brought any BD stuff with me.
Pelican9 is offline   Reply With Quote
Old 25th February 2008, 00:46   #51  |  Link
nautilus7
nautilus7's Avatar
So you need all files except those with .m2ts extension (stream folder)? I will upload on a filesharing site... Is that ok?
Btw, i have a BD that doesn't have a AUXDATA folder and BDedit can't process it.
nautilus7 is offline   Reply With Quote
Old 25th February 2008, 01:12   #52  |  Link
Pelican9
Coder
Pelican9's Avatar
Thank you, but I've received some. The new version will not check the AUXDATA folder (the standard says it's mandatory)
Old 25th February 2008, 01:19   #53  |  Link
nautilus7
nautilus7's Avatar
I am already uploading ratatouille, which has a certificate folder, and uses java (BDJO & JAR folders) also. Do you have such BD?
EDIT: http://www.sendspace.com/file/4gsh7t
Old 25th February 2008, 09:28   #54  |  Link
Pelican9
Coder
Pelican9's Avatar
Thank you!
Old 28th February 2008, 00:09   #55  |  Link
Pelican9
Coder
Pelican9's Avatar
New version of BDedit (v0.13b)
Not much but you can edit the commands in the MovieObjects.bdmv.
It can remove the region code checking too (easier than manually).
Old 28th February 2008, 12:18   #56  |  Link
nautilus7
nautilus7's Avatar
Nice! Keep on!
Old 1st March 2008, 17:16   #57  |  Link
eyekyu
will this app work to add multiple titles on a blu-ray disc
eyekyu is offline   Reply With Quote
Old 3rd March 2008, 15:00   #58  |  Link
Pelican9
Coder
Pelican9's Avatar
I've uploaded a new beta.
It can add/delete titles, add/delete objects, add/delete commands (with maintain the GoTo addresses).
Old 5th March 2008, 10:20   #59  |  Link
moviefan
Great job! I have been thinking about trying to reverse engineer the file structure of bdmv, in order to be able to replace original streams by re-encoded ones. I assume that the bdmv's have to be updated in that case. Since you seem to have achieved to know the structure, can you explain to me, what settings are related to the stream and where these information are stored in the bdmv's and in which ones? That would be great!
moviefan is offline   Reply With Quote
Old 5th March 2008, 11:29   #60  |  Link
Pelican9
Coder
Pelican9's Avatar
I think that infos stored in playlist (mpls) and clipinfo (clpi) files.
I'm working on BDedit now, so you can edit these files soon.
bd menu, bdedit, blu-ray
